Pyro Glove/ Wrist Mounted Flamethrower
74,159
833
73
For this instructable I am going to teach you how to make a Pyro glove/wrist mounted flamethrower. It is very simple and super fun to use. I got the idea to make this from Pyro/John from X-men the last stand. I this will not make it possible for you to manipulate fire it just throw it. Warning this instructable deals with high voltage electricity and fire, and I can't be held responsible for any destroyed property or if you hurt yourself or anyone else in the process of making or using to device. So now that we got that take care of let's get started.
Supplies:
Step 1: What You Need...
1. Butane refills (I used 18 ml. canisters)
2. Fuel line
3. A glove
4. Some thick string
5. A straight metal bracket
6. Some stiff wire
7. Something that can hold the butane canister (I used an old pocket knife holster)
8. A small piece of tube.
9. A metal nut (like a nut and bolt not like a peanut) it needs to be big enough that the piece of tube can fit inside the hole.
10. Some cardboard(you can use a wrist brace in place of the glove and cardboard).
11. A few bracelets or some thin rope
The next few things are optional you only need them if you want to make the igniting mechanism (I would suggest that you just use a Bic lighter because the igniting mechanism doesn't work well)
12. An electric flyswatter
13. Some electrical wire
14. A wire connector
Step 2: Tools...
1. Hot Glue Sticks/Hot Glue Gun
2.Solder/Soldering Iron (Optional)
3. Multi Tool
4. Drill
Step 3: The Glove.....
The first thing you need to do it get your glove. You are going to want to cut a hole in the center of your palm (Tip: I always burn the edges when I make a cut in the glove.). Now, set the glove aside and take your fuel line, the small piece of tube, and the metal nut. Take the plastic tube and use hot glue to close off the one end. Now drill a hole in the side of the small tube just big enough for the fuel line to fit in. Stick the tip of the fuel line into the hole that we just drilled and use hot glue to hold it in place. Now, take you metal nut and glue it on the open end of the plastic tube. Now, put all the stuff that you just glued together into the glove and push the nut through the hole you cut in the palm. When you look at the glove, all you should see is the nut sticking through. (Optional: You can use a needle and thread to hold it firmly in place.) Put hot glue around the nut on the outside of the glove to prevent the nut from falling over in mid use. Now, set the glove aside.
Step 4: The Butane Canister Holder...
In this step you will need to cut piece of cardboard the appropriate size for your forearm. We are going to be using the cardboard to mount the Butane canister on your arm. In this step, you may have to improvise with the materials. I used an old pocket knife holster. But, you can use zip-ties or anything you have lying around that will hold the Butane canister tightly in place. If you are using zip-ties, you will want to cut slits on one side for the straps to go through. (Refer to pictures for more details.)
Step 5: The Butane Releasing Device...
For this step you will need the stiff wire, thick string, and the straight metal bracket. Use the stiff wire to make two loops that can fit loosely over your fingers. Now take the straight metal bracket and drill a hole in the center of the bracket just big enough to fit the tip of the nozzle of the Butane canister. Then drill two more holes on the straight metal bracket on each side. Those holes just have to be big enough to put the thick string through it. Take your thick string and cut two pieces the length of your finger tips to your elbow. Tie one to one of the stiff wire loops you made and tie the other string to the second loop. Take the cardboard with the butane canister in its holder and stick the straight metal bracket over the nozzle with the hole you made earlier. Then, secure it firmly on your arm at the appropriate place. Then, take the two loops with the string tied to them and place them over your middle and index fingers. Put the stings firmly down to the straight metal bracket that is placed over the butane canister and tie them tightly in the hole that you made on the sides. It is important the you have your hand flat while measuring this distance.
Step 6: The Igniting Device (the Optional Step) ...
