Photo Transfer on Wood
16,651
372
14
an esy way...
Supplies:
Step 1: Material - Matériel
you will need:
-a piece of wood (not treated)
-wood glue
-a brush
-a laser printed mirored photo
Vous aurez besoin de:
- morceau de bois non traité
-colle à bois
-pinceau
-photo imprimé sur papier standar et de façon inversé
Step 2: Collage
mix half portion glue with half portion water, use the brush to put de mixture on the wood then place the photo face dowm ( nake sure the paper is glued correctly to the wood with no bubbles).
wait till the whole dry.
coller la photo côté recto sur le bois grâce a la mixture moitié colle moitié eau. s'assurer de ne laisser aucune bulle. laisser le tous sécher.
Step 3: Décollage
use a wet sponge to humidify the paper then use it to rub the up layer.
utiser une éponge pour humidifier le papier puis pour enlever la couche supérieure.
Step 4: Fin
let dry, then sandpaper the image a little.
use a brush or a sponge to put a layet of linseed oil on the surface. let dry then put a varnish layer.
YOU R DONE.
laisser sécher, passer un coup de papier de verre fin.
passer une couche d huille de lin, laisser sécher puis vernir.
VOILÀ
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    14 Discussions
    darkreeves
    2 years ago
    I tried this and ended up getting super frustrated. I found this company online called plakthat.com that did a much better job.
    interpretingbylydie
    3 years ago
    Good evening
    We enjoy doing photo transfer
    If you need help on your project, please look at our new website
    We will be really happy to help you
    Please have a look on the projects we have done
    http://interpretingbylydie.weebly.com
    Best regards
    jelte1234meanhorn1125
    Reply 4 years ago on Introduction
    Hi, I think the author is trying to say that inkjet ink will run, making the image fuzzy/unclear. (that's what I gathered from similar instructables, atleast)
    So depending on the type of image and intended result it might work, but laser printed is definitely better.
    cowboyathomejelte1234
    Reply 3 years ago
    Inkjet printers use liquid ink sprayed through microscopic nozzles onto the paper and absorbed by the paper. Laser printers use a toner cartridge (filled with fine powder) and a heated fuser which fuses the toner to the paper (not absorbed).
    nemo13meanhorn1125
    Hi, it has to be a laser, 'cause the ink of the inkjets can easily spread away (not sure how to tell it)
    TheCrafsMan
    3 years ago
    This is a good technique. I wanted to mention another material that people don't seem to be aware of - Acrylic wood finish. (aka "polycrylic", "water-soluble poly", etc.) It's basically the same technique as above, but the acrylic finish may allow for cleaner results.
    Interresting idea. I need to dust off our old laser printer, I already have some ideas... Thanks for sharing.
    nemo13
    5 years ago
    thanks & merci
    Emoth
    5 years ago
    merci pour la version bi-langue
    Vincent619
    5 years ago on Introduction
    this looks a lot like this instructable but the sponge idea is a lot better than using your own finger, love the work!
