Porthole Sign
14,025
225
24
About: Ex: Business Analyst, IT Manager, Terminal Manager, Shipping Key Worker, Stevedore, Production Manager, Farmhouse Inspector, HGV Mechanic, Rivercraft Mate, Bread Salesman, Van Salesman. Now retired working m...
The eldest son asked me to make a sign for his newly completed garden bar and barby area. As he is an ex sailor I decided to make him a themed sign. I decided to try and make a porthole type sign with a sea scene in it.
The internet provided many suitable pictures and I finaly decided on this victorian brass one as a model.
Step 1: Good Idea But How to Do It
I tried a few ideas using metal but finally decided on plywood as I intended to paint it with brass paint and it didn’t need to be functional only decorative.
After cutting a few plywood circles I realised I needed to make a circle cutting jig for my bandsaw which I have put up as a separate instructable. just using a jigsaw freehand did not produce very good circles.
Using the photo as a ratio guide I made the two main pieces. these start off fairly rough as the ply isnt furniture grade but it will be painted anyway. I realised that the bottom one could be just a circle and the top one a ring. I cut the ring on the bandsaw and then pinned and glued it together where the blade had entered and exited the center circle.
Step 2: Plywood Pieces and Positioning
I made the hinge pieces and locking tabs from furniture grade plywood for strength, then glued and pinned them together. I used wooden pegs to locate the front to the back so that the picture could be removed or replaced. Its essntialy two pieces screwed together from the back.
Step 3: Construction
after trying metal bolts and eyebolts I decided to just make the locating screws out of wood also.
When pinned and glued they are quite sturdy. The tightening pins are wooden dowels. the main pins are 20mm dowelling and go into the back piece without glue so they can locate the front piece but be taken apart to access the picture. the hinge assembly is also located this way but using dowel pins.
Step 4: Finish Off
when glued and pinned up it started to look ok.
with computer printed graphic and some 20mm chrome upholstery studs as rivets it came out ok.
The finish was a spray can of brass paint two coats. It could have been done with a much better finish if better plywood had been used but I used all scrap stuff including the perspex. I also cut the perspex on my circle cutting jig.
  • Pocket Sized Contest
  • Weaving Challenge
    Weaving Challenge
  • Trash to Treasure
    Trash to Treasure
24 Discussions
jeanmarie2601
1 year ago
Bonjour,
J'aimerai le faire, pouvez-vous me dire comment je peux faire pour avoir le fichier PDF, SVP,
Je n'y arrive pas
MERCI
theoblackadderjeanmarie2601
Reply 1 year ago
Bonjour, j’ai n’a pas fait un PDF ou des plans pour ce projet Désolé. Je vous remercie pour vos commentaires. Bonne chance
Keith
jeanmarie2601theoblackadder
Reply 1 year ago
Ok Merci.
je vais essayer de le faire.
si je réussi je vous met des photos.
------------ traduction google -----------
Ok Thank you.
I will try to do it.
If I succeed I will put you pictures.
PlaidPete
2 years ago
Thanks man! I made some modifications to make it more like the titanic and it looks great! Thanks for the idea!
16, 1:45 PM.jpg
TangskiPlaidPete
Reply 2 years ago
nice job buddy! Looks great! I would love t9 see this idea turned into a stain glass window too!
cflett
2 years ago
Great job. I may make one for a small sailboat.
Tangski
2 years ago
This is great and can also be used for a set, text on outside, picture on inside (open the door)....very cool! THANKS!
tscott222
2 years ago
I saw something like this once with a flat screen behind, playing a loop of ocean waves as seen through a porthole!
theoblackaddertscott222
Reply 2 years ago
That sounds cool! - as long as you don't get sea sick watching it! ?
theoblackadder
2 years ago
hey love it! Have you done an Instructables for it? Looks great. I was going to use a metal toilet seat hinge as they could be modded quite easily and it would then be able to open.
theoblackadderthongn7
Reply 2 years ago
You're welcome- and thanks a lot for your kind comments.
Erika021084
2 years ago
Thank you so much!!! I love making them things!!
Erika021084
2 years ago
That's awesome, really is incredible good job!! And I know what u mean with kids no matter what age they're always our babies!
theoblackadderErika021084
Reply 2 years ago
Thanks again I really like the stuff you've made for your kids too ??
