Plastic Sheet Out of PVC Pipes
9,947
167
6
About: I am a student in graduate engineering school of computer science and electronics
In this instructable, I'll show you how to make plastic plates, from PVC pipes!
You 'll need:
-a PVC Pipe
-an Angle Grinder
-a pair of protecting Gloves, Glasses and a mask
-a Heatgun
-a piece of wood , plywood or any flat surface
Supplies:
Step 1: Chose Your PVC Pipe
First, you need to choose your pvc pipe! The length of the pipe will be the length of the plate. For the width, you need to use the formula P = 2πR
For exemple, this pipe has a 32 mm diameter.
So the width will be 2*3.14*16=10 cm
Step 2: Cut the Pipe in Lengthwise
To cut it, I used an angle grinder, but use what you want or is used to.
You have to cut it as strait as possible!
Step 3: Heat the Pipe
So, first, you need to take your gloves glasses and mask!
You'll need to heat the pipe from one side to the other, streching the pipe with your gloved hand, like in the picture 3.
To make the PVC pliable, you'll need to heat for about a minute or two, it depands on the thickness.
Next, you will need to start over , but by flattening it with the plywood (picture 4 and 5).
Repeat the process until you are happy with your flattened pipe!
Step 4: The Uses
So I made this so I can use this cheap plastic to repair and create things.
I made a new handle for a bin, and I created a hook for my shelf.
If you need to bend the plastic, just a little bit, you dont have to take your heatgun, a lighter can do the trick. Just heat the area you need to bend, for about a minute, and bend it the way you want. It depands on the thickness of the pipe!
I hope this instuctable have been helpfull. If you have any question, dont hesitate.
2 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • IoT Challenge
    IoT Challenge
  • Party Challenge
    Party Challenge
6 Discussions
mcmaster_17
3 years ago
this is sick i made trampoline practice skis out of a pvc tube
fred3655
3 years ago
Good for roofing tile, siding, window shutters. I used a flattened sheet with some strong glue to fix a rust hole in a truck door. Just coat with bondo and sand/paint.
BrettHacks
3 years ago on Introduction
Neat idea! I've needed small pieces of plastic in the past and had to resort to cutting up the wife's Tupperware. This would work better and keep me out of the dog house. Thanks.
Mindmapper1
3 years ago
The only mask which will give you protection is one with a carbon filter. It is not a good idea to use a flame to soften plastic it is much safer to use indirect heating. See my instructable on how to make a strip or line bender.
ExempledenomFelixC
Reply 3 years ago
Thank you for your feedback! I forgot to mention the use of a mask, I'll add it!
