Print Flexible Filament With Creality CR-10
14,588
35
Hello to all, in this article we will see how to change the 3D printer CrealityCR-10 to print flexible filaments without any problem.
As many know the CrealityCR-10 has an extrusion mechanism BOWDEN, ie the wire is pushed through a tube in PTFE until you get inside the extruder.
The BOWDEN Extruder on CR-10 is often not very functional in the printing of flexible materials, but with the appropriate changes, everything is possible.
The amendment in question was published by Joshvv on Thingiverse.com
Step 1: Slice and Print
Once downloaded the file STL we need to Slice it.
Printing Parameters:
Filament: PETG by Rigid.ink Black
Layer height: 0.2mm
Infill: 100% Linear
Speed: 60mm/s
Slicer: S3D Chris Elkins Profile
Step 2: Assembles the Pieces
After printing the mod , insert a piece of tube in PTFE within the piece as in the figure.
At this point we are ready to replace the original piece, first of all we will have to unscrew the old bowden and then insert the just printed reconnecting the piece where reside the spring and bearing.
After that we are ready to test the new bowden for the test I used a filament TPU of FILOALFA
Step 3: Test
Already at the first attempt the results were good , the CR-10 printed without any problem and without ever jamming.
Below I leave you with a photo of the press over.
Here is a video summary of the changes.
More info: www.alessiobigini.it
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    3 Discussions
    IvanD134
    4 months ago
    I printed a remix of this part that is reinforced, but I also modified the bowden extruder to an "almost" direct one - check this video
    and this one
    Flex now prints great on the CR-10 with speeds up to 60 mm/s (40 mm/s is best).
    EddyS28
    Question 1 year ago on Step 2
    Hi,
    No prob with other filament with this mod ?
    Can we imagine drill the hole of original part for put in it the ptfe do the same result?
    tks :)
    snabderogon
    1 year ago
    Where is the download link?
