Pyrography, or How to Wood-Burn Art
629,686
810
41
"Pyrography is the art of decorating wood or other materials with burn marks resulting from the controlled application of a heated object such as a poker." -Wikipedia
In this Instructable I will show you how to take an image and burn it onto a piece of wood by hand. As an example I used the heraldic lion of the House of Lannister from the book/TV series "Game of Thrones."
Supplies:
Step 1: Supplies
-Wood, cut to size (I prefer to use Pine. It is soft enough to burn, but not too soft like Basswood)
-Sandpaper, 320 grit
-Pyrography Pen
-Graphite Transfer Paper
-Colored Pen
-Scissors
-Tape
-An Image to wood burn
Step 2: Preparing the Wood
Once you have your piece of wood cut to size, inspect it to make sure there are no dents or markings on it. If you do happen to find any relatively shallow nicks or dents, simply take a damp wash cloth, fold it at least once, and place it onto of the defects. Then use a hot clothing iron to press down onto the wash cloth. Continue this process until the dents in the wood have been raised. Let the wood dry.
Now, take your sandpaper and sand the wood to a nice, smooth finish. I would recommend wrapping the sandpaper around a flat wooden block to make sure that you get an even surface.
Step 3: Transferring the Image (for Those of Us Who Can't Draw/freehand)
Now that the wood is ready, prepare your image however you like and print it out. I did some basic photo shop just to remove the background and save ink. Cut your graphite paper to size with the image and tape the image on top. Make sure that you put the 'transfer-side' facing down.
Take your brightly colored pen and simply trace over the image (see picture 4). Only go over the parts that you want transferred onto the wood. I would recommend no tracing any areas that you want to do shading.
Step 4: Voila!
Gently lift up you image/graphite paper and see the fruits of your labor. At this point look over your image on the wood and see if there are any unintentional marks (picture 3). Worry not! Take some sandpaper and gently sand away any marks (picture 3).
Step 5: Safety and Technique
Select the proper nib for the pen (picture 2) and let the pen heat up.
SafetyTechniques
A) "Flat" side of the nib is used mostly for thick lines, gently curving lines, and shading (picture 3)
B) "Blade" side of the nib is used for fine details (picture 4). This can lead to very deep burns into the wood if not careful.
Remember that it takes a lot of practice to get the hang of it. I've been at this for almost 2 years and even I still mess up!
Step 6: First Burns
Now that you have the technique, you should start the burn on the simplest part. Using the lion as an example, the back and the tail are mostly just the flat, basic lines (picture 2).
Continue with the rest of the basic lines. It will get easier as it goes, trust me.
Tunnel Vision
Something I noticed while doing this burn was that it is easy to lose track of where you are in the work. You may find this the case when you get into more complex parts of the work. For example, i had to stop and think when i was working on the part where the mane overlapped the arm (picture 3).
Step 7: The Details
When you finish the major lines, it is up to you on how to proceed. Some pictures will require a lot of detail, others not so much. The most important part of doing the details is taking it slow. Focus on certain parts at one time (ex: the mane, an arm).
Without a video and a time-lapse it is hard to show you how to do detail work, but remember back to the technique of using the "blade" side of the nib for small details (picture 2).
A word of caution when using Pine wood: On the grain you will notice light and dark parts. The lighter is the softer wood. When you have to burn on a darker part of the grain (picture 1), you will notice that it does not burn as easy. You will have to carefully keep going over the same line until it is dark enough to match the rest of the work.
Step 8: Preparation for Shading
When you are finished with the basic lines and the details, A) congratulate yourself and B) prepare your work for shading.
You may notice that there are parts on the work where you did not exactly match the graphite trace (picture 2). Worry not! Take your sandpaper (320 grit or higher) and lightly sand the entire piece. This will get rid of any shallow burns and graphite marks.
Clean all the sawdust off the wood, making sure to get it out of all the lines. You want a nice clean piece for the shading.
Step 9: Shading, Part 1
If you choose to add shading to your work, it really adds to it and can also help give it depth. But I also must warn you that it is the hardest part and takes some experience.
First, decide where you want to shade (lion's mane). Second, determine how dark you want it to be and if you want to change the shading in different parts (gradient). For the question of how dark, i would say that the darkest should not cover up your basic and detail lines (picture 1).
How to Shade
Use the same nib that you used on for the lines (picture 2). I use the end of this nib which is flat and about 1 mm wide. Hold the pen like you would for a flat line and barely touch it to the top of the wood. While keeping it on the wood, move your hand in a circle, keeping the the nib at the same angle. You should notice the wood to start getting darker. Keep doing this until you get to the desired shade of wood.
Keep moving the nib, if you let it sit in one spot too long or favor one part of the wood over the other, it will show. If this happens, try to blend the darker parts into the lighter parts.
Step 10: Shading, Part 2
Shading is a nice way of adding some depth to your work, it can turn an average work into something astounding.
I'll be using my lion work as an example.
