Redneck Power Brush
10,795
59
21
About: Fixer, Finder, Fabricator.
This project came about because the house was starting to look like a vampires nest with all the dirt and spider webs everywhere and I would like to start painting the place.
Trouble is those spiders web are really difficult to get off and using a pressure washer just seem to spread them around, and a brush didn't help much either. I did find however if I spun the brush it seem to work quite well flicking off the dirt and winding the spider webs onto the brush, only one thing for it then,  put a motor on the brush!
The 2 photos are the before and after 30 seconds with the RedNeck Power Bush.
As this instructable is entered in the redneck contest there are references to Hillbilly's, Bogens and rednecks.
Most photos have notes attached
Supplies:
Step 1: Stuff You Will Need
For this project your going to need
  • whipper sniper, bush cutter, weed eater or weed whacker boom. (heavy duty Rednecks will also need the engine)
  • soft circular brush.
  • cordless drill
  • various size hoses.
  • insulation tape
Step 2: Striping Down the Weed Whacker
First you will need to remove the boom and the line trimmer head  from machine. The throttle cable and any other parts that are in the way will also have to be removed as we are going to straighten the boom.
Its not to difficult just undo the screws and slide the boom off the engine.  The line trimmer head is left hand thread on some models.
Step 3: Straighten the Boom and Fitting the Brush
To straighten the boom I just carefully put tin the vice and pushed the tube a little bit at a time, and kept repositioning it in the vice, until straight.
To fit the brush I found a piece of rubber tube about the right size and screwed it on the of end of the shafts and wound some insulation tape on the end to give the thread of the brush something to bite into.
The brush can then be screwed onto the end of the shaft.
Step 4: Dont Try This on Your Own Car!
If you got the urge to put the 2 stroke engine back on and use it then......you could be a RedNeck!
there are lots of uses for a 2 stroke power brush,  you can
  • take the paint off the neighbours car!
  • clean the outhouse!
  • wash those pots and pans!
  • break your windows!
  • set fire to yourself!
  • remove the fur from small animals!
If you want something a bit more useful go to the next step
Step 5: Fitting the Cordless Drill
So a whipper sniper engine is just a bit over the top, so to power the brush I used a cordless drill, which can be fitted and  removed quickly.
First cut an inch or so off the end off the boom so the drill chuck can be tighten up on the flexible shaft inside the tube.
Next I used some plastic and poly irrigation tube to increase the size of the end of the boom, so the cordless drill can  slide up the the end, and as the poly tube is split it clamps onto the cordless drill.
To fit the drill just pull out the flexible shaft and attach to the drills chuck and the slide the drill into the poly pipe.
To remove pull the drill out and undo the drills chuck.
Step 6: So Hows It Work?
The brush work way better than I expected and works well on those awkward and difficult items like fly screens and spider webs. The fist time I fired it up I wasn't expecting the amount of dirt dust and cobweb to be thrown in my face, I got stuff in my eyes and hair so safety goggles and a dust mask is a good idea.
It is also good for taking off that chalky power that old paint gets, and as yet I haven't tried in on the car or toilet ( that step was a joke )
Redneck Contest
Runner Up in the
Redneck Contest
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    21 Discussions
    astral_mage
    5 years ago on Introduction
    actually a better idea is to put it in public domain with a public domian license set up there no one would be able patent it. but every 1 would be able to use the idea and make money off it
    csherry
    anything that exploits power tools and lawn equipment always gets my vote two thumbs up!!!!!!!!!!!!!!!!
    thanks sbdesigns
    Im a Kiwi so not so familiar with the local language, just a thought "houseos" would probably like this project too.
    where about in VIC are you from?
    You don't have to put it in production, just patent the idea and then sell it to black and decker/ dremel/ stihl/ husqvarna....
    ZaneEricB
    6 years ago on Step 6
    Great! I have an old weedwhacker that needs a new life and this will soon be it. I an thinking about adding a high pressure water nozzle secured to the head...whatya think?
    THIS is a great replacement for a crap steam mop....:)
    My wife is going to kill me if i keep doing all these projects...but things will be clean!
    Thanks poorchef
    I find the power brush a little heavy, but apart from that adding a water nozzle is a great idea. I also find that the straight boom can be awkward to use in some places, its great for corners but hard to use on flat surfaces like ceilings, maybe i should make another with a curved boom.
    thanks rimar2000
    Today Ive been using it to prepare for painting, its great it get rid of all the dirt, sanding dust and lose paint, etc
    saves a heap of time
