Recycling Old Car Radio Into an Audio Amplifier
127,796
608
63
About: I like to make stuff
I got this old cd player that was pretty much waste, because It had its front panel lost. Even if it worked I don't have any physical media nor I wanted to listen to radio. But I knew that I could use the amplifier part and use it to drive some speakers, and then connect it to any audio source that I wanted like an iPod, phone, TV, etc.
It then worked very well, and the 4-channels came in handy, so I could connect it to 2 speakers plus 2 larger woofers, to give some Bass! For that I modified 2 of the channels to only reproduce bass, using a very simple low-pass filter.
This made a great setup to replace the very bad speakers that I have on my cheap TV. Now I can enjoy netflix and video games with decent audio, with some bass response to it.
All of that, basically for free! It was going to the trash bin anyway, mother nature is thankful for that, so it's my wallet. :)
Most of the time and efforts goes in trying to figure out how it works, and what you need to do. Once you figured out, the modifications are very minimal, and straightforward. Just some traces broken and a few jumper links to make it work. The only additional part is a 12v wall wart adapter that can provide a few amps, that can be savaged easily from old stuff.
It's certainly doable with any radio, but some will be more challenging then others. Since every model will be different, you will have to figure out by yourself like I did.
Step 1: How to Take Pictures
You don't need anything special, just a regular camera with non-fixed focus this is very important. And good lighting.
The camera used to take this pictures was an iPhone 5S camera.
Very important tip, take your pictures outside, you can see it makes a huge difference (first picture indoor with regular fluorescent lighting, second picture outdoor). Try taking multiple shots at different positions relative to the sun to avoid shadows and glares, with different exposure and focus, and distance. Then pick the best one.
Step 2: Getting Details to Start R.E.
We need as much as information as possible about the heart of the amp.
In this case there's a big 24-pin device attached on the back heatsink, that's a dead giveaway that it is a power device.
In some cases, you will find discrete amplifiers, and those can be some sort of transistor array or H-bridge. But in this case I'm looking for a Class AB amplifier of some sort, because at first glance I can't see any output filtering stage, not a single inductor or big electrolytic capacitor (apart from one in the 12v supply) that would appear in a Class D amplifier.
Thankfully there's a part number that we can search for a data sheet. TA8272H and I found out that this is a full audio amplifier in a chip, it is a linear bipolar amp or like I guessed a Class-AB Amplifier. They are not impressively power efficient, but they are inherently lower noise when compared to Class-D amplifiers.
Step 3: Reverse Engineering!
Please view the Original Size pictures:
View the image here: http://extrazoom.com/image-35217.html
I explain in more details how I align images here in this tutorial: How can I reverse engineer a simple through-hole board?
Based on the datasheet, I start to enumerate the known pins and traces, on layers on top of the image, then I will follow traces, and sometimes make assumptions to were it goes, then check continuity using a multimeter to make sure that I guessed it right.
I highlighted every trace that was important and required to get the amp working, from its power supply, inputs and outputs, and control pins. I back traced the speaker outputs from the rear panel through the board in magenta. Ground is always easy, I highlighted ground in Blue, (everything in a car is that is attached to the chassis is ground, so you can test continuity easily to know it it's ground). In Red, I highlighted the 12v line that comes from the yellow wire that comes from the car battery. Each of the 4 audio inputs is highlighted in a distinct color.
Everything else was useless. So I broke some traces that powered the other parts of the circuit that I won't need. So I just needed to add a jumper link on the stand-by pin of the IC, that before it was only powered by the micro controller, when the radio was on.
I Injected signals direct to the input pins, and voil√°. audio came out of the speakers.
Since it had a couple of RCAs outputs on the back, I just redirected the audio from the audio-out connectors to feed audio to the amp.
Step 4: Shrinking the Board
Most of the stuff of the board was not being used. Since I had every important trace drawn on the screen, I found that I could strip 2/3 out of the board much trouble. Again after breaking it apart just cut traces to make sure I had no shorts.
