Paper Strandbeest Mk 2
88,735
119
26
About: I like to make inventions, usually out of paper and stuff I have. I have a few projects that i haven't put up on instructables yet...
I made the Paper Strandbeest a while ago(It was my first instructable) And I finally updated it with a real working version! The old one had only 2 leg segments(4 legs total) and it could not walk well. The new one now has 3 leg segments(6 total) and can walk well. The old version is now going to be outdated to this version, but I will keep it up for people who linked to it, it being my first instructable, etc
Anyways, to the instructable!
Supplies:
Step 1: Supplies Needed
You need:
  • Scissors
  • Printer
  • Pliers
  • Wire Cutters
  • Tack or Pin
  • At least 4 big paperclips
  • Thick Paper(The paper used in my other instructables)
Step 2: Print Out the Template
I now made an actual template, not just a scanned image. Print it out twice, in case if you make mistakes.
I have this image here as a filler
Step 3: Glue It On, Then Cut It Out
Get the printed pieces, glue them on the thick paper
Then when they dry, cut them out and glue then again on another piece of thick paper. When that dries cut them out and poke a hole where the template tells it to. I dont have many pictures here because I didnt print it out, my printer broke. Though I have a few pictures of them being glued and cut out, but it doesnt look like the template.
While you're waiting, cut out pieces of paperclips about 1cm long, cut 4 for each leg, 24 total
Step 4: Put the Segments Together
Get the parts for one leg, then using pliers, put a paperclip piece in as shown in the picture 2. Then follow the pictures to make one. Do this step 6 times to get the six legs
Step 5: Make the Axis
Sorry about no pictures of the axis, I had to make the axis as i was putting it all together, so I hope these instructions are sufficient enough.
You should do this at the same time with the next step, or it would be very hard to put together.
Get the extra paperclip, it has to be very long. Bend it so it is straight, then measure about 1cm in and bend at a right angle. Then about at half an inch bend again at a right angle. Bend again at a right angle at about 0.5 an inch in. At half a cm in bend it at a right angle one third foward than the last one. Do the steps again 2 times to get 3 indents,refer to the first picture
Step 6: Put the Segments on the Axis
It is hard to explain, so please refer to the pictures
Step 7: Put It All Together
Print out the template for the top and glue it on the thick paper. cut it out and bend where both of the lines are.Then poke a hole where the little scribbles are(i made it in about 5 minutes, i couldn't find the circle tool)
Step 8: You Are Now Done!
Congratulation if you actually built this!
The first person to make one will get a patch!
Also, I made a video of it, i havent added a motor to it, yet:
  • Fandom Contest
    Fandom Contest
  • Arduino Contest 2019
26 Discussions
dombeefBoss13254
Reply 3 years ago
Its in "Step 2: Print out the template" Its a PDF file that you would have to print out.
AbdulR11
4 years ago on Introduction
Hello, I have been trying to make it myself but I am unable to get the right lengths. Please upload an image of the leg with the lengths of all the linkages.
Thanks in advance.
KyleS5
I made it! I have watched Theo Jansen's videos of his AMMERZIN 20 foot tall creations and even have decided to make a remote control, Arduino version of his massive walker. I might even put an instructable up for it!
Xyiro
5 years ago on Introduction
Hey there...
This is a really awesome post and I really appreciate your hardwork in creating this but it lacks some info. I don't really see the axle properly, along with the insides so i was hoping that you would kindly send me a pic of the axle and the insides.
Thanks.Plz reply soon
This is lovely and amazing. I actually have Jansen's little kit for the mini Strandbeest -- absolutely fascinating.
I was thinking of trying to make a "domesticated" version of one of his beasts, that could be ridden like a bicycle. I got the idea when I watched his TED talk, and he spoke about the legs on these as being a new version of the wheel, and I thought, wouldn't it be something to have a bike with legs instead of wheels? Can you imagine? Incredible. No idea if it would work, or even if I could make it at all...
Again, really cool instructable.
GanhaarMakery Pokery
Reply 6 years ago on Introduction
Have been thinking the same. I thought I would have found a theo jansen project on the web but the closest I came up with was a low walking platform more like a skateboard or scooter put together by some college students. There are also a couple of walking cars that are very slow and noisy. I guess it goes to highlight the skill and artistic ability demonstrated by Theo in developing such elegant strandbeasts.
Never the less, this doesn't mean a walking bike can't be done, so lets get prototyping to make one first.
dombeefGanhaar
I have also seen those a bit after I made this. A walking bike is possible, as long as you dont mind it being wide enough that you can't ride it like a regular bike. What I made here can't walk by itself, it is extremely unstable and doesn't even have any motors to move it. If someone were to try to make a bike shaped strandbeest it would be very hard to ride, it would be fairly slow and hard to balance being that it would be thin. The material would also have to be strong enough,given how thin the legs would be. There also has to be 3 legs(I think?) to have at least 1 point on the ground at any moment , and it would need around 2 to 4 legs to be stable if I thought it out correctly.
I have been extremely busy with school since August, but I have had a few designs that I sketched that would theoretically make this design stable enough with paper and paperclips, it could even walk with a motor attached. But it would still have to be wide, so that skateboard strandbeest you saw is probably your best hope for a portable walking device. You are better off making a segway skateboard, I actually was working on one in march last year, but I took it apart after I almost got it working.
Ganhaardombeef
If you cut the legs out of 10mm thick ali plate and use 1mm thick nylon washers at the joints, 9 layers of material is only 100mm or 4" thick which is reasonable bike width. Can profile cut the parts easily to test. The legs would buckle sideways if they were too long and it won't be light, but would be a reasonable way to test the concept.
The idea wasn't necessarily meant to be practical or that function, but more just to make a walking bike because no-one has one. Segways are pretty rare around my parts, but they're still widely known.
dombeefGanhaar
Hmm, I didn't think of that, but it would possibly work. It would seem stable, but the joining of the parts for a single leg would be difficult, so the joints would be slightly weak if it were to keep the 1 cm margin. Lets also put into account that it would be pedal powered, because a motor for this would die fairly quickly and not follow what Theo Jansen wanted to do, since he made the big ones originally to walk using the wind. If it were pedal powered then the person would have to be high up, because you can't have anything blocking the legs.
Also I looked up for a strandbeest bike, and this is all I could find: http://www.youtube.com/watch?v=iYdtWHvTdm4&feature=player_embedded  I am guessing this isn't what you are looking for?
And I also dont know or see anyone use Segways anywhere in my city, then again I dont see people use strandbeest skateboards here too!
Thanks for commenting, I almost forgot about this project, I finally have some free time and I am starting to draw out plans for a new version that should actually work, it will be based on Theo Jansen's Animaris Rhinoceros beest.
dombeefMakery Pokery
Thanks!
I actually thought about the idea of it as a bicycle, but it would end up being as wide as a car, it would need at least 4 legs per axle to be kinda stable.
Ganhaardombeef
but a bike isn't stable. How many legs do you need to get smooth vertical motion? With 4 legs per axel wouldn't it then be very difficult to turn?
This is amazing and very cool !
One thing that ( IMO) would make it epicly awesome would be if you added a windmill so that this baby could walk in the wind like its big brothers
fail
7 years ago on Introduction
Pure genius! Quite amazing really...
My science class is trying to build a big one like Jansens out of PVC pipe, and its very hard!
Yours looks great though...
Kikketer
This thing looks really cool, I was thinking of using popsicle sticks. It may be a bit tricky to make the triangles, but it may provide the nice sturdy supports and be just as cheap to make!
dombeefhintss
I don't have it with me but if you reply in 30 minutes I will reply with th answer
