Recycled DIY Floor Rug From Left Over Carpet Tiles
11,022
139
27
This low budget DIY project is about using new but leftover carpet tiles and transform them into a modern looking colourful rug for your home :).
A lot of stores that sell floor finishings and/or do carpeting projects have a stack of cheap leftover carpet tiles laying around. These leftovers are often a large mix of all sorts and colors so they are not suitable for finishing an entire room anymore. Mostly these never used tiles end up in a dirty garage or shed, they get thrown away or get installed at some place where a super low budget floor finishing is needed and aesthetics is no big deal. In most cases it’s a downgrade of a functional new quality product and that is just a sad thing. Therefore i came up with a simple solution; get rid of the limited pattern possibilities of the standard squares and cut them into different shapes, so the variety of color will become a big plus instead of a problem! :-)
this video is the third of a few tutorials i will make about this idea and hopefully you will be inspired to save some carpet tiles and money for your own :)
IMPORTANT: Think about your safety! Make sure you are good prepared and use good tools before you begin! Cutting the carpet tiles is a job that you must take serious, because it’s a tough and durable material and needs a lot of force to be cut. Only use rulers that have high edges ( to block the knife from leaving its direction and might hurt your hand ). Don’t do this project alone, for safety reasons. Use sharp blades since this will save a lot of your energy. The blades become blunt easily because of the strong backing of the tiles.
Step 1: Collect Materials & Print the Template
Recipe:
- 6 leftover carpet tiles, for best geometric effect… try to find 3 different, but nice to combine colours. 2 light coloured, 2 dark and 2 bright ones. Also try not to bring Boucle carpet tiles because once they are cut… their edges are very rough and often disturb the pattern lines ( creating ugly gaps ) Frieze carpet tiles work very good! - 1 cutting mat, could be discarded wood or anything actually - 1 stanley knife + new blades - 1 large roll of duct tape or gaffer tape, only use good quality stuff - 1 ruler with a good high cutting edge or use a straight metal profile with high edges and handle bar. In best case, your ruler or profile has hand grips that make it more easy to put pressure on the tile and stay away from the knife. BE CAREFUL! - 1 thin white marker, i used a Posca fine liner. You can also make a light mark with your knife, so you don’t need any marker. - a piece of solid cardboard or anything else that is sturdy and easy to cut - the printed template shape to make the tile contour - glue
print out the template and instruction sheet of the tile contour and measure all lines to be correct. ( to make sure the printer did not warped the shape )
glue the template contour onto the solid cardboard and cut it. ( be precise! )
Step 2: Cut & Mark & Cut :-)
mark and cut the tiles into long strips like in the video. ( be precise! )
mark and cut the strips according to the tile template contour. ( be precise! )
Step 3: Repeat With the Other Carpet Tiles
cut all 6 carpet tiles into parts just like you did with the first tile.
Step 4: Puzzle and Connect the Tiles
puzzle on the floor until you have found the design you like best
use the duct tape to connect all the individual parts.
flip your design over ( carefully ) and add tape strips on all connections to make sure every part is well fixed.
you are ready! :-) time to enjoy your hard work.
Tape Contest
This is an entry in the
Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Jewelry Challenge
      Jewelry Challenge
    • Tape Contest
      Tape Contest
    27 Discussions
    charlessenf-gm
    17 days ago
    Brilliant!
    First time I saw it I told my wife "There's a creative person."
    Wonder if you could find some way of gluing the bits to a sheet of backing material so as to have a resilient and portable piece - or, why didn't you think of it first, a wall hanging!
    I guess my main concern would have to be the cutting process. One little mistake could lead to the whole setup being messed up since the tiny pieces won't stick together in a smooth shape. I got to practice more!
    MaraCreates
    26 days ago
    Love it, not sure if I can find these here in Greece, since they don't really do carpet here :( Last week I tried getting a place to give me their old wallpaper samples, but they wouldn't hahaha.
    JaiB15
    27 days ago
    You just inspired my living room floor. I have an abundance of these tiles. Thank you so much! Who said nothing good comes from late night internet strolls?
    heygeno
    4 weeks ago
    Back in the 60's I carpeted EVERYONES bathroom with rad shag carpet pieces picked from carpet dumpsters.... no need to be precise !
    marthajheil
    4 weeks ago
    I love the optical illusion. I want to do this with kites and darts for penrose tiling.
    OnionTheAnion
    4 weeks ago
    The design kind of reminds me of the Gamecube logo. Nice project!
    Jfieldcap
    5 weeks ago
    Looks awesome! I'd worry a little about the durability, but I bet you could do a couple different things to help it last longer. Some sort of edging around the outer edge would help, and maybe if you cut a large piece of backing fabric and sewed the carpet tiles to that it would help.
    booger1027Jfieldcap
    Reply 4 weeks ago
    I am curious as how well it rates in durability & as well of mods in order to make it more durable.
    JoopB1booger1027
    Reply 4 weeks ago
    durability is not an issue :) quality of most tiles are very good. Just keep in mind not to buy the boucle type of tiles because these turn out ugly when cut.
    JoopB1Jfieldcap
    Reply 4 weeks ago
    Thank you! :) Don’t stress about the durability :) carpet tiles are made to last long. my carpet is finished a year ago and still looks neat! The thing is that the taped edges at the end of the carpet should be well taped so the pieces don’t split over there :)
    forgot to mention... don’t buy boucle tiles and also no tiles with very long 'threads’? not sure or this is the good word :P
    SedaS3
    5 weeks ago
    Looks great but- Measurements are written in CM - I think you mean MM (millimeters)
    Example - 1241mm= 48.8527 inches- I guess we should round off?
    JoopB1SedaS3
    Reply 4 weeks ago
    hi! measurements are written in CM, not MM :) 12,41cm would be 4,89 as far as i can see
    SedaS3
    Question 5 weeks ago on Step 2
    are the measurement is millimeters?
    ChaBuku AlexB
    5 weeks ago
    How well does this stick together once the carpet tape is on? Super intrigued by this as I was trying to find an odd-shaped rug for a while, but heard that cutting one up messes up the edges. Tiles seems like a good way to do it.
    JoopB1ChaBuku AlexB
    Reply 5 weeks ago
    carpet tiles would help you a lot with your search for an odd-shaped rug! :)) regular carpet doesn’t get nice trimmed edges, but carpet tiles do! The backing is perfect to hold together with good duct tape! i also tried Tactiles but that get’s quite expensive with these amounts of parts. you can also ‘melt’ the backings together i heard... but no experience with that :)
    Italiankiwiblog
    5 weeks ago
    This design is fantastic! What a great way to use up the odds and ends of carpets!
    cobourgdave
    5 weeks ago on Step 4
    Really excellent design, well done. Never thought of carpet tiles as being used as "mosaic" material
