Raspberry Pi: Launch Python Script on Startup
Introduction: Raspberry Pi: Launch Python Script on Startup
About: Scott Kildall is an new media artist and researcher. He works at Autodesk, Pier 9 and is an artist-in-residence with the SETI Institute
As I've been working on my own Pi projects, I've been discovering many little tricks and tips by scouring various websites and assembling information, testing and optimizing.
So, here is another one of my "meat-and-potatoes" Raspberry Pi Instructables.
This Instructable will show you how to setup your Raspberry Pi to automatically launch a Python script upon startup.
First of all, I know this is a lame picture. If you can come up with a better one, I'm open to suggestions.
The Arduino has auto-launch built into it; the Pi does not. This will make your Pi a more powerful electronics platform and is essential if, for example, you want to use your Pi as a video kiosk using GPIO controls.
Before doing this Instructable, please make sure you have your Raspberry Pi up and running, which you can do with The Ultimate Raspberry Pi Configuration Guide Instructable.
I'm using the Mac OS for this guide, but you can extend the principles to other operating systems.
Step 1: Make a Launcher Sript
I'm building out a new project called Black Box Timelapse (Instructable coming soon...).
My python script is called : bbt.py and lives in a directory called bbt that is in the root directory. You can substitute your own director/Python script name instead of using mine.
We will use the Linux crontab to run the Python script.
I've had trouble with crontab and directory management and my solution is to amke a shell script, which always navigates to the proper directory and will launch my bbt.py Python script.
Let's create the shell script!
I'm using ssh to access to Raspberry Pi. My IP address for the SD card for this is 10.0.1.68. Your IP address may be different — just change the address accordingly.
Open the Terminal window and on the command line, type:
ssh pi@10.0.1.68
If you are running directly hooked into the monitor, you can skip this step.
Type in:
cd bbt
then:
nano launcher.sh
Will launch your editor, type in this script
#!/bin/sh
# launcher.sh
# navigate to home directory, then to this directory, then execute python script, then back home
cd /
cd home/pi/bbt
sudo python bbt.py
cd /
Cntl-X, Return to save.
What this script will do is to navigate to the root directory, then to the bbt directory, launch the Python script and then return to the root directory.
Step 2: Make It Executable
We need to make the launcher script an executable, which we do with this command
chmod 755 launcher.sh
Now test it, by typing in:
sh launcher.sh
This should run your Python code.
Step 3: Add Logs Directory
We will get to using crontab in a minute, but first we need to make a directory for the any errors in crontab to go.
Navigate back to your home directory:
cd
Create a logs directory:
mkdir logs
Step 4: Add to Your Crontab
crontab is a background (daemon) process that lets you execute scripts at specific times. It's essential to Python and Raspberry Pi. The details are confusing, as is often the case with Linux. Once I got the hang of the format, I've found it to be incredibly easy to use.
Here's the Linux reference and here are some more crontab examples.
Type in:
sudo crontab -e
This will brings up a crontab window.
Now, enter the line:
@reboot sh /home/pi/bbt/launcher.sh >/home/pi/logs/cronlog 2>&1
What this does is rather than executing the launcher script at a specific time, it will execute it once upon startup.
Step 5: Reboot and See If It Works
Unplug the power or just type in:
sudo reboot
Wait for startup and see if your script automatically launches.
If it doesn't work, check out the log file:
cd logs
cat cronlog
This will show you any errors that you might have.
Step 6: Always Make an Exit Plan!
You'll want to have an easy way to exit the code, so that you don't get stuck in an endless buggy loop.
The way I do this is to plug in the keyboard (not plugged in for standard kiosk usage) and exit the script this way.
In a standard Python script, you can always hit cntl-C, which will exit.
If using the pygame libraries, you can do an exit on keydown, such as:
while not done:
    for event in pygame.event.get():
        if event.type == KEYDOWN:
            done = True
Step 7: Extra: Crontab for Timed Scripts
Another way you can use crontab is to execute scripts at specific times, such as every minute, every hour, at a specific time. This is especially helpful for projects such as Twitterbots, which I'm using for my Bot Collective project
In this case, you want to make sure your Python script exits and isn't stuck in a loop, otherwise you may end up launching the script multiple times.
Here are some examples, with the same bbt.py/launcher code:
# every 2 minutes
*/2 * * * * /home/pi/justdiedbot/launcher.sh >/home/pi/logs/cronlog.log 2>&1
# at 6:22 EST, 3:22 PST (we are on PST); 15:22
22 15 * * * /home/pi/marktwainbot/launcher.sh >/home/pi/logs/cronlog.log 2>&1
Step 8: Done!
