Send Music Over a Laser Beam
185,132
276
163
About: I am a student and hobbiest. I'm into physics, linguistics, sailing, electronics, hacking (not cracking), music, and the like. I post most of my project stuff on my blog: http://hotwigati.wordpress.com/ ...
WARNING: this project involves the use and modification of laser devices. While the lasers I suggest using (store-bought red pointers) are relatively safe to handle, NEVER LOOK DIRECTLY INTO A LASER BEAM, BEWARE OF REFLECTIONS, and be EXTREMELY CAREFUL when MODIFYING a laser product. Also, I am not liable for anything stupid you do.
Here is yet another thing to do with those promotional laser pointers: send music (or data) from point A to point B over the laser beam using amplitude modulation. All it takes is pointing the moded laser at a detector, and music can be heard from an attached amplifier. The range and quality (or data speed) can vary, but I have gotten a HALF MILE of range with excellent audio quality and around 300bps of throughput.
The image shown here is the transmitter and receiver working across my desk during a test.
TO SEE HOW TO USE TWO LASERS TO TRANSMIT TWO MUSIC CHANNELS AND MIX THEM WITH A PAIR OF SUNGLASSES, check out the blog post here.
A video of the system working can be found here: http://video.google.com/videoplay?docid=6895048767032879458&hl=en
Much inspiration for this project came from http://sci-toys.com/scitoys/scitoys/light/light.html#laser_communicator
Supplies:
Step 1: Gather Materials
To send music over a laser beam you will need the following parts, most of which can be gotten for less than 5 dollars at radioshack total (besides the pointer, which probably costs $15). If you are on a tight budget, try replacing the laser with a red LED and a 100ohm resistor attached in series.
for the transmitter:
a laser pointer
batteries (D-cell work best)
potentiometer (variable resistor) 50k ohm or less
audio source (iPod, cd player, mic preamp, PC line-out, etc.)
some wire (cat5 aka ethernet cabling works best)
toggle switch (a turbo switch from an old PC works well)
audio transformer (can be pulled from audio equipment)
1/8" audio jack (can be gotten from the end of a headphones cable)
for the reciever:
phototransitor (photodiodes or IR detectors also work)
1/8" audio jack
some more wire
high-gain amplifier (laptop with mic input, or mic preamp plus amplifier)
magnifying glass (helps at great distances)
tools:
wire cutter/stripper
soldering iron and electronics solder
tape (clear and/or electrical)
digital multimeter (can be useful... not realy required)
tripod (helps for aiming laser at a distance)
empty pizza boxes with white backs (for finding beam and for adjustments)
some assistants
Step 2: Hack the Laser
First the laser pointer needs to be modified. Remove all bateries and total up the voltage of the batteries to find the voltage required by the laser. For instance, mine takes two AAA batteries, so that is 2 x 1.5 or 3 volts. Now solder wires on to the positive and negative terminals inside the laser. This might require cutting open the case a bit (a dremmel is sometimes nessisary).
Next, figure out how to hold down the button on the pointer that makes it light. A shaved-down pencil eraser and a ruberband works for me.
Now test the modified laser by connecting batteries of appropriate voltage to the newly attached wires. If it does't work, try connecting them in the opposite direction. Laser pointers use laser diodes which only take current in one direction.
This mod will allow us to control the brightness of the laser by varying the voltage and current supplied to it.
In the photo below you can see my pointer, with two D-cell batteries attached.
Step 3: Create Transmitter Circuitry
Use the schematic below as a guide in soldering togeather the transmitter circuit. Everything to the left of the laser is the transmitter circuit.
Tape or glue the compents down to a piece of cardboard, or use a breadboard.
Check out the photo of my finished board. I used an 1/8th inch female jack to make connections easier.
To test the circuit, turn up the iPod volume to MAX, play some music with alot of bass, and turn the potentiometer all the way down. The laser dot should appear to pulsate with the music, since this is an amplitude modulated (AM) circuit.
Step 4: Setup the Receiver
Solder long leads onto the phototransistor (or photodiode). Attach these to an 1/8th inch audio jack (a headphones cable is perfect). Plug this into the MIC port on a laptop or PC or other MIC preamp/amp and turn up the gain and volume to a moderate level. Try to mount the whole setup (with room for a magnifying glass) on a sturdy but portable material (like a wooden board).
For this project the GAIN of the amplifier is critical. It must be very high to pick-up slight variations in input signal (light) to pull out the music. Therefore I build a breadboard preamp from RadioShack's 50-in-1 Sensor Lab breadboard kit, which I highly recommend. Check out the photos and schematics from the included book.
Step 5: Give It a Try
Point the laser beam at the photodiode, hit play on the iPod, and listen to any and all noises comming from the amp. Play with the iPod volume and potentiometer positions until music can be heard clearly and without distortion on the recieving side. Then turn up the reciever gain as nessisary.
Try mounting the laser on a tripod and sending music a longer distance. I recently was able to hear Starway to Heaven clearly at a beam distance of a half mile. This was done over a small lake, with an assistant in a canue with a pizza box to help with the aiming.
Step 6: How Does That Work? and Where Do I Go From Here?
