Pallet Wood Seahorse
1,599
32
11
Pallets are everywhere and a decent source of wood for projects that don't need the polished looked provided by higher quality wood. They are also great for concept work prior to using expensive wood in a finished product. The best part is that they are free, business and individuals are throwing away pallets basically everyday. Check your local craigslist or if you see a pile outside a building just go ask most businesses are glad to have them away.
What you'll need:
Materials:
  1. A Pallet
  2. Wood Stain
  3. Polyurethane
  4. Paper
  5. Spray adhesive
Tools:
  1. Jigsaw / Bandsaw
  2. Sawzall / Reciprocating Saw
  3. Random Orbital Sander
  4. High Speed Rotary Tool (Dremel)
  5. Brad Nailer
Step 1: Select Pattern and Print Out
The first thing to do is select your pattern and print it out to the size you want the finished product to be.
To do that open the image you'd like to print in Paint.
Then go to Print select Page Setup
Under the Scaling section, select "Fit To" and change the setting to the size of your choice this is 2 by 2 pages
Click OK.Print the image from Paint, and make sure to select “All Pages”
Once you print it out lay out your pattern and use packing tape* to connect the pages.
*Packing tape cuts well and doesn't seem to gum up saw blades.
Step 2: Cut the Pallet and Prepare the Wood
Use your reciprocating saw to cut the pallet down to size. For this project it worked out that I could cut the slats and not have to worry about the nails.
If you are doing larger projects be sure to remove all the nails when dissembling so you do not damage tools during your build.
Once the pieces were cut I use hot glue to create a temporary bond in the pieces so that I can sand them all evenly. If you have a thickness planner you can ensure they are even by using it here. I went through the grits from 80 up to 220.
Step 3: Attach Pattern and Make the Cuts
I used spray adhesive to attach the pattern to the boards.
Once that dry I tried using an old jigsaw to make the cuts but it just wasn't working. While I went to get a new one I decided to switch to the band saw.
To make this easier, I used a razor knife to slice the pattern and break the hot glue joint. I added some more spray adheasive to the separate pieces and trim off the excess with the new jig saw.
I could have made all of the cuts with the jigsaw however it was easier to just bring it to the band saw to make the final cuts, take your time and make cuts close to the line on your pattern.
Before assembling I sanded all of the pieces individually. Using the Random Orbital Sander for the larger pieces and a High Speed Rotary Tool i picked up from GearBest. I was surprised at how well this tool was able to get into smaller spaces without bogging down.
To assemble the pieces I used some of the cut offs and a pin nailer, If I was going to do it again I would either glue the pieces together or use pocket holes to join them.
Step 4: Finish the Project
All that is left to do is apply the wood finish of your choice.
I went with the Varathane wood stain in Vintage Aqua, and just used a simple foam brush to apply a few coats.
After that dried I applied a couple coats of polyurethane sanding lightly in between coats
That should make for a project complete, I invite you to follow me on social media links below:
KagedCreations@gmail.com
Facebook: https://goo.gl/3EBL8W
Instagram: https://goo.gl/3EBL8W
Instructables: https://goo.gl/3EBL8W
Twitter: https://goo.gl/3EBL8W
YouTube: https://goo.gl/3EBL8W
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    11 Discussions
    Kane Measham-Pywell
    2 years ago
    If you have one I would recommend running a metal detector over the wood as there are sometimes pieces of metal embedded in the wood
    I've been thinking of picking one up, I normally run a magnet accross it but that's not always 100% effective
    Love the use of reclaimed materials for this project! Something about making a sea creature (part of nature), out of something you saved from potentially sitting in a landfill ruining nature seems quite ironic to me! (I'm not a huge tree hugger at all but I just find the connection funny)
    Haha that's one of the things I like about reclaimed stuff. When I first started it was because it was cheap/free but as I do more I like it. (I think listening to the reclaimed audio podcast fuels this)