Step 5: Crossover
Since this is a 4-channels amplifier, and I had only 2 inputs connected, I wanted to make a kind of subwoofer using 2 smaller speakers and 2 woofers.
So I made 2 low-pass channels that will reproduce most of the bass, and 2 full range channels but I added a 12dB attenuator, to enhance the low-pass channels.
The low pass filter consist of a simple RC filter that will give a roll out of -3dB per octave with the cut off frequency of fc = 79.5774715459[Hz]. Determined by a 10K resistor with 2 100nF ceramic capacitors in parallel.
And on the full range I added a voltage divider of a 10K-2K to give me some attenuation, to make the bass more pronounced than the full ranges.
http://hyperphysics.phy-astr.gsu.edu/hbase/electri...
http://sim.okawa-denshi.jp/en/CRtool.php
Step 6: Volume
I don't have a volume control, but that's not a problem, we can just adjust the volume from our source, like an iPod, TV, etc. Or if you want just wire a stereo potentiometer in line with the input.
But you can go fancy, and add digital volume with remote control.
I explain how to make it in this Instructable: Remote Volume Control for old stereo amp
Step 7: Shrinking the Case
Step 8: Finishing
Step 9: Done!
Maybe next time we can incorporate a power on status led, stand-by switch, remote volume control and add blue tooth to the audio amp.
    • Classroom Science Contest
    • Party Challenge
      Party Challenge
    • Woodworking Contest
      Woodworking Contest
    63 Discussions
    QuangB7
    6 weeks ago
    Good modification.
    I add audio line directly to the IC with left, right, ground. However, I cannot eliminate noise from it.
    Do I have to add Low pass and high pass filter to the output? Thanks
    QB
    LeonC62
    4 months ago
    Hello Vitim thanks for the project.
    I tried to make this project with the same amplifier but I need your help. My problem is "The stand-by pin of the amplificater" where I can solder the jumper in the circuit. Thanks.
    SashlynN
    Question 4 months ago on Step 4
    Hi,
    I have a Sony hifi, and thinking of extracting the amplifier. Its a 5.2 channel. Would it be possible to use the existing controls and equaliser?
    RohithA12
    9 months ago
    Hi, I'm trying to understand this thing . And I'm tired of cuz the company is Sony but on board it has some samsung chip can plz help me!!!!!!!!!!!
    VitimRohithA12
    Reply 8 months ago
    look up the chip screwed to the back and try to find its datasheet on the internet
    RafaG4
    1 year ago
    Hi.
    I am trying to use the amplifier of a Sony CDX-L280 radio using the same integrated TA8272H.
    Could you tell me how to make it work without the front of the radio?
    When I unplug the front it stops ringing and I do not understand what I should do.
    My knowledge in electronics is minimal.
    Thank you.
    DiegoT35
    1 year ago
    This is awesome!!
    Please, can you upload/send me a high-res pic for the attenuators and filters welded on the mainboard? Regards!
    RahulC49
    2 years ago
    I am trying to convert the same radio that you used in your tutorial into an amp to run speakers at home. But my but my board has a TDA8588BJ, which is a voltage regulator cum power amp. I wont be using the RCA jacks but instead will solder the aux wires on the IC. Here is what I am planning to do :
    Aux (right) to pin 11(INT 1)
    Aux (left) to pin 15 (INT 2)
    Aux(gnd) to any ground on the pcb
    SHORT pins 22(STB) and 37(Vp)
    I will be using the Sony wire harness to connect the two speakers and power (from my PC PSU).
    There are a lot of gnd pins on the IC, I am confused what to do with them, I guess grounding the harness black wire should ground all of them.
    VitimRahulC49
    Reply 2 years ago
    Datasheet: http://pdf1.alldatasheet.com/datasheet-pdf/view/12...
