Radius Sanding Scroll Saw Mod
2,066
39
8
About: I am a metal fabricator at DA Moore in Concord, NC. I also machine, weld, and draw CAD/CAM parts on a daily basis. In my spare time at work I like to make things that pop into my head. I have to keep the ...
I recently needed a way to sand a radius on some curved lettering with my scroll saw. For this, my first Instructable, you'll likely need:
  • Scroll Saw (usually helps)
  • Scroll Saw Blade (pinned), I had a damaged cheapo blade
  • Wooden Dowel Rod, in this case I used a 5A drumstick
  • 3/16" drill bit, drill
  • Wood Glue
  • Electrical Tape
  • 3M Spray Adhesive (love this stuff)
  • Sandpaper of your choosing
Step 1: Assembly
I sawed off a chunk about 2-1/2" to 3" and drilled through both ends with a pilot drill and finished with the 3/16". Once I fit the blade through the hole I wrapped the Electrical tape around one end as to plug the other end and keep the rod in place. I did end up taking a thin piece of shim to center the blade at the open end. I proceeded to fill the hole with drops of wood glue until it was reasonably full. I then stood it upright to cure (inside this random spool of solder wire).
Step 2: Applying the Sandpaper
Here I coated the back of the paper with the spray adhesive and rolled the blade onto it.
Step 3: The Resting Surface
I cut a large hole to accommodate the cylinder and away I went! Don't mind my unusual clamping method. I don't own a pair of vice clamps (yet) so I have been using a cheapo pair of micrometers to bite down and it works darn well.
Best part is that you can reuse the rod and keep applying paper, and you can even flip it upside down for anther surface to use!
Thanks for checking this out, and I should return soon for another instructable!
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
    8 Discussions
    Nate5b
    2 years ago
    Neat idea, thanks for sharing. I like seeing tools used in new ways.
    deluges
    2 years ago
    This is really smart, thanks for sharing! Will definitely come in handy
    Lotusfallsdeluges
    Reply 2 years ago
    Thanks! I have plans+pics to make a more elaborated instructable very soon.
    Bubbler
    2 years ago
    A good idea. I have had good results with store bought Sanders for the scroll saw, but they were a tad expensive, and now, hard to get. At least where I live. Thanks.
    LotusfallsBubbler
    Reply 2 years ago
    That was my problem as well. I could only find the stuff online and I got impatient after nothing was available at Lowe's or Home Depot.
    wold630
    2 years ago
    Awesome hack! Did the sandpaper ever come off while you were sanding?
    Lotusfallswold630
    Reply 2 years ago
    Not at all with the 3M spray adhesive. I'm finding all kinds of uses for that stuff. I used the Super 77, pretty general purpose. Glad you liked it!
