Piezoelectric Generator
25,599
123
27
hello frnd,
i come with new attractive ,easy and smart power generation idea which is useful for your smart project and give new way of creation .
piezo electric power generation which is fully depend on applying pressure on piezo transducer,
Step 1: Collect Wooden Plywood As U Want to Make in Your Size
cut as per images .
Step 2: Buy Piezo Electric Buzzer at 20 Rs Per Pic and Modify As Image and Get Piezo Transducer
s
Step 3: Draw Square Box to Attach Use Box As Per Show Images,,, Buzzer Upper Parts Use for Making Top Part to Press
Step 4: Make Series Connection of Piezo Transducer
Step 5: Finally Glue or (use Plastic Tap )on Series Connection on Down Part As Shown Image
Step 6: Start to Generate Electricity by Applying Finger Pressure ,,,
Step 7: Generate Electricity While Walking Homemade
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    • Party Challenge
      Party Challenge
    27 Discussions
    pavangowda01998
    Question 23 days ago
    I need to know how to make an power generator by foot steps And i need more brief explanation about project
    medinashuriyeva
    10 months ago
    Hi! My team has a project which needs this, and we were very happy to find your post! THANK you, by the way! BUT our project is focused on generating the electro energy from the mechanic, and we hope the Piezo will have a role of the "thing" that would accept the kinetic energy that is released after pushing a pressure on it. Is it so? Or is it just a kind of button? THANK YOU!!!
    Modern Da VinciVANDANAR8
    Answer 12 months ago
    Connect them to a breadboard, make a rectifier bridge (using diodes), add a 25v capacitor, and it becomes DC. easier to work with and measure.
    https://youtu.be/6_-n_DSJNFk?list=PL8PXGEvouIcx-wIh1S-qO2SrMwKiTOQZv
    niravpatele63VANDANAR8
    Answer 1 year ago
    I dont know, but you can check voltage when you pressure that show how much voltage can be generated , thanks
    RishabhP19
    2 years ago
    from where I can buy piezoelectric disc at 20rs per piece...
    niravpatele63RishabhP19
    Reply 1 year ago
    i took it out from buzzer . as per buzzer price it was consider .
    rah187
    3 years ago
    Hello, I have a question concerning the piezoelectric devices used in this project. As it turns out I will be needing a piezoelectric generator circuit. The idea is that the piezos will charge moderately large capacitors which will then be dumped into a battery with some extra timing circuitry. However, I have not developed a circuit yet because the rochelle salt crystals I tried to grow were unsuccessful. So, instead of wasting my time, I went to Amazon and bought some piezoelectric elements marketed as guitar pickups/drum triggers. Will these work?
    niravpatele63rah187
    Reply 1 year ago
    sorry ,i never used piezoelectric elements from things that u considered . i got piezo elements from buzzer . but that should be worked ..
    preetham sudhansh
    2 years ago
    Hello Nirav Patele. This is Preetham...I want an indetail information about this Project...I want to make this Project...Please send me information...My email: preethamsudhansh@gmail.com....Please send me indetail info about this...Please..It's a request...
    JOYDEEP_07
    2 years ago
    Sir as I can see there is three wire one is connected to feedback part another connected to metal part and last one is connected beside the feedback part . So at the end we can see two wires make connection finally but third one is still unconnected...so why we are using the third wire which is beside the feedback path.??
    DiedreR1
    Reply 2 years ago
    I'd love to know how they built that nightclub that is powered completely by peizoelectric panels on the dancefloor works then.
    it is possible as I've seen various successful projects. But I have no idea of the circuitry.
    id like to adapt something for charging lithiums.
    Moira Atropos
    3 years ago
    n Spain there is a small company that manufactures electric generators obelisk-shaped piezoelectric operating with a base and the movement of wind, thus avoiding the huge blades of the wind turbines that threaten the birds' migration routes. a larger obelisk captures more wind and produce more energy. for now they are struggling to break through against traditional energy production system and the pro-establishment
    Left-field Designs
    Reply 3 years ago
    not strictly true, you can use the small pulses of current to charge a capacitor,with the correct circuitry you can them 'dump' the capacitors held charge to the battery. I have used similar technology in devices with solar panels where the sunlight is not reliable but there is power to be scavenged
    Chitlange Sahas
    Reply 3 years ago
    I agree. I had tried this a year ago to charge a cellphone battery, they dont work.
    Courrent is less than 1 mA for 6 piezo in parallel.
    But though Nice instructable.