    On the page 44 there's a application diagram, this is the minimum components to use the amplifier IC. You can't connect your audio signal directly to the IC pins, a resistor and capacitor is required on the inputs. But you don't need to buy this, because they are already on the board. You just need to trace them. Your audio input ground is SGND(pin13) and ACGND(pin16) tied with four 470nF capacitors.
    If you need help, take hi-res pictures with good lighting and sharp focus of the top and bottom of the entire board. Taking pictures on daylight helps a lot with glare and noise.
    RahulC49Vitim
    Reply 2 years ago
    Okay got it.
    But will shorting Vp and STB make it work? Since there is a bus line that communicates with the amps , I am guessing some sort of instruction set could be required.
    CyKlopsCC
    2 years ago
    Couple more questions: (For anybody that can answer)
    What are the two yellow connections that you drew in your above diagrams, the upper one appears to link a powered section of the board to a ground section, and the lower one looks to be a resistor between two powered sections of the board?
    When you say "jumpered" to the stby pin, do you mean you just ran straight 12v from a nearby powered section to the standby pin?
    I cannot get any output sound currently. I am reading 3v or so coming from each of the INPUT leads (all four of them)... not sure about that, perhaps I am missing something necessary in grounding. Where exactly did you solder into the input leads? Right at the amp?
    I am not getting even any hiss from the output leads... almost as if it is muted, or not turned on. The only sound I get from the speaker is a faint pop when I connect main power.
    Thanks very much.
    VitimCyKlopsCC
    Reply 2 years ago
    sorry for the long delay, I never seems to get comments notifications. The yellow symbols are a inductor and a capacitor, they are part of the power supply filtering. You can see on the datasheet standby it requires anything from 3volts to VCC (same as input voltage, in this case 12v). Try touching the inputs with your fingers you should hear a hum, if not the IC amp is probably in standby or in mute. Read your datasheet to find which pin controls those things.
    CyKlopsCCVitim
    Reply 2 years ago
    Thanks very much for the reply(s).
    I am still fuzzy on the section where you talk about the yellow hand-drawn components (inductor + capacitor)... Did you have to add them in (if so, what are their specs?) or are they on the other side of the board, and it is a necessity to be aware of their location as to know where to solder in the leads (before/after) etc?
    Typically both the mute and standby would possibly require VCC (within specified range according to datasheets etc)?
    CyKlopsCCCyKlopsCC
    Reply 2 years ago
    Actually, I see they are not on either side of the board originally, so you are adding them in. What are their specs, and if you don't add them, what will happen?
    RahulC49
    2 years ago
    Hey great tutorial.
    But how did you connect the aux to the RCA output jack? Those Jack's are for audio output right?
    VitimRahulC49
    Reply 2 years ago
    That's right the RCAs was originally outputs from the cd DAC, but the output of the cd DAC is connect to the inputs of the amp, so I just disconnected the DAC from the circuit then the outputs becomes inputs to the amplifier!
    RahulC49Vitim
    Reply 2 years ago
    So I am a bit confused, does the output of the CD player not require amplification?
    CyKlopsCC
    2 years ago
    Great job, thank you Vitim!
    I am currently doing this to a newer Clarion deck, similar (common) 4x50W Toshiba setup. Fairly nicely labelled on the board too.
    Question #1: Can I bridge the four channels into two, by joining the F/R right outputs, and the F/R left outputs? This would provide 2 x 100W as a result. I worry though that there needs to be additional circuitry to prevent the signals from feeding into each other?
    Question #2: For soldering in the input signals, what is the best locations to solder in the accompanying grounds (neg-) from say, the RCA cables such as you used? Or does it matter?
    Again, thank you and great job.
    VitimCyKlopsCC
    Reply 2 years ago
    About bridge configuration, typically no unless this configuration is mentioned on the data sheet.
    Make connections as close as possible to the IC inputs, and do not pick a ground very far from those LR inputs, this is to avoid picking hum. Just be carefully to not bypass the usual ac couple capacitor and input resistor on the inputs, connect it after, or else you will get very distorted sound and might damage the inputs.
