Quick and Easy Dice Tower
20,133
204
22
About: It's all about the process. The finished product is just a bonus!
My family loves to play games. Many games involve dice. Many dice rolls result in disputes over whether it was a real "roll" or not. Did it tumble an acceptable number of times? Did it strangely land without tumbling at all? All disputes and questions may now be put aside with the use of a dice tower. Inside this simple box are three baffles which guarantee that the dice dropped within will be adequately randomized. Never again will you hear, "THAT WASN'T A ROLL!!!"
A dice tower may be made very quickly from scrap wood or cutoffs, as this one was. Some well-placed felt will provide a bit more friction to ensure that the dice actually roll and don't merely slide. Not only that, but the felt creates a really nice sound. Seriously. Check out the video at the end to hear what these dice sound like coming through the dice tower. It's beautiful!
On the last page of this Instructable, I explain the rules to a fun dice game which has been around for at least 60-70 years or so. It's a great way to break in your new dice tower, or to otherwise occupy a rainy day.
Let's get started!
Supplies:
Step 1: Materials Needed
As I said, this box was made from scrap wood. The dimensions are really up to you. In my case, my dimensions were determined by the size of the scraps! The tower is about 6 inches tall. If I had to do it again, I would make it more like 8 inches tall, because it would allow more room inside for the three baffles.
Most of the wood I chose is nice-looking plywood. The side walls are thin solid wood. The baffles, as you can see in the picture, are very rough-looking plywood, but they are not visible and so the type of wood doesn't matter.
The most important thing is that the baffles are the exact same width as the front and back panels, because they will be providing structural support by being glued to both side walls.
Not pictured above is the small panel for the top, to partially close the top of the dice tower.
Step 2: Place the Baffles
First, you need to figure out how far apart to put the baffles, and at what angle. A few considerations:
  • You need to be sure you will have enough clearance for the dice.
  • You need to have a decent angle so the dice won't come to a stop.
  • If you play games involving many dice thrown at a time (like Yahtzee or Farkle), you will want to allow for even more clearance to avoid jams.
  • Three baffles is the generally accepted minimum number for a dice tower. You can do more! I have even seen a spiral staircase design for a dice tower.
My placement is rather arbitrary. Because the tower is a bit short, I feel like these baffles are crammed together. But they work fine. After you have them set up, mark their placement, glue them in place on one side, and then place a large heavy flat object on the top. Let dry. (Notice I am using simple craft glue, not wood glue. This wood is lightweight and small, so I figured craft glue would be sufficient.)
Once the glue is dry, glue some felt onto the baffles. This would actually be better done first, but I had forgotten. Still, none of the pieces came loose as I handled the baffles while gluing on the felt, so that shows the craft glue was doing its job.
Step 3: Entrance and Exit Openings
Now you need to figure out how low the front wall will go. Like with previous steps, this does not require precision. Just figure out how much room you need for the dice to exit the tower. The area marked with Xes shows where the hole will be.
Likewise, figure out how much of the top you want to close up to allow the dice to enter. I suppose you could leave the top completely open, but I like having yet one additional gluing surface for stability of the tower as a whole.
Step 4: Partial Wall Glue-Up
Trying to glue eight small and thin pieces of wood together is a very tricky business. So I simplified my job a bit by doing two partial glueups in advance. First, I glued up the front panel with the small top panel. Then I glued the back panel with the base or floor. Leave it a couple hours to dry.
Step 5: Final Glue-Up
Just prior to glue-up, there was one last-minute adjustment I made. I glued a small panel of felt to the inside front wall, and another to the inside rear wall, where the dice are likely to hit before proceeding down the tower. I mainly did that so that the entire dice roll will be felt-sounding, and not interrupted by the occasional bang of dice-meets-wood.
Now it's time to glue it all together. First, I glued the bottom of each of my two-piece glue-ups and placed them on the side wall that already has the baffles (see first picture). Then I applied a layer of glue over the top surfaces of everything (including the top sides of the baffles) and laid the other side wall on top. Lastly, I applied the clamps.
You can see in the second picture that where possible, I covered the exposed edges of the plywood with the solid wood. This is one benefit of using solid wood for at least two sides of your tower, to cover up the plywood.
Step 6: You're Done!
After the glue dried, I applied a coat of maple stain, just to even out the two different wood colors. Then I glued on another panel of felt at the bottom of the last baffle by the exit. And there you go! It's not fine woodworking, but it does the job of looking halfway decent and making dice games a bit more enjoyable to play. Next I will be building a felt-bottomed dice tray into which this dice tower will fit.
Here's a short video showing how it works and sounds:
Thanks for reading! I look forward to your comments and suggestions. This dice tower is easy, it's quick, and it'll make your game playing more enjoyable!
To break in your new dice tower, go to the next and last page to learn a simple but fun dice game called Pig.
Step 7: Pig: a Dice Game
Equipment: Two standard 6-sided dice, pen and paper
The goal: To score 100 or more points
The rules: The starting player rolls both dice. As long as the player does not roll any 1s, they add the sum of the dice to their turn total and may either stop (banking the points) or roll again. The player may keep rolling until they either decide to bank their points or until they roll a 1 with one or both dice.
