Recirculating Air Spray Booth
25,051
308
68
About: About me : I am a Cabinet maker of 30+ years with a degree in civil engineering who presently runs a cabinet shop for a custom home builder on Vancouver Island . I have been building things all my life, fro...
The construction of this spray booth happened out of necessity ,
I am responsible for the design and construct all the cabinetry for our custom built homes ( we build on average 4 to 6 homes per year ) and I was sending all our finishing out to a spray shop ( the only one in our area ) the problem that arose was that getting our finished pieces back when we needed them . Sometimes this would delay our completion, then the finishing company had some internal problems, which meant they were unable to take on any new work.
After a lot of research it became evident that because of the cost of a commercial spray booth and the shop area required that purchasing a booth was not practical for our present space. Because of our location a conventional booth would require us to have a make-up air system to heat the incoming air that would be exhausted out, another added expense.
IMPORTANT NOTE *****
I decided that we would only be using waterborne lacquers for finishing and no solvent based products. Waterborne products are more environmentally friendly, safer, and non toxic. Which meant two things :
1. That flammable vapors and fire suppression would not be an issue.
2. I would be able to recycle the air providing I could remove all the contaminates.
Today’s waterborne finishes are comparable with solvent based products; they just take a little longer to dry. And another deciding factor for using a waterborne lacquer was that there is very little odor, compared to the toxic gases given off by solvent based products ( grey cell killers and I need all that I have left ). Just because there is less odor, you still require a proper spray mask while spraying.
It should also be noted that the design of this spray booth incorporated items and material I had available to me at the time and changes to size and configuration could be used to construct a booth to fit your own needs and the materials you have access too.
Supplies:
Step 1: Basic Premise, and Filters
As seen in the drawing,the contaminated air (paint over spray)
(A) is drawn into the first accordion type paint filter. This filter traps up to 90 % of the airborne paint on its cardboard riffles,
(B) next the air is drawn thru 5 -20’’x 20’’x 2’’ baffle filters (furnace filters ),
(C) then after the air passes thru the squirrel cage fan it is then forced thru
(D) 6 - Activated Carbon filters (to control organic vapors ).
(E) And then finally thru 5 more 20’’x 20’’x 2’’ baffle filters.
(F) The air then flows downward ( creating an air type curtain ) and then repeating the cycle with clean dust free air .
Filters A,B and E are readily available. The activated charcoal filter D was made from scratch and I will go over it's construction in a later step.
Step 2: Main Supporting Framework
The frame for the whole unit started with 2 -9’ high pallet racks and 5 – 9’ horizontal bars. Using the steel frame would help provide enough weight to support the cantilevered upper plenum .
Once assembled the inside was lined with 3/8 ‘’plywood on the back, and 3/4 ‘’plywood on the sides. All the plywood was fastened on with self-tapping screws into the metal frame.
I made up a 3 ½ ‘’ x 6’’ piece of fir, the same length as the width of the pallet rack side, then attached a piece of ¾‘’ plywood and heavy duty casters raising the whole unit ¾ ‘’ off the ground. This makes the whole unit movable should it get in the way of our shop door.( I ended up adding a third wheel to each side and a support screw to bear the weight once it was in position)
Step 3: Filter Frame and Fan Instalation
I then built a 20’’ deep base ( the width of my squirrel cage fan and furnace filters ) x 11” high along the bottom.
Using the height of my card board baffles,( 36’’ clearance on the bottom and 18’’ on the top). the filters are held in an upper and lower U shaped channel, ( solid stock with 1/8'' masonite strips on both sides ).
The upper filter is just a 36'' filter cut in half down to 18''.
I then constructed a framework that would hold my 5- 20’’ x 20’’ x 2’’ furnace filters, and then mounted it horizontally across the unit.
The squirrel cage fan was then attached to ¾ ‘’ plywood. ( back, top and front with a hole cut out for the exhaust ) Then the fan unit was mounted above the filter framework.
Note that the 1hp motor was mounted above the fan and a fan belt connected the two thru a slot in the plywood.
Step 4: Upper Plenum and Closing in the Fan
Then I installed the two sides of the upper plenum ( 3/4'' x 16'' x 96 ) on which I routered out 3 -1 1/4'' x 16'' slots at 13 degrees ( these are for my charcoal filters ).
Next were cleats for back support so that I could enclose the fan, along the face (3/4'' ply), and on the top (3/8''ply).
NOTE: The face pieces were just screwed in place should I ever have to get access to the fan.
