Simple Corner Clamp Jig
20,564
445
14
About: DIY Montreal is all about woodworking & DIY projects. I post how-to videos on my YouTube channel, as well as step-by-step tutorials on my website www.diymontreal.com. Builds include mainly woodshop proje...
In my last build, I made a really large wood picture frame with splines and I thought I'd share how I made a super simple jig to clamp and align the corners during the glue up process.
_______________________
Watch the 2 minute video or read on!
Step 1: Mark Your Cuts
These corner clamps or extremely simple to make and even more easy to use. Start with a scrap piece of 3/4 inch thick wood (mine was about 10 x 7).
Mark the piece of wood so you have 4 equal squares.
Then within each square use your speed square to draw a triangle on the outside edge of the square.
Step 2: Drill Relief Holes
Where the triangles intersect, drill all the way through using either a Forstner bit or spade roughly 3/4 in diameter (it can be a bit bigger or smaller. The important thing is to make a hole all the way through.
These holes will serve as relief pockets and prevent the jig from interfering with the corners of the frame.
Step 3: Make the Cuts
Head over to your miter saw and set the blade to 45 degrees. It is very important that your 45 degree angle be accurate, otherwise the inaccuracy will carry over to your frame when clamping, and the whole frame will be out of alignment!
Tip: Use a scrap piece of wood and cut a miter. Butt the 2 ends of the cut together to form a 90 degree corner, and check it for accuracy using a carpenter square.
Cut along all the lines you traced, starting with the 45 degree cuts, then set your miter saw back to 90 degrees and make the remaining cuts.
Step 4: Glue Up
The corner clamp jigs are ready to use! Lay your frame on a flat surface and line up the corners. Gentle press the corner clamp jig into place and use a quick clamp to apply pressure. Don't overdo it- excess force will force the frame out of alignment. Moderate pressure should be sufficient. Oh, did I mention you should add glue before clamping? ;)
_________________________________
Check out my other recent Instructables:
Or head over to diymontreal.com to see all my projects!
Workshop Hacks Challenge 2017
Runner Up in the
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    14 Discussions
    ThomasBuildThis
    1 year ago
    This is a very nice idea! Thank you for sharing.
    Special~K
    1 year ago
    oooh... these are awesome! Fantastic for my newbie projects!
    Really appreciate the share & super simple instructable!
    Thank you & keep up the good work
    KenS2
    1 year ago
    Hmm, never seen this version of picture frame clamping, doesnt the inside corner triangle push the joint apart?
    shallnotKenS2
    Reply 1 year ago
    My thought too. I'd add that the clamps really aren't really helping to hold any glued face together---that is none of the forces are perpendicular to a glued face.
    Man Upshallnot
    Reply 1 year ago
    "Don't overdo it- excess force will force the frame out of alignment. Moderate pressure should be sufficient."
    Been using these for years. The only way you can beat one of these for versatility is a band clamp.
    Carpenter GuyKenS2
    Reply 1 year ago
    It would if you used only one, but when these are in all 4 corners it doesn't.
    imreprobateKenS2
    Reply 1 year ago
    Even commercially offered clamping jigs are of this general design. The angles are/provide the 'inward' pressure to the mitered faces and the smaller triangular piece merely provides a surface for the actual clamp. There 'outward' pressure exhibited is negated by the outside pieces, due in part to the 'relief' hole. As with any clamp, if used incorrectly, the joint will be sloppy at best.
    I've been using jigs almost identical to this for many years and as long as I assemble everything properly, paying attention to details, I've achieved success every time.
    Carpenter Guy
    1 year ago
    Very cool! I would almost make a groove on the outer edge of the corner clamp jig so I could hold the frame together more tightly.
    driesbessels
    1 year ago
    Thanks for the idea, I will make them tomorrow!
    Greetings from Amsterdam,
    Dries
    fjr_scoot
    1 year ago
    Well thought. Thanks!
    charlessenf-gm
    1 year ago
    You must be sighkick! I saw tour PF w/S Video and took note of your corner clamps last week with an eye to building myself a set.
    Last night, I sketched them out from memory but did not go further given the lateness of the hour.
    Having made a set that required two clamps for another project, I thought this design elegant - possibly with the addition of some fine sandpaper along the gripping edges - or thin rubber for clamping finished work. Planning on experimenting with those ideas as my mitre saw's not the most accurate tool in my shop!
    Thanks for thinking of me!
    desertwalker
    1 year ago
    So simple, I never even thought about this. Many Thanks for the heads up
    Graeme_P
    1 year ago
    Great! I've seen pictures of things like this in use before, but not how to make them. Thanks!
    jpmarth
    1 year ago
    Quick and simple. I like! Need to make some for a project idea.
