Simple Elegant Guitar Stand
94,864
747
47
I designed this guitar stand to be universal and really simple:
  • no glue
  • no screws
  • no nails
  • just one piece of wood.
In this case I used a board of oak wood, 25mm thick, about 22 cm wide and about 38 cm long.
You can use the template I made and modify it to change the size. I found that a corner of 9º works best on all acoustic guitars, I haven't tried an electric guitar yet tho.
If you decide to make your own I would love it if you'd send me a picture of it at stand@lennartdemeij.com
Supplies:
Step 1: Transfer the Template Onto Your Board
I printed my tempate on an A4 sized piece of paper and punched holes in it on interesting points so I could draw inside those holes on the wood.
Step 2: Drill Two Holes
Then I drilled two holes with a drill having the same diameter as the thickness of the board (in my case 25 mm).
I wanted to keep the holes round and just off center to ensure a snug fit.
Step 3:
I used a fine saw to work inwards from the hole to be able to make the middle cut. This did require some patience however :-)
Step 4:
I first completed the middle cut to keep the structural integrity intact whilst working on the other hole and finally the last two cuts to finish the guitar stand!
Then I tried to fit the pieces together, sanded, tried again, sanded some more and then the stand was finished!
13 People Made This Project!
  • Classroom Science Contest
  • Woodworking Contest
    Woodworking Contest
  • Fandom Contest
    Fandom Contest
47 Discussions
KS2004
4 months ago
cool
mejones645
2 years ago
add the non hook side of sticky velcro so as to not scratch guitar
gfry
3 years ago
Nice!
JoanneE5
3 years ago
My fiance' is making this tonight.
WandersonA3
3 years ago
Perfeito Farei vários pra deixar na igreja, é simples e elegante.
Corasaurus Rex
3 years ago
This is great! and the fact that its your frist Instructable I hope you do great I voted for you good luck.
cammers
3 years ago
Very nice, simple, functional. I think I will make one.
jeanniel1
3 years ago
We have a metal guitar stand, and it's hopeless. The guitar keeps tipping over sideways. I can see how this design would work with the curve of the bottom of the guitar in keeping it upright. Also can scale it down for a ukelele, too! Elegant
lennartdemeijjeanniel1
Reply 3 years ago
great idea! if you make a ukelele version, please share a pic with us here! :-)
UpCycleLivin
3 years ago
this is perfect. thanks for sharing this. I'm going to give this a try.
jetpower
3 years ago
Really nice "Why didn't I think of this?" design!
You also might like to check out the Nomadic Furniture books by Papanek & Hennessey. I still use its slot-together desk, many decades after making it in my college's woodworking work (see below for original drawing).
westislip
3 years ago
What an excellent idea for a unique gift. Would you please furnish the dimensions?? I intend to make a template so I can make several units as gifts. Once I can make one template, all I have to do is trace it and cut the un its on my band saw. Thanks.
I int
Chenkzr
3 years ago
A clever idea. Only one question: is the front coated with something to prevent scratching the instrument ???
srutkowskiChenkzr
Reply 3 years ago
Adhesive weatherstripping would do the trick.
tensegrityChenkzr
Reply 3 years ago
You could just stick some little felt pads on there, like for the bottom of furniture legs. Eight pads total would be good--four at the farthest points of contact and then two each at the interior right angles.
