Pov Spinner
6,035
76
6
So i was thinking: let's make something obvious.
This instructable is on making a spinner with a persistence of vision illusion inside.
Supplies:
Step 1: Parts and Wiring
  • ATtiny 45 ic
  • 5 smd led (1206)
  • 5 smd resistor (47 Ohm)
  • 2 small pieces of pcb
  • 1 coin battery (3v - 16mm)
  • 8 pieces of metal (for balance)
  • a piece of mdf (3mm) for the spinner itself
  • a 22mm metal ball-bearing (center)
The wiring is pretty straight forward. I followed the datasheet from Atmel (see screenshot above)
  1. The positive pins on the led go to PB0 - PB4 on the ic. I added a resistor in between.
  2. negative pins go to GND.
  3. Power the ic by connecting the battery to VCC and GND.
Step 2: Programming the Ic
In order to put code on the Attiny we need to follow a few steps:
  1. Upload the 'ArduinoISP' example to the Arduino board ( located in the examples folder)
  2. In Arduino preferences point to https://raw.githubusercontent.com/damellis/attiny... or look for attiny library (by David A. Mellis) and install it
  3. In Tools> programmer select the ‘Arduino as ISP’ option
  4. Attiny 45 runs on 1 Mhz but can be changed under ’Tools’. That's a bit to slow for persistence of vision: change it to 16 Mhz (normal clock on a regular Arduino)
  5. If you do the previous step you have to burn the boot loader. (Tools > burn bootloader)
  6. wire the Attiny to the Arduino board (see this page for the exact wiring or look at screenshot above). You also need a 10 uF capacitor between reset and ground to avoid reset (and starting the bootloader)
  7. upload the code below to the attiny.
  8. done.
arduino / attiny code from the spinner:
<p>int letterSpace;<br>int dotTime;</p>byte invader[] = {1, 1, 1, 0, 0, 0, 0, 1, 1, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 0, 1, 1, 1, 1, 1, 1, 1, 0, 1, 1, 1, 1, 0, 1, 0, 1, 1, 1, 1, 1, 1, 1, 0, 0, 1, 1, 1, 1, 0, 0, 1, 1, 0, 1, 1, 1, 0, 0};
byte invader2[] = {0, 0, 1, 1, 1, 0, 0, 1, 0, 0, 0, 1, 1, 0, 1, 1, 1, 1, 1, 0, 1, 0, 1, 1, 0, 1, 1, 1, 1, 0, 1, 1, 1, 1, 0, 1, 0, 1, 1, 0, 1, 1, 1, 1, 0, 0, 1, 1, 0, 1, 0, 0, 1, 0, 0, 0, 0, 1, 1, 1};
int amount = 12;
void setup()
  // setting the ports of the leds to OUTPUT
  pinMode(0, OUTPUT);
  pinMode(1, OUTPUT);
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  letterSpace = 2;
  dotTime = 1;<br>}<br>
void printImage(byte pix[]){
int y, i;
// image
for (i = 0; i < amount; i++) {
	for (y = 0; y < 5; y++) {
		digitalWrite(y, pix[y + (i * 5)]);
	delay(dotTime);
// space between images
	digitalWrite(y, 0);
delay(letterSpace);
void loop(){
	printImage(invader);
	printImage(invader2);
Step 3: Simple Spinner Images
create images
The spinner needs an image to display so i've made a small browser page to create sequences / images for the spinner. (attached as file)
It has an interface of multiple input tags (type: checkbox) and two functions: one to create a new column and one to create the sequence of 0 and 1.
My son (6) had a good time making some invader like sequences.
js:
var start = 8; // start with 8 columns
// a function to create a column of inputs. i have 5 led in the spinner..
function makeColumn() {
  var box = document.createElement("div");
  box.id = "col"; // check css for styling.
  for (var i = 0; i < 5; i++) {
      var input = document.createElement("input");
      input.type = "checkbox";
      box.appendChild(input);
  document.body.appendChild(box);
// function attached to load event. Creates the buttons and the columns based on the amount stored in start variable
function create() {
  var b = document.createElement("button");
  b.innerHTML = "create";
  b.addEventListener('click', generate);
  document.body.appendChild(b);
  var b2 = document.createElement("button");
  b2.innerHTML = "add row";
  b2.addEventListener('click', addNew); // event for adding a new column
  document.body.appendChild(b2);
  var input = document.createElement("p");
  input.id = "result";
  document.body.appendChild(input);
  for (var i = 0; i < start; i++) {
      makeColumn();
// adds a new column
function addNew() {
   makeColumn();
   start++;
// function to generate the sequence of 0 and 1
function generate() {
   var inputs = document.querySelectorAll("input");
   var result = [];
   for (var i = 0; i < inputs.length; i++) {
       var r = inputs[i].checked ? 1 : 0;
       result.push(r);
   var pusher = document.querySelector("#result");
   pusher.innerHTML = result;
// start everything when page is loaded.
window.addEventListener('DOMContentLoaded', create);
css:
#col {
   display: inline-block;
input {
   display: block;
   -webkit-appearance: none;
   width: 20px;
   height: 20px;
   background: black;
   margin: 1px 1px 0;
input:checked {
    background: yellow;
The spinner itself was made with NodeBox 3 - an interesting tool for design. The svg output is included.
5 People Made This Project!
  • IoT Challenge
    IoT Challenge
  • Woodworking Contest
    Woodworking Contest
  • Classroom Science Contest
6 Discussions
kukulcangod
1 year ago
Have you patent it? Because you would loose the right by publically posting it..Shame because this is would be fascinating, too much for the uninformed buyer.
lievn_mkukulcangod
Reply 1 year ago
i'm out of luck then, it seems to be too late already :)
anyway: pov is not really new, i can't be held responsible for inventing the illusion, let alone patent it..
deluges
1 year ago
Thats pretty cool! Although I still don't undertand the spinner trend which I guess makes me an old fart :(
lievn_mdeluges
Reply 1 year ago
i wouldn't worry about it, it don't really get the trend either but when my son came home with one it seemed like an ideal construction for a funny pov experiment