This circuit works using amplitude modulation, exactly like AM radio, except using a visible light wavelength instead of a radio frequency. The audio signal leaves the iPod as a varying voltage which forces a varying current through the laser. Then the laser's varying brightness conveys the musical information. Finaly, the phototransistor varies in resistance as the brightness on it changes. The mic amp applies a small voltage to the phototransistor and amplifies the resulting current.
A problem with this system is that at each step there is a non-linear transfer function, that is, there is distortion that occurs because the brightness changes are not always proportional to the change in voltage applied. See the screenshot below for an example, and listen to the attached audio sample.
The next step in this project would be to use pulses (like fast, computer operated morse code) to convey digital information like text, crystal-clear audio, or even video. One could even network computers with laser beams in a manner similar to fiberoptics but in open air. I will post C code for my transmitting and recieving programs.
    • Gardening Contest
      Gardening Contest
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    163 Discussions
    tab328
    3 years ago
    question: did the "next step" ever get followed thru? sending digital data for use with say, an arduino or something?
    tab328
    3 years ago
    not many recent comments, for aiming purposes it seems you could use fiber optics, not entirely sure how to have a large area of them go down to the 3mm diode
    VijayS5
    4 years ago on Step 6
    plzz give me audio transformer ratings....
    Clarisse
    6 years ago on Introduction
    Why do i need audio transformer (i mean, how it works and what is the point of it) and where can i buy/find one (pls paste a link if you know a store or if you found it on ebay) tnx ahead, please reply quickly ;)
    navaburoClarisse
    Reply 6 years ago on Introduction
    Why? Because it allows the input audio signal to modulate the laser power supply while also electrically isolating the two circuits. -- Basically, it transfers the signal from the stereo to the laser magnetically, without actually making an electrical connection between the circuits.
    This one featured at the link here will probably work:
    http://www.mouser.com/ProductDetail/Xicon/42TU120-RC/?qs=sGAEpiMZZMv0IfuNuy2LUU2nVj3GMLUawQykJuAOLGA%3d
    hesh123
    Can you please tel me the Voltage & Current values required for the Audio Tramsformer ????
    And Link OR a Site to buy a suitable Audio Transformer???
    Hope quickly response as soon as possible....
    youngdemetre
    Edit: I tried again after charging the batteries and no luck. It doesn't work now. Could have to do with laser color?
    navaburoyoungdemetre
    Hey! I'm glad you got something, even of it was faint.
    Are you using a mic input on the receiver side? A solar cell is self-powered, so it may not work well in a PC mic jack, which is expecting a varying resistance. Honestly I just don't know -- ive never tried it.
    What you can do is, build or use a preamp after the solar cell but before the main amp. Be sure to use the "line in" jack on the main amp, not a mic jack.
    If you want more help, I suggest you draw a schematic of your setup, and/or use pictures.
    youngdemetrenavaburo
    I figured it out. The solar cell I'm using was to big of an area for the laser. The dot from the laser wasn't big enough, luckily I was using a laser that also had a led light. The more area of light shown on the cell produced the sound, it's working quite well, I'll probably make something more about mine sometime.
    Again thanks for your help.
    navaburo
    Your problem might be the photocell. I recommend trying a photodiode or phototransistor, because the photodiode is more sensitive than the photocell.
    Another way to think about it is that the the photo cell is 8 W but your laser is in the milliwatts so it's your laser is way less than one watt to the signal from the laser is going to be very weak in comparison to the total signal from the photocell
    Sorry if this comment doesn't make any sense I'm typing it with Siri
    Ok, I think I understand, so the voltages don't matter for this case? I know the laser is being ran on 4.5 volts and the photocell is only .5 volts. I got the idea to use a photocell from kipkay (youtube for makemagazine).
    I'm really thinking that my problem is the wiring on the audio transformer.
    I just looked at the package again and it says that the power output is .5w and typical output voltage is 6v so I think the front of the package had the numbers mixed up.
    Your transformer wiring could be an issue. Try changing it, and check the schematics from me or some other posters. You can also use headphones on the output to see if it's working. By this I mean you can hook up headphones directly to the transformer output pins with the laser and battery disconnected.
    Cheers,
    Chris
    Thanks I just did that and the transformers working. I went from there and hooked the batteries back up and the laser and I vaintly heard the music! Then the batteries died =( I'll hook it back up once they're charged and thanks for your help! It's always the little things we overlook.
    youngdemetre
    Ok I figured out!! The solar cell I have has a larger area so I think that means it needs more light hitting a wider area. The laser I'm using also has a flashlight and i turned it on and it started working! Thank you again for your help hope you have a good night!!
    youngdemetre
    Ok, so my projects very similair only it doesn't work. I think my problems with the wiring and I don't know how to fix it.
    I've got the laser wired up to the batteries and that turns on. If I test for sound now (even though no sound is hooked up) I'll hear a click noise every time I turnt the laser on and off.
    Now when I wire everything up with the transformer all I can get to come out is the click. No other audio.
    For the reciever I'm using a .5v 6watt solar cell.
    If anyone could help I'd be thankful. I can also upload pictures of the project if that would help.
    NGinuity
    7 years ago on Step 3
    I assume you're using the transformer in that manner to "step down" the level of the input signal as well as modulate the DC going to the diode. Is that correct?
    ALogan97
    7 years ago on Introduction
    Is the audio transformer necessary? I forgot to buy one and don't want to go back out to radioshack to get one.