Step 5: Upper Plenum
Next came the box that would hold 2 - 4' - 2 bulb fluorescent lights ( 8'' wide 4'' deep to fit between the two upper plenum sides ) .There is a piece clear glass to protect the fluorescent bulbs. ( removable and held in place with a small rabbited molding )
I added a two sided divider in the middle that matched the grooves for the charcoal filter, and then connected them with U shaped pieces for the filters to slide into.I then attached 1/4'' MDF ( maximum density fiberboard ) between the bottom of the filter and the top of the filter below ( this forces the air to go thru each charcoal filters )
Next came another horizontal framework to hold another set of 5- 20''x 20'' x 2'' filters, and then the whole plenum was enclosed with 3/8'' plywood.
I used 1/8'' white Masonite cut into strips to create the U shaped channels to hold the expandable cardboard filters in place, and to close over the horizontal furnace filters. ( removable for filter replacement )
Step 6: Doors and Lights
I made two doors out of 3/4'' plywood that has a white melamine finish on it, that has two more 4' fluorescent fixtures (mounted in a box on the outside of the door. with a piece of clear glass to protect the bulb from over spray).
The doors are held in the open position with small barrel bolts, and in the closed position with a commercial suitcase latch. The lights were wired into a switch on the side of the unit and the 220 volt fan motor just had a long cord with a plug on the end.
Step 7: Activated Charcoal Filters
The first step was to make enough activated charcoal (6 + pounds) If you are uncertain what is the difference between activated charcoal and charcoal, it all comes down to the available surface area on the charcoal particles that can absorb odor. Activated charcoal has something like 2700 times the available surface area compared to charcoal, which makes it so good for purifying both air and water.
For me to go into how I made it is another whole Instructable. It takes a surprisingly large amount of work to produce any large quantity. Next time when I have to replace it I will look into purchasing it in bulk .
The actual filters were a two piece wood frame that has a piece of a 3/8'' rain screen ( a material used in construction to allow air movement under the exterior siding ). Fastened to the wood frames the rain screen has a thin layer of fiberglass on one side to hold the activated charcoal, and a dense plastic spaghetti on the other side, this spaghetti side will hold the activated charcoal from moving around.
Once I had the 6 frames made up I spread the activated charcoal evenly on them . I made up window screen frames to cover the charcoal side ( removable for when the activated charcoal needs replacing) and the slid them into the slots in the upper plenum, then covered over with a piece of plywood ( removable ).
Step 8: Spray Room
Now that the booth was complete and fully functional, it was moved to it's location by the rear overhead door of the shop.
I then needed to build a spray room to keep unwanted shop dust out, and that could be moved out of the way when we needed access to the rear door. Finished size 16' x 22'
I mounted two steel tracks on the ceiling (12' high ) that would have rollers attached to a heavy duty white tarp. The door section was made out of 2'' x 4'' and 3/8" plywood . The whole door section slides in the track as well.
Above the door is a box with a filter that holds a construction heater that blows warm air into the room. On the ceiling I mounted two house type ceiling fans that would both push the warm air down and also create air movement to aid in speed of drying the water borne finishes.
Because the heater is blowing air into the room and there is no exhaust air going out, the room is under a slight positive pressure keeping any unwanted dust from entering the room.
The last step was to build 4 mobile drying racks out of plywood and 1/2'' electrical conduit and some solid stock.
We purchased a commercial high pressure - air assisted unit that you can see mounted on the white movable cart. Having the proper spray equipment ensures a better finish.
What you see on the racks is the first job I sprayed ( teak veneer doors and drawer fronts , sprayed with clear waterborne satin lacquer ) and it turned out better than I hoped .
Step 9: Conclusion
This is my very first Instructable and I hope that my explanation isn't too confusing. Any unique projects I do in the future I will try to document them with more detail.
Like most of the things I make and do, I enjoy the challenge, the problem solving ,and the fun of doing it for yourself.
I have believed all my life that I was always the laziest guy in the room, because if there was an easier or quicker way to do something, I was going to find it !
I have done my fair share of spraying over the years in several different booths, and surprised myself with how well this worked to control the over spray and dust control . The [air curtain effect ] prevents any dust from entering the booth area. As for the odor, I leave the booth running the whole time and have had people walk into the room while I was spraying, and said the smell was negligible.
I did not keep an accurate list of the materials used in this project, and like I mentioned at the start , the purpose of this Instructable was to show how a recirculating air booth works , how I constructed it ,and the materials used. Should you attempt to build your own booth your list of material could be completely different than mine depending on your own design, and what you have available.
The entire build took about about 6 -7 weeks, ( mostly by myself and my lead (only) shop hand ), but now we can do all of our own in house finishing, saving time and money .
One Big Massive Tool to get the job done.
CHEERS!! Thanks for your support and votes .
