PWM Lamp Dimmer Using NE555 Timer
About: Welcome to ElectronicsHub.Org. We provide various free project circuits, project ideas on electronics, electrical, robotics, solar, sensor based, communication, etc. and latest technology information. For mo...
This is an engineering level project in which we use PWM to dim the intensity of the LED light. Here, the DC source is connected to NE555 timer. The PWM signal always depends on the duty cycle, so we can vary the duty cycle through NE555. If we vary the duty cycle, we can generate the pulse with various width. So we use timer to generate the PWM to dimmer the LED or increase brightness of the LED. Get detailed information about this circuit in the post - PWM LED Dimmer using NE555 Timer.
Supplies:
  • Arduino Contest 2019
  • Classroom Science Contest
  • Woodworking Contest
    Woodworking Contest
6 Discussions
krishnac43
2 years ago
Don't try this it doesn't work....... If u want it to work don't give supply there. But u can give supply to 7th terminal of 555 timer IC with 1k resistor by varying potentiometer u can absorb the output.
krishnac43
2 years ago
Is this project really work.
WilliamD157
2 years ago
One more comment - pin 1 of the 555 needs to go to ground. michael_tsx is also correct...
ol FERAL lo
3 years ago
Why display 555 like that? This circuit make no sense
michel_tsx
5 years ago
In your schematic your leds are directly grounded, bypassing the 2N2222
mdemi
5 years ago
put as many led as possible in series. this will reduce the current consumption.
