Reflective Dino Hoodie
13,866
80
20
About: I like to make things for the internets. I also sell a pretty cool calendar at supamoto.co. You'll like it.
Transform your regular hoodie into a reflective dino hoodie and be more visible at night! With some reflective spikes that use the amazing high-tech retroreflective mojo developed by 3M you'll be much easier to spot. In a city where the drivers are a bit crazy and any edge helps to avoid being run over these just might save your life!
Or help you look a bit goofy. That's worth something, right?
Thanks to Rachel for sewing advice.
Step 1: Get an Old Hoodie
This hoodie has been great for me. I failed to return the favor and during a big wheel race I tore a big hole in the back.
Ah well, now I have an excuse to rip it up even more in the name of science!
Step 2: Tear It Up
The hoodie itself here has two layers. The inside gray layer and the outside black layer. I ripped the seam of the gray layer and then pulled the back out through this opening and ripped up a lot of the back layer that way.
I was more concerned about the way the black layer would look an no the gray. SO I was pretty careless about the gray and took my time ripping the seams of the black layer.
Step 3: Start Making the Spikes
The spikes for the hoodie are sewable 3M reflective fabric. You can buy this in 1, 2, 4, or 6 inch widths. This stuff is 2 inches wide. I wanted to have a spike be about 2.5 inches wide on the bottom so I planned for a 3 inch wide triangle since some of it gets sewn under the fabric.
Long story short, cut a 6 inch piece off.
Step 4: Fold, Draw, Sew
Fold the fabric back over itself, draw on a triangle, and sew it up!
The folding and drawing are as easy as you'd imagine, but be careful with the sewing. Go nice and slow so it doesn't get bunched up.
Step 5: Cut and Turn Inside Out
Trim off the excess fabric and use a dead pen or a popsicle stick to turn it inside out.
Step 6: Stuff It!
I grabbed a small amount of polyfill to give each spike a bit of volume. How much you use is up to you so keep trying different amounts until it has the right fullness.
Step 7: Sew Back In
Here's the hard part. You want to sew the hoodie back together with the spikes inside it. You make a sandwich with the two pieces of the hoodie with the spike in the middle. Then you carefully sew it all together.
It helps to pin everything in place. These two shots show the hoodie/spike sandwich and the inside after all of the spikes have been sewn in.
Step 8: Sew Up Other Layer
Now sew up the inside layer and you're done! You can make this look nice and pretty or messy. It's up to you.
Step 9: Wear It!
If you want some help being seen at night then throw this on when it's dark out.
This is not the best for riding a bike, since you should be wearing a helmet. However, once off the bike, I've found this helpful for crosswalks at night.
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    • Classroom Science Contest
    20 Discussions
    dogs990
    8 years ago on Introduction
    Haha thanks!! i made a dino hoddie!!! its awesome!!!
    Atomman
    9 years ago on Introduction
    Sunbanks, I agree. Who wants to walk around as a Yoshi? Me :D I shall be a stupid green dinosaur :D
    PyroguyX5
    you said you found the 3M in 6 inch strips, can i ask were id purchases these? nice 'ible btw!!
    temp
    10 years ago on Introduction
    That's awesome! But i think it should be a color more different then black. I mean its dark at night.
    fwjs28
    RRAWRRR...that means i like it in dinosaur...
