Rope / Ring Puzzle
27,896
193
17
About: I like to design and build random things.
This is a really easy project to make. The goal is to separate the ring from the puzzle. Refer to the solution video if you can't figure it out.
Step 1: Tools/Materials
Tools:
  • Table or Miter Saw
  • Drill or Drill Press
  • Drill Bits (1/8" & 3/8")
  • Sander
  • Scissors
  • Lighter
Materials:
Step 2: Base Build
You will build to this drawing.
Step 3: Cut Wood
Cut wood to a 3" square.
Step 4: Holes
Mark the hole locations per the drawing. Drill 3/8" diameter holes. Round the edges with sandpaper.
Step 5: Beads
These 1" diameter beads were purchased from a craft store. Drill 1/8" diameter hole through each bead. Counterbore a 3/8" diameter hole about 3/4 of the way through each bead. This counterbore will capture the knot in the string.
Step 6: Run Paracord
Route the paracord as shown. Place the wood beads at the ends of the paracord and tie knots to capture the end of the paracord. Trim the ends of the paracord and use a lighter to sear the ends. For each end, pull the paracord knot into the wooden bead. Cover the wood bead ends with glue to clean it up.
Step 7: Add Ring
Watch the second half of the video for installation.
Step 8: More Pictures
Thanks for viewing!
5 People Made This Project!
  • Pocket Sized Contest
  • Tape Contest
    Tape Contest
  • Fat Challenge
    Fat Challenge
17 Discussions
mtairymdLuizA18
Answer 1 year ago
One piece of string. It crosses horizontally on the side opposite of the beads
LuizA18
Question 1 year ago on Step 4
Hello, how are you.
I liked this your project more I would like to see underneath you only showed above, as it is under thank you (luizrossa3@hotmail.com)
NguyenT295
1 year ago
I was wondering if you have any ideas for substitutes to the wooden base, since I don't have the tools for that at the moment. thanks!
mtairymdNguyenT295
Reply 1 year ago
You can use almost anything. A piece of cardboard will work but it won't be very durable. A would try to find a scrap piece of wood or plastic and ask someone to drill the 4 holes.
Kris82
1 year ago
Simple and easy to make. Great job. I always love puzzles.
Yoruk
1 year ago
I love this mix of woods, rope and metal. Thanks for sharing !
AlyssonR2
1 year ago
A ridiculously simple puzzle that has had me mystified for years.
I may go and make one, now - but in any case, thankyou for the solution!
Cayotica
1 year ago
nice brain teaser. But it took me a few minutes to understand what the back is supposed to look like after running the cord.
mtairymdCayotica
Reply 1 year ago
Yeah, sorry about that. Step 6 is probably your best view. BTW, there is nothing tricky going on - string crosses between the back 2 holes.
MarkI36
1 year ago
Great project. I've learned to mark out and drill the holes and such before cutting the smaller piece from the larger board. I can use the additional board for clamping or holding against drill torsion. I've had too many small pieces get grabbed and spun out of my hands.
mtairymdMarkI36
Reply 1 year ago
Thanks. Very good point. BTW, notice the marks on the beads. I used vice grips to hold them while drilling the counterbore :).
CayoticaMarkI36
Reply 1 year ago
I have hold downs on my drill press for that very reason but oddly enough it never occurred to me to drill the holes before cutting the wood. If using a hand drill I always, well at least since I almost tore my index finger off, clamp down small pieces.