If they roll a single 1, the player gets a score of zero for that turn, and their turn ends. If, however, the player rolls two 1s, the player's whole score (including previously banked points) gets wiped out, and their turn ends. If the player rolls a double (of anything but 1s), they add the sum of the dice to the turn total, but the player MUST roll again.
This game is surprisingly fun! I have played it with 2-10 players. For larger players, I'd recommend a slight variant called Skunk, which you can read about here.
Rainy Day Challenge
Runner Up in the
Rainy Day Challenge
    • Gardening Contest
      Gardening Contest
    • Classroom Science Contest
    • Party Challenge
      Party Challenge
    22 Discussions
    Jobar007
    3 years ago
    The only problem I see with this design is that with a six-sided die, it could only roll back and forth, preventing the "sides" of the die from being an option. Granted it would have to perfectly drop in from the top to make that happen. Perhaps an alternate angle would solve that? As in your center baffle be glued to the front and back instead of the sides. That way you get more motion in your tumble than just back and forth.
    My family plays a lot of games as well. We must not be a cut throat as your family because I've never heard "THAT'S NOT A ROLL!" while we played. If it is on the table and one side is clearly up, it is good. That being said, this would be good for my son (who's a toddler) to roll since his hands aren't big enough to hold more than one die.
    offseidJobar007
    Reply 3 years ago
    I love this comment. Thank you! That is a great suggestion. Having an alternate-direction center baffle, as you suggest, would work. Or, using some simple geometry, you could cut angles onto the sides of the baffles where they glue onto the walls, so each baffle is not only going downhill but at an angle as well. I do plan on making a solid wood dice tower in the future, so I will try that.
    Of course, this is only really an issue for those inclined to cheating. For the average family gamers, it's probably not an issue!
    ndronetoffseid
    Reply 1 year ago
    I've owned many dice towers and honestly we never had issues of dice not truly tumbling on all 6 side. The odds of a 'sliding dice' is really slim. However if it is a concern, you could easily remedy that by adding ridges to your 'backboards' before covering them with felt.
    halciberJobar007
    Reply 1 year ago
    Trying gaming with serious strategy and role-play gamers for a little while. You'll hear this more than you would think possible. When you game too much, you look for EVERY advantage, including complaining about the result of a die roll.
    Jobar007halciber
    Reply 1 year ago
    I used to play a lot of Warhammer 40k, competitively. In all of the tournaments, I can't remember ever hearing someone complain about a roll and not get laughed out of the building. There were some guys that rolled 40 dice at a time, so it's not like they were little rolls.
    I also used to play a lot of pen and paper RPGs. I can't remember anyone saying, "That roll didn't count" aside from the not on the table rolls. Everyone I played with understood the dice went how they went. Maybe we always had a DM that was in it for the game, not to "win" against the players.
    Maybe it's personality differences in where we look for advantages. For me at least, if I'm going to win, it'll be because I was the better player, not because I complained the loudest.
    rocketridehalciber
    Reply 1 year ago
    Indeed. My fiancee and I got to know each other in a D&D game.
    rocketriderocketride
    Reply 1 year ago
    That should have read, "Indeed. As an aside, my fiancee and I got to know each other in a D&D game. The stories we could tell about diceroll-based dungeon lawyering.
    snowf7
    1 year ago
    If the tower was made from clear plexiglass, I think the kids would enjoy watching the movement of the dice as they came tumbling down and out. So would I. LOL.
    Eh Lie Us!
    1 year ago
    that sounds is pretty neat. Kind of like the souvenir wooden frogs from Thailand. I think your design needs to be changed... make it taller!!! The sounds might calm the nerves of your edgy players.
    offseidEh Lie Us!
    Reply 1 year ago
    I like your idea! A tall dice tower would be pretty nice. If I do it, I'll make another Instructable about it!
    Raicer
    1 year ago
    Awesome dice tower. I built one a while back but did not think about the felt aspect. I will incorporate this next time!
    offseidRaicer
    Reply 1 year ago
    Thanks a bunch! Yeah, for me, the felt just makes it sound nice too. It just feels and sounds pleasant to roll the dice. :)
    halciber
    1 year ago
    Nice project, and a great idea! Thanks for sharing it with us.
    GeorgeM161
    3 years ago
    I am a big of dice towers and you have made an awesome work. I have a blog about dice towers, if you need to learn more check it out :) www.woodendicetower.com
    steveap
    3 years ago
    Nice
    Malkaris
    3 years ago
    I think I'd add a "fence" to catch the dice from rolling off the table. With little kids ended up making a penalty for when the dice fell off the table (monopoly I think) not so much to punish, but to keep them focused on not "throwing" the dice to energetically.
    offseidMalkaris
    Reply 3 years ago
    Yes, totally. As I mentioned, a dice tray would be (for me) a necessary accessory. In the meantime, I often put the dice tower inside the box top of a board game, and that does the trick.
    offseidbuildandsewandstuff
    Reply 3 years ago
    Thanks a lot! They are fun to use. If you search here on Instructables, you will find a few other dice tower plans, all slightly unique and made from different materials.
