Saturn V Lamp
18,966
298
55
The Saturn V rocket is the most popular of all rockets, it was made famous by the historic flight of July 1969 which brought two astronauts on the lunar soil, this event took place almost 50 years ago !
I made this lamp imitating a flight of this amazing rocket,
It's been a long time I wanted to make it, and I was inspired by a similar creation on pinterest.
Step 1: Materials
For this project you will need:
  • wood (plank and cylinder)
  • warm white SMD led's (or led strip)
  • acrylic paint (white, black, silver)
  • transparent varnish
  • cotton
  • printable adhesive paper
  • buck converter
  • switch
  • DC jack
  • wires
Tools:
  • hot glue gun
  • soldering iron
  • access to a 3D printer
  • ink printer
  • sandpaper
Step 2: The Saturn V Model
I wondered how to make the rocket:
- from wood?... but the details are too complicated
- from a purchased plastic model? ... but the scale was too big
... So I turned to 3D printing.
The member "major__tom" is a friend of mine, who printed it from thingiverse with his CR-10.
>>> model here <<<
The print was cleaned with a cutter and sanded using sandpaper 220.
In the lower part of the first stage, I glued a wooden cylinder and drilled a hole between two engines (as shown on the photos) that will position the rocket on the lamp later.
For the paint job, I used diluted white acrylic in order to avoid brush strokes. It took me 8 thin white layers to reach the desired finish. With an aerograph, the result can be cleaner and faster.
I masked the rocket with masking tape, and painted the black areas with acrylic according to the scheme of the Apollo XI's launcher.
The details, such as the control module and the fins are painted in silver.
I printed the inscriptions (USA, United States, and flags) on adhesive paper and then, cut and glued them on the rocket.
I finally applied a layer of non-gloss varnish on the entire saturn V to protect the paint.
Step 3: The Exhaust Flames
The rocket exhaust flames are one of the light sources of the lamp. They were made from a pencil tube of the same diameter as the nozzle, which was cut into 5 tubes about 25mm long. These tubes were sanded outside using sandpaper (120). For each exhaust light : Two smd led were soldered together in parallel. They were placed at one end of the tube (as pictured), facing down. The tube containing the led's wires was filled with hot glue.
Step 4: The Lamp Body
The body of the lamp is a wooden cylinder of 300mm long and roughly 40mm diameter,
A metal rod was placed at the top of the cylinder so that the rocket can stand straight.
The exhaust flames and the model nozzles should fit together in the end, so they should be glued while facing each other.
About 20 led wires were soldered, then harmoniously sticked around the cylinder. Keep in mind to place more led at the top than the bottom for realism ! All the "+" should be soldered together as well as the "-". Each pole should be soldered to a long wire which will be connected to the base later.
You can also use led strips, just make sure it's "warm white" to make it realistic!
Step 5: The Base
The base is made from 3 squares of 20mm thick wood planks. The top plank has been drilled near the middle to allow led wires to go through. The middle plank has been emptied to make room for electronics.
The upper and middle planks are glued together. The bottom one will be screwed with 4 screws (1 in each corner)
With a screw, the lamp body is fixed to the base.
Step 6: Electronics
I first thougth about making a PWM module as on The Earth Clock. But this time, the rocket needs more led, and the module wasn't powerfull enough. I decided to only have an ON/OFF switch and nothing else.
To do so, I used a buck converter (preset on 3.1V) directly connected to led.
Step 7: The Cotton
The smoke is made using white cotton, a very simple process : you only have to glue gradually the cotton to the wood cylinder.
If you notice that lower led are too bright, you can glue a little cotton ball right on the led: that way, the light will be spread and softened.
Step 8: End
This project is now done! Here is a cut drawing showing all the steps.
If you build it, keep in mind that you can modify everything as you want (bigger, smaller, or different spaceship like the space shuttle or the falcon heavy ...) the possibilities are limitless!
If you want more pictures or if you have any request, post a comment.
I hope you liked this project!
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
  • Trash to Treasure
    Trash to Treasure
55 Discussions
SebastianK74
Tip 21 days ago
what if you had flickering LEDs to make look like live fire?
andrei101
3 months ago
Damn!! That looks cool, gonna need to try it!
Nilfisken
3 months ago
Awesome project! That exhaust flame looks amazing! The first image almost tricked me into thinking it was a rendering! :D
LevelRabbit3493
3 months ago
I love this lamp, do you have any plan of making a NASA space shuttle version? That would look really awesome too.
SimonRobLevelRabbit3493
Reply 3 months ago
yes it can be great! you just have to make two thinner "lamp body" and one "exhaust flames" on top of each lamp body according to the two boosters.
After that, the process stay the same :D
wclapie
3 months ago
Not at all sure I could make one but this is a nice project.
Bowero
Question 3 months ago on Step 1
Very nice work! Amazing look. Any way you could tell me what model your friend used from Thingiverse and possibly the scale? thanks!
major__tomBowero
Answer 3 months ago
Hello! I'm glad you like the project! In fact all the credit goes to the designer RealAbsurdity on thingiverse. The model is this one : https://www.thingiverse.com/thing:45316
I didn't modified anything. It is 3d printed at scale 1.
If you have any questions more, don't hesitate! :)
Boweromajor__tom
Reply 3 months ago
Thanks for the reply. I do have a couple questions regarding the 3D printing of these parts. I am new to the whole 3D printing thing but it is a blast! I was wondering what material you used, PLA or ABS? Also was curious as to what machine you made it on. I have the Creality Ender 3.
Thanks again!
mmgarcia30major__tom
Reply 3 months ago
Excelent print and awesome project. @major_tom would you mind to share the model link to download it? There are a few Saturn V models and want to choose the correct one.
major__tomSimonRob
Reply 3 months ago
Exact, sorry for the late answer :)
I used a nearly stock CR-10. I sliced the model using Simplify 3D and without support! If you have any questions, don't hesitate! :)
jmacuk
3 months ago on Step 8
That is a great solution to the flaming exhaust pillar! Never would have thought of using otton that way. Awesome work!
Eh Lie Us!
Good God, man. You outdid yourself.
AndrewHoover
3 months ago
This is awesome!
I'm building one of these!
JoeA66
3 months ago
Very nice! Adding an animated flame effect is super easy - Get a "flame effect" light bulb and take it apart. It will have a small mercury switch that orients the flame effect in the up direction. Find it, de-solder it, and solder it in upside down. Now the flame animation will be in the down direction. You can also remove the 120VAC power supply and run it from 12VDC.
SimonRobJoeA66
Reply 3 months ago
Waw it looks awesome !!
