Servo Driven Face
15,216
83
25
I've decided to see if I could build a head that had similar movements to the Madame Leota tombstone from Haunted Mansion using servos.
Eventually, I may build a tombstone for it to go inside.
The first thing I did was come up with the design for the eyes and eyelids on a word processing program (I converted it to .png) and then cut out a piece of mdf to hold the eye and the servos. I ended up having to cut out another piece of MDF to get the eyes closer to the inside of the mask.
Step 1:
I used 40mm ping pong balls with wooden dowels that go through the top so the eyes sit on board.
A few more dowels are glued into the back of the ping pong balls so the eyes can move left and right. Two large paper clips were straightened out to assist with connecting the dowels to the servo.
Before I attached the eyes to the board, I attached "U" brackets which the eyelids are connected to the mdf. A few more large paper clips were used as connectors between the eyelids and the servo. At first I used hot glue to attach the eye lid servo to the mdf, but I decided to make it more secure and used vertical servo mounts.
A small square piece of wood sits just in between the "U" brackets and a pop sickle stick is attached to the little piece of wood to keep the eyes from rolling back, but still allowing the eyes to move.
Step 2:
To make the face move up and down I used a 1/4 rod end and attached that to a piece of mdf. The mdf was attached to the main board and a 1/4 threaded rod was inserted into the rod end. Note: The first picture was not the final board that was used. The picture is to show how the parts were connected up.
1/4" compression sleeves were placed above and below the rod end and a nylon locking nut was attached to the top of the threaded rod.
A 1/4" locking nut was added under the bottom compression sleeve and a heavy gauge rod (it is the metal part of an irrigation flag) was attached and used as an arm for the servo. Another 1/4" locking nut was used to keep the arm in place and an additional vertical servo mount was used to hold the servo in place.
In order to keep the face from wobbling side to side, a track was added which was made using a tongue depressor cut in half and hot glued to either side of the nylon locking nut.
Step 3:
In order to run the movements of the servos, a Pololu Micro Maestro controller was used.
Using a small display box, servo extension wires were run from the controller to the top of the box. This allowed for easy connection to the servos. Wires were also run for the power supply and an on/off switch. A small hole was made in the side in order to allow to the usb mini to be connected for programming the servos.
The threaded rod was attached to a piece of wood using a 1/4" coupler and a 1/4 bolt. Also, the box was attached to the back part of the wood.
Step 4:
Acrylic paint was applied to the mask and eyes for effect.
The servos movements were then recorded and it was time to give her a test run.
http://www.youtube.com/watch?v=5jQIcLwAQPY
Overall, I'm really happy with the results.
Thank you.
**Update**
I added a picture of the face connected to the tombstone. I still need to carve the blue parts of the tombstone and add fabric and she will be done.
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    25 Discussions
    dionicia12discozombie
    Reply 3 years ago on Introduction
    I used the shells for fire crackers. You can also vacuform some eyelids using the 2" wood ball cut in half.
    dionicia12El mane
    Reply 4 years ago on Step 4
    I didn't use an Arduino. I used a mini-maestro from Pololu. I can look up the code and upload it if there is interest, but it is super easy to program.
    psycho_3852
    6 years ago on Introduction
    very nice, you could have it to where it fallows a person as they pass by the mask. to add to the creepiness
    gtoaldionicia12
    Reply 6 years ago on Introduction
    Having it follow a person is definitely possible and can be done analog, without requiring a microcontroller. You'll need an analog infrared sensor in each eye, and an op-amp, and an analog motor (not a stepper motor). Depending on which eye gives the stronger IR signal, trigger the servo to turn in that direction. The head will turn until the IR from each eye is balanced and should continue to track you as you walk across its path. A friend of mine, Steve McGloin, built this circuit when we were students back in '77 before PICs etc were available. (Sorry I can't remember the circuit in enough detail to reproduce but any electrical engineer should be able to work it out. I'm more of a digital man myself.)
    gtoaldionicia12
    For Halloween a skull might be fun. That was actually Steve's implementation. The recessed eye sockets help make the IR detection more directional too.
    I forgot to explain that with his one, the whole skull rotated to follow you across the room, but I'm fairly confident you could make it work with just the eyes.
    Or have the eyes follow you first and the head move more slowly until it is facing you again...
    dionicia12gtoal
    I already have four 3-axis skulls so I think the paintings might work out better for the eye that follow.
    Although, if the whole skull followed and not just the eyes, that would be a new twist in using animated skulls.
    Sounds like it might be interesting to get another Lindberg skull and give this a go.
    Thank you.
    dionicia12gtoal
    Reply 4 years ago on Introduction
    I had a big transition this year to a different state so I'm still trying to get organized.
    Thank you for the information. A few of my friends have articles in the Nuts'nVolts magazine so I'm going to check it out.
    Thank you.
    Redsicgtoal
    This is an interesting concept of beam Robotic's :)
    Would love to see an Instructable on this :D
    lambofwrath95
    5 years ago
    reminds me of Meshuggah - Shed... you should totally make a weird video or horror/sci-fi trailer with these!
    Eticketdream
    Hello friend, Great work here! I am going to make Leota'a tomb my project for 2013 Halloween as she takes some detail. This year my devotion is to Madam leota herself. I have Decided to work on one character from the Haunted mansion a year! I was wondering if you might give up your secret as to how you created the detail in her headress? I see people using molds but I am wondering if that is too heavy and how to Adhere Late text to Styrofoam? I thought there is no harm in asking. Any advice in all areas of her tomb would be so appreciated. The season is early, I could Mabey get her out this year! I do expect that may be Ambitious. I expect Madam leota herself I will probably run into some snaafoos. Thank you!
    Hi.
    Great questions. The tombstone itself was carved using a CNC machine. I worked with woodloom.com as the price was very reasonable.
    The headdress I will using a mix of foam and muslin fabric. The fabric will be coated with monstermud (a mix of joint compound and latex paint). The foam I will be carving using a hot knife. The face itself you should be able to find at Halloween stores as they should have plenty this time of year or you can find them online (which might be cheaper).
    I hope this helps. Please let me know if you need clarification on anything.
    Thank you.
    Hello,
    I do have two more questions if I may. I was wondering what you will be using for a stencil ( if any) for the epitaph and fleur de lis? I was also wondering what you will be using to adhear the final mold of the headress to the tombstone; being it will be Styrofoam. Thank you so much!!
    I added a picture of the tombstone with the face. I still have a little work to do to finish her up but as you can see from the picture, it didn't turn out too bad.
