Rubber Band Powered Paper Arrow
1,140
8
6
About: maker
In this Instructable i will show you how to build a paper arrow that is shot with a rubber band. It can easily fly over 12m (40ft) an is pretty accurate.
Step 1: What You Need
You need a pair of scissors, some glue, tape and 4 sheets o paper. That is all.
Step 2: Buildin the Shaft
First take a full sheet of paper and roll it up diagonally.Be sure to roll it as tight as possible. Put some glue on the inside and tape the end corner around the tube. Now take another full sheet of paper and roll it up sideways around the other tube. Then cut one end of the diagonally rolled paper off completely. Leave some sticking out on the other side. This will be where you grip the arrow. Reinforce the whole thing with some tape.
Step 3: Build the Head
Now take another full sheet of paper and roll it diagonally. The fold it in half. Tape the halves together and cut it in two peaces, each consisting of two tubes. They should be roughly the same size. Cut the one with the fold at an angle. This will be where the rubber band will hook on the arrow.
Now tape the two sets of tubes to the main shaft. Be sure that the notch for the rubber band faces the main shaft. use plenty glue and tape to secure the peaces together.
To complete the head cut the final peace o paper into a strip a bit wider than the head. Glue and tape it around the tubes so that it covers some of the notch keeping the rubber band from getting stuck between the tubes. At the front cut the overhang on the corners and fold them inwards. Tape them together to create the nose.
Step 4: Build the Fins
The left over paper is used for the fins. Cut it in halve and fold each of the halves. Then draw your fin design on one of the sides. Now cut all of the at once. The only thing left to do is to glue the fins on the arrow. Put on one top and one on the bottom. Then glue them together. Use some tape to reinforce them.
Step 5: Done
Now you are ready to shoot. Simply hook a rubber band in the notch and grip the arrow at the end.
The rubber bands don´t need to be strong at all. To get more power knot them together and use them as one long one.
To keep in mind:
Be careful where you aim. These arrows can hurt quite a lot.
Never shoot at other people.
    • Jewelry Challenge
      Jewelry Challenge
    • Fat Challenge
      Fat Challenge
    • Pie Contest
      Pie Contest
    6 Discussions
    Italiankiwiblog
    7 weeks ago
    My youngest son would adore making these arrows (and shooting them even more!). We'll have to give it a try!
    Penolopy Bulnick
    2 months ago
    These look like fun!
    It would also be fun to set up some kind of game with hoops or something for people to play against each other :)
    TheP24Penolopy Bulnick
    Reply 2 months ago
    Hi, we use empty water bottles as targets.. works great.
    I actually wanted to enter the paper contest, but it didn´t seem to work. Is it ok do redo it and try again since it can´t be entered after being published?
    Thanks.
    Penolopy BulnickTheP24
    Reply 2 months ago
    You can enter it after it's published as long as you publish within the timeframe of the contest. Just go here and click Enter Now!. If that doesn't work for you, let me know and I'll take care of it :)
