Parallel Leg Vise With St. Andrew's Cross
56,430
237
28
  In woodworking and fabricating, a leg vise can be enormously useful.  They offer a large, flat clamping surface on which you can impart a surprising amount of clamping force.  A properly aligned leg vise can hold large workpieces such as doors or 6x6 beams.  But few companies make proper woodworking leg vises or even the hardware for them.  The issue with making a leg vise is keeping the chop (the part that moves) parallel to the bench leg when under tension.  This Instructable features a solution.
  I make all my leg vises at TechShop.
Step 1: St. Andrew's Cross
  On many traditional workbenches the chop is held parallel with a sliding wooden guide which is shot full of holes.  The worker must place a pin in the hole closest to the bench when the vise bottoms-out.  This procedure can get tiresome after a while.
  Another option is to outfit the chop with a steel scissor-action mechanism which will keep it parallel at an infinitely divisible distance.  This mechanism is often identified as St. Peter’s Cross, however this is a misnomer, as St. Peter’s cross is actually an inverted perpendicular cross.  The X-shaped intersection we see here looks more like St. Andrew’s Cross, which is called a saltire and is featured on the national flag of Scotland.  So I’m calling this St. Andrew’s Cross.
  You can learn more about Scotland from the books at your local library.
Step 2: You Will Need:
Materials:
Vise screw and nut
2" x 8" x 32" hardwood (for the chop)
36" of angle iron (8 gauge) or thicker
12" of 5/16" metal bar
5/16" bolt
Various nuts, washers, and spacers to fit
Tools:
Basic woodworking tools (saw, router, chisels, drill)
Basic metalworking tools (metal saw, angle grinder, drill)
Step 3: Making the Cross
I want to make the bars of the cross as long as possible so I'm mounting them just below the screw and having them extend almost to the floor.  On my 32" chop this make the bars 17" long.  I will be using angle irons for this to prevent flexing in any direction.  I milled one side of each down to 1" wide then using a metal bandsaw I cut the other sides to be wider in the middle (1 1/2") and 1" at either end.  Then the holes were drilled, each 5/16".  The bars will be hung from the top and bolted together at the center, the bottoms will float up as the vise is opened and down as it closes.
  The bolt has to hold the two bars together but not under tension.  I am using a stainless steel collar bolt with just the right thickness of washers to hold the bars in place without squeezing them.
  I gave the bars a patina of iron oxide and a clear-coat to prevent rust.  I will lubricate them with sewing machine oil.
Step 4: Prepping the Chop
A channel must be dug in the chop (and the bench leg) to accommodate the cross.  Since the bars are an inch wide, the channels must be 2" wide and 1" deep.  Since the bars will cross each other, there is still space for the extra height in the middle.  I used a router to hog out most of the channel then cleaned it up with a chisel.
  Next the 5/16" through-hole is drilled for the pivot.  I used a Forstner bit and a drill press for this to keep the hole as straight and perpendicular as possible.
Step 5: Prepping the Bench
  Now cut the same hole and channel in the bench leg. The nut will be secured on the inside surface of the leg.  Since I don't have a 2 1/4" Forstner bit, I will be cutting with a 2 1/4" hole saw and hogging-out the waste once it bottoms-out, then repeating the process until I get through the leg.
  It is important that the pins holding each of the bars are at the exact same height.  Here they are placed 12 1/8" on center from the top of the bench.
Step 6: Assembly
  Insert the pins through the leg and the inside bar.  The pins should be tight but not permanent.  The spacers will keep the bars from sliding along the pins.  Make sure it has the necessary freedom of movement in the channel.  The last part to secure should be the bolt at the intersection of the two bars.  At this point the vise is functionally complete.
  In fig. 2  you can see it holding a large block of wood at the top edge while remaining parallel.
  If your chop experiences any raking, despite all parts being true, you can place a strip of sheet metal in the bottom of one or both of the channels.  This will widen the bottom half of the assembly and should compensate for raking that occurs under pressure.  It's okay for the chop to be out of parallel when not clamping, but slight raking while being clamped will cause a noticeable decrease in holding power as there will be only an edge of contact with the work piece on one side.
  • Epilog X Contest
    Epilog X Contest
  • Trash to Treasure
    Trash to Treasure
  • Pocket Sized Contest
28 Discussions
ringai
6 years ago on Introduction
Back in the first decades of the 20th century, this is the sort of project that would appear in Popular Mechanics. In fact, they featured a similar build that used flat stock instead of the angle iron. I think the angle iron is a better choice.
I you'd like to find some really awesome DIY woodshop projects, you could do worse than to go back to the those old issue (via google books) and peruse the freaking awesome tips and projects.
Another excellent source of shop projects are the old Fine Woodworking magazines. They had DIY projects such as a shop-built 8-inch jointer. FWW doesn't have many of those sorts of articles anymore. For that you need to pick up ShopNotes magazine.
