Protecting Phone Cable Using Craft/Fun Wire
1,374
17
About: A computer science engineer who is interested in providing hardware/software solutions for everyday challenges. Most parts of my day are filled with imagining unique innovative solutions for some regular pro...
Protecting Lightning cable using Plastic covered Fun/Craft cable
  • Now, the binding wire won't repair or fix non-functioning old cables, but it will help keep your new cable in condition
  • Helps if the damage to your cables isn’t too severe (i.e. lightning cable is functioning)
  • Adequately flexible to prevent from further breaks
  • Rigid enough to hold the cable straight
  • Plastic coated binding wire is covered with plastic hence softer at the ends with no sharp edges popping out
Supplies:
Step 1: What We Need?
  1. iPhone Lightning cable
  2. Plastic coated Craft/Fun/Binding Wire
  3. Glue Gun (optional)
Step 2: Unwind the Twists and Bends
Step 3: Wind the Binding Wire Around the Cable
  • Make sure there are no gaps between each winding
  • Make sure the winding is not overlapping
  • The winding should not be too tight, as it increase the tension on the elasticity of the Lightning cable
  • The winding should not be too loose, as it won't be able to provide the support to the cable
  • After winding the binding wire, rotate the binding wire coil to tighten or loosen the coil
Optional
  • Stick some glue at the ends of the binding wire after winding it around the lightning cable (The glue I used was soft, giving it more flexibility)
Existing work
  1. Using Springs
  2. Using Springs
Thank you for your time!
    • Classroom Science Contest
    • Gardening Contest
      Gardening Contest
    2 Discussions
    Thank you!
    You may also use a different gauge of binding wire depending on the thickness of the cable.
