Pallet Wood Coffee Table
About: I really like woodworking and Metalwork. I like to build just about anything that pops into my head. I like making Jigs that makes jobs easier and saves time.. I have a few videos on My Youtube Channel but...
The First Step was to break down these Pallet wood crate lids that I come across in a friends shed. So out with the crow bars and wooden blocks. After removing all the nails and staples I sorted out the best parts and glue and clamped them together. Sorry but I could not find the pics for that process ....Annoying lolol...
Supplies:
Step 1: The Table Top Pattern
Once all the glue had dried I sanded the top starting from 80 grit to 220 grit then hand finished. I Routed a dead end chamfer to a one inch stop @ all four corners.
I then Routed the lines in the top with a 1/4" round nose groove bit. Took me some Time as I measured everything to make sure it all came out square.
Step 2: Frame Work
The frameWork was made from the rails from the Pallet wood lids. I did not change these much only cut to length and sanded as they were at the right depth I wanted. I added extra narrow rails to these so I could screw the top to the frame. I then added the corner braces to take the legs..
Step 3: The Legs
These I made up from a length of 4"x 4" post I had, cut them to length then I just sanded and Routed a dead end chamfer @ the corners..
Step 4: Legs Continued
I then assembled the table by placing the legs at the corners and screwing them into place @ the corner braces using a roofing square to get it straight and true.
Step 5: Finishing
After the finished assembly I stained it in dark Oak four coats. Then I added the decorative pieces to the front.
I used branches,some cut down homemade veneer cut on the table saw and bark. Then used a hot glue gun to set them in place the pinned them with tacks. The finish is clear quick dry varnish, four coats. I really enjoyed this build and it was a good upcycle project.....
Woodworking Contest
This is an entry in the
Woodworking Contest
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    Alex in NZ
    23 days ago
    That's a very nice-looking table. Thank you for sharing your making :-)