Shop-Built machiery is not for the faint of heart, nor is it the path for every wood worker. But man, if it trips you trigger to be able to show off a DIY bench tool, then ShopNotes is your guide.
Edgar
A note about it went to my Blog:
http://faz-voce-mesmo.blogspot.pt/2012/12/lagartas-de-robot-tele-seminarios.html
Edgar
Naugas
2 years ago
Very interesting mechanism. I must admit I don't really understand why it works, and doesn't fold/collapse when you apply pressure... I instinctively think the friction at the loose ends at the bottom of the cross is important - I guess it wouldn't work with rollers there? Does it work inverted, with the pivots at the bottom instead - it seems like that would take up any slack in the joints and assembly? I guess I have to make one for myself to see what's happening here...
tonyiNaugas
Reply 3 months ago
The steel cross assists with spreading of the base when opened and stops the vice leg getting twisted, thus keeping the vice let vertical ... but this also depends on how much play or slop you have in the over all mechanics which will have an effect on the efficiency of the system. Too much play may stop the cross bar spreader functioning and having the desired spreading effect it is meant to have.
There is nothing stopping you fitting wheels to the bottom of the cross legs and placing a 2mm steel bar / plate inside the channels to stop excessive wear on the wood. you just need to take into consideration the extra space it will take up and cut the channels to suit.
tytowerNaugas
Reply 2 years ago
Mate the force on the top of the legs from the screw holds the bottom out
tonyi
3 months ago on Step 5
Great Instructable, & thanks for sharing.
i too at first did not fully understand the mechanics of the cross bars. So as an exercise to myself i CAD'ed it up with full articulated joints and now i 100% "get it" & it's a great idea, no stuffing about with manual variable holes in a base spreading plank of wood.
The steel cross assists with spreading of the base when opened and stops the vice leg getting twisted, thus keeping the vice leg vertical ... but this also depends on how much play or slop you have in the over all mechanics which will have an effect on the efficiency of the system. Too much play may stop the cross bar spreader functioning and having the desired spreading effect it is meant to have.
There is nothing stopping you fitting wheels to the bottom of the cross legs and placing a 2mm steel bar / plate inside the channels to stop excessive wear on the wood, you just need to take into consideration the extra space it will take up and cut the channels to suit.
cosmicdobber
2 years ago
Hi I know this is a older post about the leg vise. I have a question, my bench has aprons, Paul Seller type. Would this system still work having a gap between the leg and chop as the the apron thickness will be the differnce?
I was thinking I could build the leg up to match if it was necessary.
Naugas
2 years ago
OK, suddenly realized that the cross just restricts the twisting/bending of the clamp/chop, it doesn't act anything like a solid support. Friction at the cross' ends has nothing to do with how it works.
Naugas
2 years ago
Hmm... I can't see my comment I just made a few seconds ago. I just wanted to add a link with some nice comments about the forces involved:
http://www.popularwoodworking.com/woodworking-blogs/chris-schwarz-blog/st-peter%E2%80%99s-cross-and-the-ultimate-leg-vise
It doesn't answer my questions, but it's still interesting. It was a long time ago I draw any free body diagrams as mentioned in one post, but maybe this would be a good opportunity to refresh that knowledge.
Yonatan24
3 years ago
I have a question about Step #5:
Why does the dust bother the hole saw when drilling?
ScotttlandYonatan24
Reply 3 years ago
It will clog the teeth, a hole saw doesn't have a way to remove the wasted wood so it can clog, bind, and burn the wood. If you can't drill relief holes then you need to make shallow pecks with the saw and back-out regularly to allow the sawdust to clear.
Yonatan24Scotttland
Reply 3 years ago
So that's why it was hard to drill...
Thank you so much!
raymondvillain
4 years ago on Step 3
Thanks for the posting, great advice! But how does one give "...a patina of iron oxide..."? Vinegar and salt? Is there a link that will explain the details?
mrmjspencer
4 years ago
would this work if mounted up side down to support the bottom preventing pinchining?
monty324
5 years ago on Introduction
if you also have the bar in the bottom with all the holes in, it can support the chop and allow it to slide more freely. that probbly diddent make much sense so heres a picture of what i mean http://benchcrafted.com/Graphics/Vises/Vises_2012/LV_bench_side.jpg
When i was getting this picture i found that benchcrafted also make a cross vice now.
12mile
after i look at project cant back up to main paige?
vincent7520
Great idea.
But I guess I'm dumb as I don't see how the two bottom ends of the cross slide in their respective channel ? Or the top assembly is enough to keep them in line and in each channel ? I would have thought the whole thing would be somewhat wobbly if not attached to a rail they could slide in.
Nice inst' anyway : we learn a lot both about this system and tricks about making holes etc …
Better than going to the movies on a rainy day, and shorter too ;))
Thanks !