Build a Tool Contest
First Prize in the
    • Classroom Science Contest
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    68 Discussions
    Barringer
    5 weeks ago
    This is an awesome design, great work. I've been working on a similar apparatus to help pull away fumes from the big 4'X8' laser cutter in my shop. In the one i'm working on, i'm hoping to use the overhead air filters as a light diffuser to help spread the light around a bit from a rig like this. Thanks for posting, once again job well done!
    -Barringer.
    neslo63Barringer
    Reply 5 weeks ago
    Thanks for your comment and I hope you can come up with a design that works
    cheers
    Mindo78
    6 weeks ago
    I only registered to post this! :) This is what was remotely in my mind -how to direct the air so it does not suck from surroundings and all the dust from the small workshop. Only I imagined that the air should come thru the roof and filters then directly above the work. This is really impresive concept and migh not need the hole in the roof at all! Great design and looks truly amazing :) Only wanted to ask, what if Polyurethane paints are used, what then? If the gases could become flammable or could explode?
    neslo63Mindo78
    Reply 6 weeks ago
    I am not sure how flammable Polyurethane paints are unless you are talking about waterborne polyurethane. I use this booth to spray only waterborne finishes that are not flammable and do not give off harmful gasses ( I still wear a mask ), that been said I would not recommend building a booth like this for solvent based products because you were right in saying that explosive gasses could be extremely dangerous!! and would require a conventional spray booth that expels all of the flammable gasses. I have used this booth to spray a couple kitchens now and it is performing extremely well and I am quite pleased with the finished product using waterborne lacquers.Thanks for your interest and if you have any more questions feel free to ask.
    cheers
    Mindo78neslo63
    Reply 6 weeks ago
    Thank you for fast response. Yes, I'm referring to 2K synthetic polyurethane paints, worked in the past with joinery painted in microporous waterborne paints and found them to be very soft and not good as a protective finish for hard wearing areas, exterior doors etc. While 2K PU paints do give a strong hard wearing surface... I was thinking about a similar concept just to have exhaust and intake from outside, so there is no circulation of the same fumes. I assume the benefit of the system likethat would be that I should not get negative air pressure inside the curtain area and should avoid dust suction from the workshop- what do you think?
    neslo63Mindo78
    Reply 5 weeks ago
    So from my understanding you want to build a what sounds like a conventional type booth that exhausts outside but strictly uses intake air from outside , but i think having a curtain wall might not work.If you had a fan blowing air out ,yes it would draw fresh air in thru say a hole in the ceiling but it would have to be big enough for the volume of air your pushing out with the fan . I think you would still have a negative pressure in the room, you probable would have to have one fan pushing air in and another pushing air out, trying to balance two fans might be tricky especially if you have filters involved that would change your air flow as they clog up. May be another option depending on where you live is one of those inflatable type booths you can set up outside.
    neslo63Hey Jude
    Reply 6 weeks ago
    Ya my boss thought I was insane too at first :)
    neslo63CraftAndu
    Reply 6 weeks ago
    Thanks .it seems to be working really well so far
    cheers
    pierrard
    3 months ago
    I NEED THIS !!!! :)
    woodie1949
    3 months ago
    Wish I seen this about 15 Years Ago, I just closed my Shop after 50 Years
    neslo63woodie1949
    Reply 3 months ago
    Congratulation on your retirement, I'm on the freedom 85 plan myself. I am not sure the waterborne lacquer 15 years ago is any where as good as it is today, so this type of booth might not of worked back then. best of luck in your future and thanks for your support
    woodie1949neslo63
    Reply 3 months ago
    I used Solvent Based Products, (Lacquer) Tried Waterborne, didn't like it.
    pejoka7577
    3 months ago
    Excellent project and instructable!!! Truly, it is above average. Looking forward to using many of your ideas as I configure a new shop space.
    neslo63pejoka7577
    Reply 3 months ago
    I'm glad people are finding my project interesting and informative. I hope my future instructables ( I think I'm hooked ) on various shop related projects, carts ,storage,and maybe some of the neat things I get to build, will go over as well . Thank you for your words of support,and your encouragement. Cheers and don't forget to vote
    Ross51
    3 months ago
    Great concept, ideal fold away design and it does away with the exhaust through the roof or wall making it far more portable/moveable and I would certainly like to build a spray booth along these lines.
    Regards,
    Ross
    neslo63Ross51
    Reply 3 months ago
    Thanks for your input , but please remember this was designed strictly for water borne finishes and not solvent based , which do require external exhaust and fresh air intake.This booth cleans and then reuses the air . I hope you can use my concept to help you build your own booth, to suite your own requirements.
    Cheers and thanks for your support.
