Paper Gun!
9,611
38
19
About: Greetings! I'm an engineer, and I like to use my hands to make things that I find interesting. Fun stuff!
This is a paper gun, made from only paper folding! I was taught this when I was a little kid by a family friend, and from a basic web search, have never found this method online. So in this age where everything is electronically documented, let us follow the masses and bring this method to the world!
DISCLAIMER: Describing paper folding techniques is much more difficult than I could ever have imagined! I'm dreadfully sorry if my instructions aren't too clear. Hopefully, following the pictures will help you along. Best of luck, and godspeed!
Step 1: Paper!
Total: 5 sheets
Cut into:
  • 3 hamburger style halves
  • 14 quarters
The quarters will make up the handle, so you can add some more or take some away, depending on your hand size. Custom gun handles, what? Fun stuff!
Step 2: Make the Little Handle Pieces
This step is to make ONE little two-pronged, triangular piece. Many of these will fit together to make the handle of the gun. This is the most tedious step, so I put it first. Once this part is done, you're more than halfway done!
  1. Fold a quarter hamburger style
  2. Fold it the same way again
  3. Fold the piece the OTHER way. I guess since now the longest side is horizontally because of the first two folds, this is also hamburger?
  4. Open it back up, and fold both ends perpendicularly. Just look at the picture...
  5. Fold the overhanging corners in. I like to leave some space so it doesn't get super bulky; I just eyeball it. Or you can just ignore me, whatever.
  6. Fold the overhanging edge over. So that the edge essentially continues the way it was going.
  7. Fold the whole thing together. The legs you folded over should end up on the inside.
Step 3: Make the Body
Yay, you're more than halfway done! This part ain't hard, unless you really suck at folding into thirds. Even then, that's only one time. Here we go!
  1. Fold one half piece into quarters. This piece shall be known as the "quarters" piece.
  2. Fold another half piece into thirds. This one shall be known as the "thirds" piece.
  3. Fold the "thirds" piece into a "W" shape
  4. Wrap the "quarters" piece around the middle of the "W". You can choose where the folds start on the "quarters" piece so that the last part will end in the middle.
  5. Fold the free edges of the "W" into the wrapped part. It should now look like one contained piece, without anything flapping around.
Step 4: Make the Barrel
This part took some time for me to get. The trick that helped me is to begin rolling a corner of paper into as tight of a roll as possible, between your thumb and forefinger.
  1. Start rolling the last half sheet of paper as tightly as possible
  2. Roll up the rest of the sheet as tightly as possible
  3. Realize that it comes loose when you're not holding it
  4. Unroll the sheet
  5. Repeat on an opposite corner. An opposite corner means that it shares no edges with the corner you started on.
  6. Roll it all up; this time, it should stay!
Step 5: Assemble the Handle
  1. Notice that there are two slits along the backside of your triangular handle pieces. This is where the next piece will insert.
  2. Push the two prongs of another triangular piece into the slits. One prong into each slit.
  3. Push it as tightly as possible
  4. Repeat for all the handle pieces
Step 6: Assemble the Barrel Onto the Body
  1. Open up the middle part of the "W" a little bit. The barrel will fit snugly into there
  2. Push the barrel into that gap. You can also twist the barrel to make it wide enough to fit in the "W" more snugly.
  3. Tear off a bit from the front to make it straight
  4. Fold the back of the tube flat
  5. Fold up the back end. Just as an aesthetics thing.
Step 7: Handle to the Body
  1. On the back of the body (the end where you folded the barrel up), there is another pair of slits. This is for the prongs at the front of the handle
  2. Push the handle in!
Step 8: Done!
Hopefully, my instructions weren't too horrible. Describing paper folds really is difficult, and I apologize for my ignorance in proper paper folding terminology. I'm usually better at this, I swear! For proof, you can check out my website, Creations of My Mind (yes, I'm shamelessly promoting myself).
And most hopefully of all, I hope that this worked for you and you will be able to bring the wonder of this neat little gun into the lives of others! Good day!
  • Classroom Science Contest
  • Woodworking Contest
    Woodworking Contest
  • Gardening Contest
    Gardening Contest
19 Discussions
AmadorF
3 years ago on Step 8
Thanks for this! I've made a couple for my nephew and niece. The instructions were a little tough to read, but the pictures made it easier.
papergeek
4 years ago on Introduction
s,cool I am a big paper gun fan I love making and playing with them in my backyard with my brother
Thanks! You seem to be in the same category as me, you are really good at origami and crafts yet you have a hard time understanding instructions. Although, your instructions about this paper gun has helped me a lot for the last few minutes, take a look at the gun I just made! (note: I made it just like yours and then I cut out a trigger and added the, oh what is it called, the thing that spins the bullet chamber, I'm not very good with knowing what the parts of a gun are called. And I also had to use some tape). Hope you like it! I'm planning to use a sharpie to color it somewhat.
Pan Zijin
5 years ago on Introduction
Er... can you make a video?I'm really confuses when I printed these out!
Are you confused or something and can't understand these instructions irulelikecheeze? Or do you just like ray guns better than normal, gunpowder pistols. I was just wondering because, as far as I'm concerned, this is probably the easiest, yet coolest origami gun I have ever seen on the internet!
No offense, Mr. Ruling cheese guy
-J.R.