This step deals with high voltage electricity so be careful!!! This stepis optional, in place of the igniting device you can use a lighter it is much smaller and easier to use. But just in case you want to make it here are the instructions. The first thing you need to do is pull out the batteries (if you are using rechargeable one and you can't pull the batteries then just be extra careful because you can give yourself a nasty shock) You need to do is take the electric fly swatter, unscrew all of the exterior screws. When all of the screws are out pull off the outer plastic casing (be really careful what you touch to make sure you don't shock yourself). When the plastic casing is off the part that zaps the bugs should be connected to the circuit board by three wires, cut the wires in such a way that there is as much wire left attached to the circuit board as possible. Two of the wires attached to the circuit board lead to the same solder point cut off ONE of them. Now solder the remaining two wires to the two leads of the female piece of the wire connector(you don't need to use a wire connector but it makes it easier to put on and take off). Now take the stiff wire bend them into two L shapes. Now take the L shaped wires and glue them to the side of the nut that is attached to the glove (make sure the wires don't touch the nut). Make sure the ends of the L shaped wires that you glued to the nut almost touch in the center of the nut (right over the hole) so the spark will jump across the gap and ignite the butane gas. Now take about three inches of electrical wire and strip both ends of both of the three inch wires. Now take one of the wires we just striped and solder one end to one of the L shaped wires and the other end to one of the leads the other piece of the mail piece of the wire connector. Now take the other piece of three inch wire and solder one end of it to the other L shaped wire and the other end to the other lead of the male wire connector. And your done!!!
Step 7:
All you need to do to use it is put it on, put everything together bend your wrist back to release the butane and ignite it with a lighter or with the igniting device by pressing the button on the handle. The farther back you bend your wrist the bigger the flame. Have fun and be very careful!!! Your votes would be very much appreciated!!!
    • Classroom Science Contest
    • Fandom Contest
      Fandom Contest
    73 Discussions
    pastorpili
    9 months ago
    You can add a Voltage multiplier on your ignition system to make it more powerful and to create more spark
    pastorpiliHimers
    Reply 9 months ago
    No post it in youtube so that everyone can see
    pastorpili
    9 months ago
    Can you please upload a video showing that it actually work ? In youtube i mean
    chrslefty
    4 years ago
    It would be way cooler if you had shown your glove in action.nice start and cool concept.
    Himerschrslefty
    Reply 4 years ago on Introduction
    Thanks!!! Also I did make a video of the glove in action it is in the final step.
    King Cyber
    3 years ago
    nice project it will work oneday fo ma protection lol thanks for sharing
    HimersYourLightbearer
    Reply 3 years ago
    You can buy it online or you might even have something laying around the house.
    itsthatsguy
    4 years ago on Step 7
    I do like the idea, and i theorized building a device like this once, I asume it could be done safely, but id use some kind of kiln or crucible style gloves for the glove you mount it on, there flameproof and withstanding massive temperatures without burning your skin. Furthermore no tubing exists that is both butane safe and see through, in your instructable you mention fuel line, which is also wrong as gas, diesel, and alcohol will not dissolve what butane can. it looks like you using vinyl which will dissolve until it ruptures and expends butane. There are basically 3 types of rubber that are butane safe, BUNA-N (nitrile or NBR), Viton (FKM), and extruded ptfe (which requires a steel braid to operate over 20 psi), Please do some chemical compatibility research and design your ideas to be safe before releasing a guide on how to build these. Your asking for permeant burns on about 20-30% of your body from that canister, Butane is a hell of a flammable gas, and just as importantly a solvent.
    If you think im wrong then feel free to goto: http://www.coleparmer.com/Chemical-Resistance and look for yourself, Cole parmer is a lab supply company whose nie enough to supply us with a neat little chart allowing you to check any material vs any solvent, its an excellent resource.
    Pyroguyman096itsthatsguy
    Reply 3 years ago
    Barbeque lighters use a clear, vinyl-like (if not just straight vinyl) for the deliverance of butane to the ignition point. Might wanna check your facts again
    Himersitsthatsguy
    Itsthatsguy, I don't know how accurate your source is but I have seen many people on internet using this kind of fuel line and nothing has happened. And also I have been using this fuel line for weeks and I just went to check the fuel line and I see no signs of it dissolving. Now don't get me wrong I am not saying you are wrong... but maybe that is the case only if you are using it for long periods of time. Again I am not saying you are wrong and so for that reason I am going to pay close attention and if I see anything happening I will post something on my instructable telling my viewers to switch out the tube. Thanks for expressing your concerns!!!
    a2eHimers
    Rad work!
    I totally agree with you.
    There are people that build, and there are people that complain. BTW: Where you shot the vids? It's a nice place and I'm happy that you didn't burn your eyebrows at the end, although it is not as serious as everybody claim, I've seen it go wrong and it takes a short while to get fine again.
    Himersa2e
    Thanks!!! And you are exactly rite... this isn't as dangerous as people make it sound... It isn't like I'm playing with a "bomb"!!!
