Shopping List Holder
2,709
188
7
About: Easy and affordable DIY projects and ideas.
I normally have shopping lists all over the place and when it comes to buying what is needed something is always forgotten. I made this practical shopping list holder to hang on a wall in the kitchen using a few inexpensive supplies.
You can mount the shopping list holder on a wall close to or in the kitchen, or have it flat on a counter. The till roll you can buy at stationary stores, or at Makro. The simple design allows you to write down what you need from the supermarket and then simply rip off the slip.
YOU WILL NEED:
Till rolls
Scrap piece of pine or board approximately 200mm long and 20-30mm wider than the till roll
Aluminium or tin can 1
6mm screws [4] and optional screw rings
Picture hanger and a 16mm screw
Piece of wire
TOOLS:
Cordless screwdriver,
PSR Select or Drill / Driver and assorted bits
Dremel MultiTool and cutting disk, multi-purpose scissors, or tin snips
Needle-nose pliers
Tape measure and pencil
Find more easy DIY and craft projects on www.Home-Dzine.co.za
Supplies:
Step 1: Cut the Aluminium or Tin Can
1. For the aluminium or tin strips that hold the till paper in place I recycled a can. This was clamped firmly in place. DO wear safety glasses when cutting any metal, as the sparks can easily get in your eyes.
2. Most cans have ridges on them, and you can follow these to cut out a strip of aluminium.
3. Use multi-purpose scissors or tin snips to cut [2] straight pieces that will fit across the width of your pine or board.
Step 2: Assemble Holder
GOOD TO KNOW: Use a hammer and nail to make a hole in the edge of the strips to make it easier to screw these onto your board.
4. Screw the strips onto the board. Leave enough space at the top to mount the till roll, and at the bottom to rip off your shopping list.
5. Where the hole for the till roll will sit, drill a 2mm hole in both sides of the board. The depth of the hole should be about 40mm.
6. Cut a piece of wire that is long enough to thread through the till roll, fit over the sides of the board, and also be inserted into the holes drilled in the sides.
7. Place one end of the wire in the side and then bend over and thread through the till roll. Bend over again and force into the drilled hole on the other side. Tap with a hammer to flatten at the sides and make sure that the till roll have space to move.
8. Attach a picture hanger at the centre back and your new shopping list can be hung up ready for use.
After making the shopping list I realised that it was missing a holder for a pen or pencil, so I added a couple of cable clips to the bottom of the board.
2 People Made This Project!
  • Classroom Science Contest
  • Woodworking Contest
    Woodworking Contest
  • Party Challenge
    Party Challenge
7 Discussions
jbaxter101
2 years ago
Great idea. I used this paper roll concept on one and found that a piece of an old hacksaw blade worked nicely to tear the paper. I also use this hacksaw blade trick (fixed to the wall with a thin washer as a spacer) for tearing sheets of sandpaper in half and then into quarters.
mdaveejbaxter101
Reply 8 months ago
I did the same thing, but I saw another guy here used strip from a used box of aluminum foil. Seems handier for most people.
plowers
2 years ago
awesome idea! the only change I would make myself, is to put the till roll at the bottom, as you then limit the "wasted space" on the roll as we write from the top down.
mdaveeplowers
Reply 8 months ago
I just write from the bottom up
judypalmer
2 years ago
Very nice! We have our pencil attached by a string so that it doesn't "walk" away!
clues5
2 years ago
Very good one!
