Sam Flynn Suit From TRON Legacy
101,311
273
46
Okay all... so more than a few people have asked for this Instructable.  I hope I am able to explain enough.  Sadly I didn't completely document the whole process, but here it goes!
Step 1: Electroluminecent Tech
EL for short, comes in many different forms.  Sheets, strips, tape, ribbon, even flexible fabric (although I didn't discover this version until after my suit was made.)  The version I used was a cuttable form I first saw on a webseries on Revision3 internet TV.  I found it on the site: http://electroluminescence-inc.com/
Attached are some photos.  The checked pattern around the perimeter alternates the connection points (anode + / cathode -) which allows the sheet to be cut so long as two opposite contacts are connected to the sheet.
Step 2: Shapes and Things
I designed the pattern on a computer after many measurements.  I cut them out on paper and layed them on the suit to ensure everything fit right.  It probably took 5 tries to get the shapes just right.  I was also trying to use as little of the EL material as possible as the sheets are almost $50 for an 8.5" by 11" sheet.
Once I was confident that:
1.  the shapes were just right.
2.  I had two contacts (+/-) connecting to each shape.
3.  I could wire them all together easily in the suit based on the current configuration.
I had my girlfriend cut them out! haha.  Seriously, she's good with a blade.
Step 3: Wire It Up!!
This section is missing some images and detail because I was so rushed to finish before Halloween.  I will update by middle of March.
First step is too attach all the wires to the EL shapes.  I used solder and copper tape, along with binder clips to hold everything together.  This step is by far the weakest part of the costume  (and why at the end of this instructable I say what I say).  After attached the wires I fed them thru small holes in the suit so all the wiring is hidden inside.  This made things incredibly difficult, but it is awesome when people don't understand how the suit works because everything is hidden!!
I wired the shapes each in 5 sections, each of which are in a parallel circuit.( Front Right Torso and Legs, Front Left Torso and Legs, Back left torso and legs, Back right torso and legs, head and arms.)  It is important to keep everything in parallel as the brightness of the lights depend highly on voltage and current remaining consistent.  All the wiring met underneath the 'vanson' text in the back center of the suit. I plan to hide the inverter and power pack for the EL tech in the holder for my disc.
The shapes were then taped to the suit using very clear packing tape.  Sounds cheap, but I knew I would be painting the suit and the paint would hide and hold the tape on the suit.  Be sure to test the shapes as you work and especially before taping everything into place!
Step 4: Disc Holder
I designed the disc holder using Solidworks and printed it on a rapid prototyping machine.  This was quicker and easier for me since I had these resources at my fingertips (the only thing a corporation is good for).
I made two pieces.  Attached are pdf drawings of the parts.  *Note, if you copy this design it will fit almost perfectly with the Deluxe Toy Disc. I printed the parts and used a dremel to dig out some notches for the 4 nubs on the interior of the ring.  Directly underneath these divots I hot glued magnets. I also hot glued matching magnets on the inside of the toy disc.
(Pictures to come)
This made the disc easily removable.
Inside the holder I hid the inverter and battery pack for all the EL sheets.
I screwed the back cover from the inside of the suit, thru the leather and into the back disc holder. Having the back plate on the inside of the suit added stability to the holder.
Step 5: PAINT!
Probably the simplest part of the costume.  I removed the disc holder to paint it separately and ensure that all parts are painted evenly.
I covered all the parts of the EL that I wanted to light up.  Here is also the chance to fix any mis-alignments since the paint will cover up the edges.  I painted the edges of the tape with a plastic coating paint normally used to coat handles of tools, "Plasti Dip".  It is flexible yet strong and won't crack upon bending.  I used a brush for these parts to make sure the tape was held down.
The rest of the suit is a mixture of a spray version of "Plasti Dip" for the leather parts and matt black paint for the fabric parts.
Finally remove the tape!
Step 6: Re-test...uh Oh...
As always nothing is perfect and some wiring needed to be redone, but eventually it worked!!
Step 7: Epilogue
It was a rough ride and I was rushing all the way until Halloween, but it was fun.
For next year I think I am going to recreate the costume using a more flexible and reliable EL technology.
After a night of partying some of the EL panels stopped lighting up where they were bent multiple times.
Halloween Epic Costumes Challenge
Finalist in the
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Jewelry Challenge
      Jewelry Challenge
    46 Discussions
    brad.kussy
    4 years ago
    I will pay someone to do this for me in red. Very serious
    sypherbrad.kussy
    Reply 2 years ago
    ok... I have wanted a reason to do it
    taz1328
    7 years ago on Introduction
    Hey. Nice job on your costume! Quick question...how many sheets of EL paper did you need for it? Just trying to get a rough estimate on the damage to the wallet. Haha.
    Tifetuptaz1328
    I used about 5 of the largest cut and shape sheets at $50 a piece. I would wait a bit though. That same company is coming out with a pre made Sam Flynn pattern that will make the suit a lot easier.
    brad.kussyTifetup
    Reply 4 years ago
    Ill pay you good money to build this for me in red.
    cdastmalchiTifetup
    yeah for about 530 bucks... im working on making a quorra costume. ive never worked with this stuff before. she has less illumination on her suit so how many sheets would you suggest?
    Doctor08
    5 years ago
    What kind of jumpsuit did you use and the name of it
    boltoms
    6 years ago on Introduction
    amazing suit! if you want yours to be just like the movie try using a hexagonal stitch spandex jumpsuit with a heavy industrial gloss. you can use a p33 9v battery to power the whole suit. that was held by a mount in the back (which also housed the identity disc; held on to the mount by using magnets)
    RalphNLThe nerdling
    I agree!
    Maybe using a diving/jump suit or thermal cloths would be a great idea instead of a leather jacket
    Tifetuptebright1
    Any paint peels off leather after much bending. The "Plastic Dip" paint was a little better. Good for one Halloween night, but not for repetitive use. It will always require touching up. It you are good at mixing paint you could try rubber cement mixed with a certain type of paint, but I'm not sure it would work any better. Leather and paint just don't mix.
    cdastmalchiTifetup
    actually painting leather is fairly easy. it isnt 100% fullproof to all benting but if you wipe down the leather with acetone then paint it, it will not chip nearly as easily
    menahunie
    7 years ago on Step 5
    I used shoe dye instead of paint..
    They come in plastic squeeze applicator bottles.
    schroedc
    7 years ago on Step 7
    thank you for creating what I started to, but financially could not continue. I was even looking at the same company for the panels. I'm really glad someone completed my shared vision!
    PS> I bought a black leather motorcycle suit for my base...
    llaurencelle
    7 years ago on Step 2
    Was the entire costume made out of EL tape or EL panels? because I was looking into making a Quorra costume, but I'm not sure how you would bend the tape in order to create the curves and such. I really want to find a way to make the tape work if i can
    sd2kool4ullaurencelle
    Amazing Right!?
    http://www.ebay.com/itm/EL-Tape-Curve-Tron-Costume-2cm-12cm-Bend-Half-Way-Halloween-/150671860380?pt=Adult_Fancy_Dress_UK&var=&hash=item68c8730831
    http://www.ebay.com/itm/4-X-EL-Curve-Tape-Tron-Costume-2cm-12cm-Bend-Half-Way-Haloween-/150671916660?pt=Adult_Fancy_Dress_UK&var=&hash=item68c8733e5f
    http://www.ebay.com/itm/EL-Hoop-Bright-Glowing-EL-Tape-Ring-Tron-Disc-Fancy-Dress-Costume-/150671711652?pt=Adult_Fancy_Dress_UK&var=&hash=item68c8729399
