Simple, Elegant Toddler Bed
42,074
760
40
About: I love writing, leather working, cooking, and playing board games. My short stories have been appeared in Spark, Abyss and Apex, Bards and Sages Quarterly, Stupefying Stories, Punchnel's, Kids 'Magination, a...
With two sheets of plywood and a handful of screws, you can make a pretty nice little toddler bed. This design fits a crib mattress (about 52" long), which will last the average toddler well into elementary school.
My toddler just turned two. He's too big for a crib, but a twin-sized bed takes up too much space in his room. There are a lot of toddler beds you can buy that are low to the ground, but I wanted something with A) storage underneath and B) enough height to make diaper changing easy. This is what I came up with.
Supplies:
Step 1: Plan Overview
The basic design is pretty simple. There are five plywood panels (two sides, two headboards, and a middle). You'll cut them out, use a router on the edges (if you want), sand, finish, and screw them together.
Supplies:
  1. Two 4x8' sheets of 3/4" plywood
  2. 1-1/4" wood screws
  3. 1-3/4" wood screws
  4. Polyurethane, paint, or another finish (optional)
Tools:
  1. CNC router with a 4x8' bed (optional*)
  2. Hand drill
  3. Measuring tape
  4. Table router (optional)
  5. Sandpaper
  6. Paint brush
*I used a CNC router because they have one at the TechShop I'm a member of (I made it at TechShop, techshop.ws/). A CNC router is a robot-like machine that uses an end mill (similar to a drill bit) to cut out whatever design you put into the computer. Because of this, my design isn't optimized for cutting by hand. However, if you don't have access to a CNC router, you can still make this bed. Just simplify (remove unnecessary curves and holes) and use a hand-held rotary saw and/or band saw. I'll provide dimensions in the next step.
Step 2: Cut Out the Pieces
There are two patterns which correspond to two sheets of plywood.
I have attached the patterns as vector pdf files. You can use these to generate toolpaths for the particular CNC router and end mill you have access to.
I have also attached V-Carve Pro files of both patterns. These hold the information for the toolpaths I used (with a 3/8" two-fluted end mill). If you have V-Carve Pro, you can open these files and export the toolpaths directly to whatever file type your CNC router requires.
Finally, I have attached a pdf ("layout.pdf") with basic dimensions. You can use this to cut the pieces out by hand if you wish.
NOTE: If you're using a CNC router, cut out the holes first. If you cut out the parts first, they may move around while you're trying to cut out the holes.
Step 3: Smooth the Edges
You can simply smooth the edges with sandpaper if you want. I decided to use a table router and a 1/4" roundover bit to put a nice radius on the edges that would be most exposed.
Step 4: Cut Scabs
To help screw everything together, I cut some plywood scabs. To do the same, you'll need:
  • Two scabs that are 48" x 1.5"
  • Six scabs that are 24" x 1.5"
The simplest way to cut these is on the table saw. Cut five 1.5" strips that are 48" long (the width of your plywood). Then cut three of these in half. This gives you two 48" pieces and six 24" pieces.
Four of the 24" pieces will be used on the four vertical corners of the bed.
Two 24" pieces and two 48" pieces will be used to hold up the center piece (which holds the mattress).
Step 5: Install Scabs
Install the scabs using the 1-1/4" screws. Install screws from the scab side (the inside or hidden side of the bed). Since you have two 3/4" pieces of plywood, the 1-1/4" screws won't quite go all the way through (which is a good thing).
As shown in the first picture, each side piece needs two 24" scabs (flush with the edges) and one 48" scab (with the top edge 27-1/2" from the floor).
As shown in the second picture, each head board needs one 24" scab. The top edge of the scab should be 27-1/2" from the floor.
Step 6: Sand and Finish the Pieces
I used an orbital sander to smooth out the routed edges. I also used it to get rid of scuff marks I'd made while handling the sheets of plywood.
I then finished all the plywood pieces with three coats of clear, water-based polyurethane.
NOTE 1: Water-based finish tends to raise the wood grain. This was especially true on the edges of the plywood. After the first coat of finish, the edges were very rough. After sanding them and applying the 2nd and 3rd coats, however, they ended up pretty smooth.
NOTE 2: For more detail, see my instructable on Refinishing Old Furniture, which has a ton of information on types of finishes, technique, etc.
Step 7: Assemble
Use the longer (1-3/4") screws for the assembly.
