Replacement Watch Strap From an Old Inner Tire
3,396
29
10
About: I'm a social-worker, working with 12 - 23 year-olds. I used to be a printer. In 2018 I opened a small makerspace (www.imdib.nl) in my house, where I have lasercutters, 3d-printers, Arduino's, Mindstorms and ...
So the strap from my favorite watch broke... a long time ago. Somehow it wasn't easy to get a replacement that fitted the style of the watch. So I made my own, fast and easy and I'm happy with the result.
This fix is really easy, cheap and will take you less than an hour.
Supplies:
Step 1: You Will Need
Materials:
  • an old inner tube from a car or motorbike
Tools:
  • scissors
  • watch strap replacement tool can be helpful
  • glue
  • hole punch
  • pencil
Step 2: Cut Your Strap
  • Cut a straight piece from the tire
  • Mark the width of your strap on the tire with a pencil
  • Cut on the marking
Step 3: Glue the Strap
  • Put contact cement on the tire strap
  • Turn the strap inside out
  • Glue together
Step 4: Add the Old Hardware
  • Remove the hardware from the old strap (watchmaker tools might be helpful here)
  • Mark on the tire strap if you have to make adjustments (I did)
  • Cut to the desired shape
  • Add the hardware
  • Place on the watch
Step 5: Make the Other Half
  • Make the other half of the strap the same way
  • Put the watch on your wrist
  • Mark where you need the holes (you only need one hole for this custom made strap)
  • Punch the holes
  • Wear your watch
I am really happy with the result and proudly wearing my watch again.
    • Party Challenge
      Party Challenge
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    10 Discussions
    3366carlos
    2 years ago
    awesome, i'm making my own soon.
    kenyer
    3 years ago
    Sorry, English is not my first language. What do you meen with that reply?
    rafununu
    3 years ago
    And black marks caused by rubber on your skin ? How do you remove them ?
    kenyermothy10
    Reply 3 years ago
    and it might help to first wash the tire before you use it.
    kenyerrafununu
    Reply 3 years ago
    It doesn't give marks, so no problem.
    malfestor
    3 years ago
    Thank you very much for the great idea. I knew someday I would have a good use for all those inner tubes I've saved.
    kenyermalfestor
    Reply 3 years ago
    And you can also use them to make rubber bands and by using two hole punchers even o-rings and many other things like grips for your tools. So its a good thing you saved them :)