After i finished shading the mane, I felt like the work was still too boring. I noticed that there were 2 other spots that would be prime candidates for extra shading: the plumes on the tail and the fur hanging from the legs and arms. I shaded them to the same darkness as the mane (picture 2).
For a nice touch, i decided to lightly shade the rest of the lion's body so that it would have definition against the regular wood backdrop.
The important part about this is to blend the darker parts into the rest of the light body. This does not apply to the mane since it is 'separate' from the body, but the tail plumes and arm/leg fur do. Blending is the name of the game.
Hint: If you mess up on shading, or just want to go lighter, don't be afraid to lightly go over the problem areas with sandpaper.
Step 11: Done!
After you finish with the shading, you will be done with your work! Step back and appreciate the hard work you put into it. Don't forget to add your own personal mark on the piece, whether on the front like a painting, or on the back (picture 2).
At this point, you can leave the wood as is, or you can protect it. Polyurethane, oil, varnish, wood stain all work. A word of caution about these methods: If you use a dark stain, for example, the shading might be less pronounced.
Thank you for reading my Instructable and I wish you luck on your own pyrography projects!
-Scott
Update: I have put this piece of work up for sale on ETSY, check it out!
2 People Made This Project!
  • IoT Challenge
    IoT Challenge
  • Woodworking Contest
    Woodworking Contest
  • Arduino Contest 2019
41 Discussions
DianneS39
Question 11 months ago on Step 11
Once I complete my project, how do I clean off the visible transfer ink?
1 answer
EXPLODINGLDianneS39
Answer 4 months ago
oh boyyyyyyy... you gotta make sure the transfer ink is completely burned off. you can attempt to sand it off but that's about it
oxodian
Question 1 year ago on Step 2
I can’t do anything this fancy and amazing but I just got some flat pine but it’s still very ‘green’ and has tiny amounts of bark at top and bottom for design but cant find if that’s ok
57rjb.
3 years ago
Hi... I have had a Pyrography set for a couple of years now, but have not been able to use it as I cannot work holding the pen at the end, I would like to be able to hold the pen nearer the nib, but as you know the rod gets to hot, does anyone have any suggestion as to what gloves would be best to use so as I don't get burnt?. any suggestions would be appriciated..
edrieann12357rjb.
Reply 1 year ago
You can buy a leather finger guard on amazon for couple of dollars. I find this to be less restrictive than wearing a glove.
mhcrane57rjb.
Reply 3 years ago
I took leather shoe string and wrapped mine using super glue along the way. I've been using this one for over a year now and it's still holding up. I hope it works for you as well as it has for me. P.S. I can't imagine doing this with welding gloves on. This is something you should enjoy! Great instructable also!
Chele2u57rjb.
Reply 3 years ago
A welding glove is easy to work with as they have different sizes and thickness. You can find them at a welding shop. Mechanic gloves at auto part stores may work also.
Jared_Sams
2 years ago
Awesome work. I tried my hand at some pyrography on a pub table and bar stool set. If you or anyone else wants to see them, look here https://www.instructables.com/id/Pub-Table-Bar-Stools/
KobeR2
3 years ago
What about using a pyrotechnic powder do burn in the design?
rcgriffin1127
3 years ago
Awesome job! I can't wait to try this! I wondered how people made fancy stuff...carbon paper...mind blown! I have a set, and now I'm about to be all locked up in my house...for. a. long. time! Haha -=80)
Chele2uJoshuaB24
Reply 3 years ago
I read that heating up certain materials like stains and saps are not healthy for you to inhale. I would also think that the heat would also cause that stain to bleed and run thus drying in clumps and ruining your picture.
RameshR10
3 years ago
Very useful instructions, thanks. Rana
LelandP1
3 years ago
I'm thinking about woodburning a cutting board. Is it safe to use for cutting or should it just be decorative?
Also. You don't have to use transfer paper :) I ran out a little while back and just used a heavy leaded pencil and colored the back of the picture. It makes it kind of nice actually and now it's the only way I do it. I noticed with the transfer paper that it can rub off in unwanted places that you don't intend to burn on. And it was very hard to remove if I succeeded at all haha. When you color the back of the picture instead of using transfer paper, just tape it to a window so you can see the image clearly and only color where the lines you want to transfer are. I swear by it. Just a little tip to throw out there.
dollarseed
4 years ago on Step 11
First, in regards to the comment below mine. A soldering iron is not the same thing as a wood burning iron. Most wood burning irons come in kits with all kinds of cool tips to play with, and run at a higher temperature. Now back to you Scott. I prefer to work from the outside of a piece in, so as to not have a sweaty hand smudging the graphite. Also, once a piece has been outlined with the burner, that wood is now sealed off from the rest of the piece. This gives you the opportunity, say on the mane or tail etc, to use regular wood stains without fearing they would bleed into surrounding areas.
kootamaa
4 years ago on Introduction
Hi, I'm a newbie in pyrography so I'm looking for some tips and... here I am :D
Here is my latest (anf first being honest :P ) pyrography artwork, hope you'll like it ;)
