Pixel Trash Can
72,240
322
88
About: Hi, my name is Britt Michelsen, I'm a Chemical Engineer especially interested in Computational Fluid Dynamics. To balance all the theoretical work I like to make stuff in my free time.
From the second I saw this paper pixel trash can I fell in love with it and I knew that I wanted to make a real life model.
I love working with wood, because I grew up on a lumber yard and now that I'm living in a city I really miss the smell of it. Piece by piece I am equipping my cellar room, so that I'm able to make what ever I like.
Step 1: Material and Tools
material
  • wood 1.5 cm thick (I've used plywood because it was easier for me to get)
  • paint (3 different types of gray)
  • wood filler (putty knife)
  • wood glue
  • primer
  • masking tape
  • screws (20 mm long)
tools
  • circular saw bench
  • scroll saw
  • belt sander
  • drill
  • ruler
  • paint brush
  • clamps
  • protection: working gloves, safety glasses, ear protection
Step 2: Sawing
You can of course build the trash can entirely out of wooden blocks, but I wouldn't suggest it, considering the work to cut them.
Make sure, that you now what you are doing and don't hurt yourself!
The first picture (higher resolution) shows the template of the pieces you will have to saw. I made them by cutting rectangles, marking the corners with a pencil and cutting them out with a scroll saw.
In order to saw the lid and bottom I drew a grid on the wood, as shown in the fifth picture.
Step 3: Filling and Priming
Now you will have to sand all the pieces. If you are working with plywood you should use a wood filler, to fill the holes.
Priming is important when you are working either with MDF or plywood, because the edges won't take a good and even coat of paint. In order to get a good result you should prime the wood more than once and sand in between the layers.
Step 4: Painting
In the pictures you can see how I've painted my trash can. Those are of course only suggestions, if you don't like them, just paint it however you would like it to look like. Don't make it to complicated though, because it takes some time to paint all the pieces.
Masking tape helps a lot in order to get nice straight lines.
Step 5: Assembling
Picture one shows the basics of the assembly for one side. The light blue areas mark the surfaces on which we apply glue.
I've assembled one side at a time and then glued all the sides together. To support the bond between the pieces I used screws and later covered the holes with wood filler. In the end add the bottom and if it's necessary support it with screws.
Congratulations, you are done!
    • Gardening Contest
      Gardening Contest
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    88 Discussions
    BrittLiveulaliaaaa!
    Hi, jep ich spreche Deutsch (Ich hatte Englisch, Französisch und Latein in der Schule), spreche Spanisch, da ich ein Jahr in Chile gelebt habe und lerne gerade Schwedisch in der Uni...
    und du?
    techturtle2BrittLiv
    Linguam latinam disco, discivi multum! sum solus puer qui linquam amo! ridiculus, vero ita?
    quoque tubam sono. nunc sum otiosi quod pensam non habeo, sed est ad me venint!
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
    Te sun să-ți spun ce simt acum, Alo, iubirea mea, sunt eu, fericirea.
    Alo, alo, sunt iarăși eu, Picasso, Ți-am dat bip, și sunt voinic Dar să știi nu-ți cer nimic.
    Vrei să pleci, dar nu mă, nu mă iei, Nu mă, nu mă iei, Nu mă, nu mă, nu mă iei, Chipul tău și dragostea din tei Mi-amintesc de ochii tăi.
    BrittLivtechturtle2
    To be honest I never quite liked Latin, I prefer to learn languages that I can use to talk to people, I can understand what you wrote, but I don't remember enough to answer...
    dehlomeBrittLiv
    Wer kennt sie nicht Deutsch sprechen?! Ich spreche auch Russisch, Englisch, Latein, Niederländisch und ein wenig Spanisch. Wir alle sind begabt! Ja!
    diabetisheaddehlome
    Ich spreche auch english spanish und franzoesisch.Also koennte man die muelltonne eigendlich auch stabieler bauen?
    dehlomeBrittLiv
    Große instructable Menschen. Als ich das Bild sah, dachte ich, dass es ein Pixelbild war. Beeindruckend.
    scistonedehlome
    Thats scary how many people know different languages. Too bad I only know english. :(
    kilbia
    6 years ago on Introduction
    Ohhhhh golly. This is adorable. I've been inspired. Thank you! =)