  1. Stand the two sides upright. Place the middle on the 48" scabs. Screw down through the middle into the scabs.
  2. Attach one head board. Screws should go into into the scabs on the bottom (black arrows) and into the side piece near the top (red arrows).
  3. Attach the other head board (aka the foot board) in the same way.
Optional: if you don't want any screws showing, you could attach the side pieces by screwing through the scabs and into the head board (i.e. screw from the inside toward the outside). In this case, a wider scab (maybe a 2x2x24" piece) might suit you better.
Step 8: Enjoy
Now you have a solid, nice-looking bed for your toddler. There is a slight railing to keep him or her from rolling off, but of course use judgement with your kid's age and sleeping habits.
Sleep tight!
Woodworking Contest
Runner Up in the
Woodworking Contest
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    40 Discussions
    mdhandyman
    4 years ago
    Thanks so much for sharing your very well detailed instructions & files! I made a set of 2 for my grandsons at TechShop. One tweak I'd do in the next iteration might be to open up the head/footboards in the lower area. otherwise, it's a great design. I tried using pre finished birch plywood to save time& materials. I had problems with the outermost layer chipping & peeling off! So buyer beware...shop for the good stuff and ask questions. The cnc bit may not have been sufficiently sharp, also. But I feathered out the chips with the sander and I'm happy with the results, as are they! Also, for the finish sanding in the slotted areas, I used a small "drum" sanding attachment on my cordless drill. Made the job less tedious ;-) Thanks again!
    solobomdhandyman
    Reply 4 years ago on Introduction
    Very cool! Thanks for posting those pictures. Good idea on opening up the head/footboards.
    dlong
    10 days ago
    This is a great-looking bed. I had some trouble with the files, since our CNC does not use V Carve Pro.
    I made a new .DXF and joined the shapes together, also adding a "pocket outline" and the blocking. I pushed the sheets 1/4" from the edge so I am getting a nice clean cut from the router instead of a factory plywood edge, and since our primary mill is 1/2" I spaced the parts 5/8" apart so that I am getting a decent edge from the compression cutter on both sides of the plywood. Finally, I measured our (cheap Target-purchased) crib mattress and it was only 27-1/4 so the DXF file below has a couple pieces shrunk to fit the smaller mattress size. Check your mattress before cutting!
    From the DXF file I was able to import into our CAM software and assign tools and depths for each layer. If anyone else is trying to do this from CNC, I hope the files here are helpful.
    A big huge THANKS to @solobo for the design and the original files.
    solobodlong
    Reply 9 days ago
    Thanks for the files dlong, looks great!
    kbbaktha
    4 months ago
    Excellent and very elegant design and build instructable. My grand children are 8 & 5 years, will this design and build material would be strong enough for the older children till they become ten or so?
    solobokbbaktha
    Reply 4 months ago
    Probably strong enough, but not big enough... the bed is only four feet long (already too short for my 6 year old)
    DanaF406
    2 years ago
    I'm going to make two of these! I don't have access to a CNC machine, so I will use a router...for the first time. Would you recommend cutting out the plywood with a jig saw or skill saw, and then routering the edges; or cutting with the router? With a 1/4" roundover bit, is it better to use a fixed or plunge router? I can borrow either/both. Any advice appreciated!
    soloboDanaF406
    Reply 2 years ago
    I would recommend cutting everything you can with a skil saw, then using a router or jig saw (both of which will be a lot slower) for the tight turns. Fixed vs plunge router: I'm no expert, but I think you'd want the plunge router if you need to "plunge" (i.e. start in the middle somewhere). Alternatively, you could use a drill to make a starter hole and then use a fixed router from that starting point.
    ZaneEricB
    Simple and straight forward! I dig it. I am planning to make something very similar to this except the "landing" will not be a bed, it will be just an indoor playhouse...so i guess i will need more support...but great design and build!!
    bonjobish
    5 years ago on Introduction
    Fantastic job ! 10 out of 10 for you ! maybe a curtain track and curtains for hide-a-way for a boy or a girl would be a great addition and of course Handy for a quick tidy up too :)
    mathieulj
    Very nice result. Unfortunately my 3 year old still falls out of bed regularly so this is really not an option for us but I am definatly bookmarking this for future reference :).
    tim_n
    Looks neat - couldn't trust my son in it as he moves so much I'd be hearing a thud and scream every 10 minutes.
