Replace Worn Arm Rests on a Secondhand Chair (Knoll Formway Life Chair) // Furniture Upcycle
5,759
54
13
Introduction: Replace Worn Arm Rests on a Secondhand Chair (Knoll Formway Life Chair) // Furniture Upcycle
About: Custom Design and Fabrication Workshop with a love of making things!
Check out the short build video above!
I picked up this secondhand office chair, it’s in great condition and really comfortable. However the arm rests were all coming apart. Because I’ve got no experience upholstering things I thought maybe I could make some nice wooden arms instead.
Step 1: Here's What You Need
This is a straight forward project provided you have access to a way to cut curved shapes in wood.
Here’s what you need:
  • Wood
  • Some stiff cardboard
  • Someway to saw curved shapes in wood eg. bandsaw, jigsaw, coping saw etc
  • Sand paper. Rough to fine grit (120gt, 240gt at least)
  • Danish Oil
Step 2: See What You're Working With
Started by removing the existing armrests to see what components I could use as a starting point.
I realised I could use the plastic base as a template to get the shape I needed.
Step 3: Create a Template
I traced a master template of the side profile onto cardboard, so that I could transfer it onto the wood.
Step 4: Cut Your Wood Down
The wood I had was too thin for the profile shape. I got around this by cutting strips from it and then turning them on their side to get more thickness.
Step 5: Trace and Cut
I traced the profile onto each of the strips.
And cut them out on the bandsaw.
Step 6: Glue Up
I then glued these back together so that I had a left and a right pair.
After the glue had dried I could smooth out the shape a bit more.
Step 7: (Rough) Smoothing
I used a hand plane going across the grain to get the shape roughly smooth. This may create a little bit of tearout at the edge of your pieces, so that’s why I did this step before cutting them to their final shape.
Step 8: Cut the Outer Shape
I then traced the outer shape onto the my pieces.
Using the bandsaw again to cut the shape.
Step 9: Final Shaping
I rounded the edges with the handplane.
Then sanded. a . lot. of. sanding. Moving up through the grits 120gt -> 240gt. I used mostly hand sanding because of the organic shape. With a power sander it’s very easy to accidentally put flat spots in your work, which will be noticeable at the end.
Step 10: Apply Finish
Finally I finished them with a couple of coats of Danish Oil. I like Danish oil because all you have to do is wipe it on, let it soak in a bit and then wipe off the excess - much less likely to get runs on a curved surface. The downside is it takes 4-8 hours to dry between coats :/
Step 11: Finished!
I’m happy with how they came out.
But mostly just glad they’re not dropping gross bits of foam and plastic all over my floor.
    • Metalworking Contest
    • Fix It! Contest
      Fix It! Contest
    • Creative Misuse Contest
    13 Discussions
    I like the tone of your finished wood.
    Very nice result! And people are always throwing away chairs like that because they don't know any better.
    Thank you! I know, it's such a shame!! but at least it meant I got a new chair haha
    I love the way it looks, but I feel like my forearms would get sore after awhile.
    Thanks. It hasn't really been a problem so far. But you're right, wood is overall less comfortable than foam.
    That's a really good solution to a common problem. Well done.
    You skipped a really important part...how did you attach them??? Nice work.
    good point! I just screwed them down with little screws to the black plastic base piece.
    Beautiful job, and a great save of what looks like a pretty expensive chair. Thank you for sharing the process :-)
