Setting-up to Cut a Recess in a Trapezoid Using the Shopbot
1,741
6
About: Daddy-O...
I recently had a need to place an aluminum panel in a trapezoid for a mantelpiece.  I decided to use the Shopbot so I could ensure a consistent depth for the recess.
The attached video shows the recess being cut.
I do my work over at the Techshop in San Jose...
Supplies:
Step 1: Start With a Trapezoid Image Which Has the Same Dimensions As the Piece of Wood
For preparing drawings for the Shopbot, I generally start with CorelDraw.  Mainly because I'm most familiar with it.
The tool I used is called the Contour tool.   I made a 1-step internal Contour, about 1/4" from the original.
Select the Object (trapezoid)  --> Effects --> Contour.   Alternatively, you can select CTRL + F9 to get the Contour tool.
Step 2: Apply the Appropriate Contour
This process is pretty straightforward, especially since I wasn't worried about the colors or gradients or anything along those lines.
With the object (trapezoid) selected, I chose the following:
Inside
Offset - .25"
Steps - 1
Then I selected Apply.
Step 3: And We Have Our New Trapezoid, a Quarter-inch to the Inside of the Original
This is the new trapezoid I was looking for.
Now, CorelDraw allows you to separate the two trapezoids, but I did not want to do it.   So, I went ahead and added a curve (set of lines) that matched the internal trapezoid to use for my eventual export.  The next step shows this new curve.
Step 4: Use the 2-point Line Tool to Make a Copy of the Internal Trapezoid
I drew lines from node-to-node on the internal trapezoid.  I changed the color to red to make it easier to see.
This curve is the shape I needed to export to VCarve to prepare a file for the Shopbot.
I could have simply ungrouped the Contour pair (probably saving some time), but chose not to do so.
Step 5: Move the Red Trapezoid to a New File, and Export for Vcarve
I opened a new file and added this new trapezoid.
I then went to File --> Export --> Save as Type --> DXF (using the AutoCad R10 option)
Step 6: I Opened VCarve Pro to Get Ready for My Drawing.
I set the following in VCarve Pro for my piece to be cut.
Job Size
Material Thickness
XY Datum Position
Units
This data matched the piece I was using - your needs may be different.
Step 7: I Imported My Trapezoid
File --> Import --> Import Vectors
I selected the dxf I created in previous steps.
Step 8: And I Prepared a Toolpath
Once I'd imported and moved the trapezoid onto the VCarve canvas, I created a toolpath.
Since I was using a 1/8" router bit, I used this info to set up the Pocket Toolpath, and carved down to 1/8".
The output file was a Shopbot Arc (inch)/with speed .sbp file.
Step 9: And I Cut My Recess.
After aligning my piece and testing the alignment with some sacrificial pieces, I was able to cut a very nice recess.
I had to use a knife and chisel to complete the corners which had a 1/8" radius, since I wanted sharp corners.
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    • IoT Challenge
      IoT Challenge