I hope this was helpful!
Scott Kildall
For more on Raspberry Pi code and other projects, you can find me here:
@kildall or www.kildall.com/blog
7 People Made This Project!
  • Metalworking Contest
  • Creative Misuse Contest
  • Fix It! Contest
    Fix It! Contest
95 Discussions
Hey, where do I do the Ctrl+C to exit the script? My script runs upon rebooting but nothing else is opened, so there isn't like a terminal where the script is running for me to Ctrl+C.
GioloP
8 months ago
I am having an error running my script on boot.
ImportError: no module named imutils
I have tested my script an it runs without errors, I also checked that it imports everything that is needed. But when I run it on boot (following the steps above) it seems it can't import modules. Is there anything else that I needed to do?
hi, I also have this problem. if you solve it may you share it with me?
thanks
remove the 'sudo'. Simply run 'python your_script.py'
i think its beter to check whether the process is running and if it fails relaunch
  1. Add this line to the file that just opened
    */5 * * * * pgrep -f myscript.py || nohup python /home/you/scripts/myscript.py > test.out
3 questions regarding this, as I'm new to linux:
1. what does the " */5 * * * * " portion of this code do?
timing - found the answer :)
2. what does the " > test.out " portion do?
3. Does this line get placed in the crontab file as the previous instructable indicates?
I like the functionality of monitoring and restarting my python script, as I'll have this on a headless Raspberry Pi that will be left unattended for days at least.
1 yes timing every 5 minutes
2 to save a log for debugging purposes
3 you can put a file in /etc/contrab.d named as you want with this line inside.
well finally I do it similar but a little different
1 create in /etc/crontab.d/ a file named ie.: mycron
2 write inside
*/5 * * * * root /root/myscript.sh
3 in file myscript.sh write
#!/bin/bash
# test if running and kill process
process_id=$(pgrep -f MYFILE.py)
if [ "$process_id" != "" ]; then
kill -9 $process_id
fi
# relaunch with nohup and in background the process MYFILE.py logging output to /tmp and error to null
nohup python /root/MYFILE.py > /tmp/results.log 2 > /dev/null &
Excellent! Thanks for the help! :)
AymarL
Question 5 months ago
Hello, great tutoriel but i have a question im using the Desktop version (for needs to visualize my code) but now that it's running background how can i send Ctrl+C to it? how can i view it's terminal?
1 more answer
this gives you the process number and then
kill -9 NUMBER_PROCESS
This method works only for reboot (rebooting with command) not for Startup or power on.
I am looking for method which can execute script on Power On (startup)
Hi it don't work and there is no log either
Hi Scott, this is a really cool way and works. except that I have one problem. the script runs only when I reboot. It doesnot work when I start my rasppi. any idea why?
Scott, really cool thank you. You helped me out when using the rc.local file wasn't running on boot.
One piece of feedback, is that crontab should be able to just run the python script directly, without needing to create a bash wrapper script to launch python.
You can add the line:
@reboot python /absolute/path/of/my/script.py
To cron and it will run fine. The logger line you added above also is helpful too.
If your script uses python 3, then just use something like:
@reboot python3 /absolute/path/of/my/script.py
Running it this way will avoid the need to use cd commands in bash to connect to the directory. Just assume you're starting from root at boot, and then call the script with its direct path.
Great Instructable. Helped a ton.
HELP! I did this and now I have a black screen on boot! What do I do?
What python script is executed?
Mr.S32
7 months ago
Traceback (most recent call last):
File "assistant_library_with_button_demo.py", line 31, in <module>
import aiy.assistant.auth_helpers
File "/home/pi/AIY-voice-kit-python/src/aiy/assistant/auth_helpers.py", line 24, in <module>
import google_auth_oauthlib.flow
ImportError: No module named google_auth_oauthlib.flow
Hi,
First of all, great tutorial. Very clear.
However I am having an error in my MySQL connection.
_mysql_exceptions.OperationalError: (2002, 'Can\'t connect to local MySQL server through socket \'/var/run/mysqld/mysqld.sock\' (2 "No such file or directory")')
I think that maybe have to be the user who run the script but I to noob in linux to know.
Thanks in advance.
Hi, total noob here !
Before getting to this tutorial, i ran the .py manually in the terminal.
I managed to get launcher.sh to launch my python script, but when my raspy reboots nothing happens( i dont see a terminal where i can read my data inputs like my working .py would). Also, when i try to reach the logs , an error says they dont exist, eventhough the log directory already exists.
Thanks for the guide. It's working just fine. I am running a bot for discord. However it boots and works just fine and everything but there is no terminal popping while it's on. The bot uses feedback on the terminal.
