Simple Homopolar Motor
49,674
318
26
About: YuKonstruct is a non-profit society which provides an enthusiastic community of makers and entrepreneurs affordable access to space, equipment and knowledge. This community serves to embrace the individual a...
The first homopolar motor was demonstrated by Michael Faraday in 1821. He was experimenting with magnetism and electricity when he discovered the first circular force then known in nature.
This simple motor is a great beginner project for young makers!
YuKonstruct is the first makerspace in Canada's north. Our mission is to provide access to shared space, quality tools, available expertise, and a collaborative environment to help makers build anything!
Step 1: Materials
Materials needed:
  • A few neodymium Magnets
  • AA battery cell (or use a C or D cell)
  • Bare copper wire, around 30 cm (12 inches) long
Step 2: Add a Dimple to the Battery
Begin by taking the AA battery and make a small dimple in the cap on the positive end.
To make the dimple, use a small nail, screw driver or even a multi-tool.
Be careful not to strike the battery too hard, just hit it with enough force to leave a small dimple visible in the cap. Don't hit it hard enough to break through the end of the battery, or crush the cap.
Step 3: Place the Battery on a Stack of Magnets
Place the battery on top of a stack of small neodymium magnets, stacked high enough to leave a surface for the wire to contact.
Step 4: Prepare the Wire Coil
Inspect one end of the wire, and if it's cut flat, cut it on an angle with wire cutters, or a multi-tool, to sharpen the wire to a point.
Using the sharpened end as the beginning, form a vertical loop, then begin forming the shape of a spiral. Form the coil either clockwise or counterclockwise, and make it two to three times the diameter of the battery, finishing off the loop in a smaller diameter.
Place the pointed end in the dimple at the top of the battery and if the coil is too short, or too long, you can stretch or squeeze the coil until it's the proper height.
Let the coil hang freely and see if the free end of the wire contacts the magnet below the battery.
If it does, a current will pass through the wire, and if the wire has a light enough contact with the magnet, the wire will begin to move, either clockwise or counterclockwise, depending on the polarity of the magnets.
Step 5: Watch It Spin!
Trouble-shooting:
If the coil does not move, you will have to adjust the balance of the coil by tweaking the shape of the bottom of the coil, or move it closer to the center of gravity, or further away, until the hanging wire gently brushes the surface of the magnet.
Once this balance has been achieved, the motor will begin to rotate.
By reversing the polarity of the magnet, by flipping it over and placing the battery on the opposite end, the motor will change the direction of rotation.
One direction of rotation or the other could work better to make the motor spin, and experimentation will show the best way to place the magnets. With a well balanced coil the motor should work fairly well in either direction.
Note: The battery will heat up if the motor stalls as it then becomes a direct current short circuit. Also, if the motor is running for too long the battery could heat up. Please monitor this experimental motor carefully.
4 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
26 Discussions
jgerry22
2 years ago
awesome!!!!!!!!!!!!!!!!
Starlyte
2 years ago
Nice, and the prospective utilisations are flooding in ... :D
Keywizard
2 years ago
Dope was a chemical suspension used to make flying model airplanes in the early twentieth century. The original term doop meant a suspension of material in a liquid medium (glue, paint, soup, and medical concoctions were called doop mixtures but in the early 1900's Dope usually meant a specific type of mixture). We would build a balsa wood frame, then cover the plane with a special paper that was very thin and made with silk threads, that, when covered with Dope would tighten up and turn rigid. The Dope was made with chemicals that were poured on cloths and then sniffed by teens looking to catch a buzz. These chemicals caused lung and brain damage when breathed repeatedly, causing dizziness, loss of memory, and general cognitive damage. This led to asking people who made less than intelligent statements, "What are you, a dope?" indicating one who got Doped Up by sniffing paint and dope and other doops. When certain chemicals became illegal to teens, making certain paint and other products hard to get by non-adults other products were developed for model plane building. Now we use shrink to fit plastics and laser cut balsa wood to build model airplanes.
By the mid twentieth century the term dope had come to mean anyone who had a lower than normal mentality, or any material used to produce a buzz or high, specifically marijuana and illegally acquired and utilized drugs. In the late twentieth century the use of steroids became illegal in commercial sports, and because there were many who used steroids illegally, it also became known as doping because it became known that too much steroids again limits mental capabilities.
Eventually the people who used illegal substances were called dopes, and using the substances became known as doping. Those who sought out the most mind affecting chemicals and drugs as a form of entertainment would call high quality or high strength drugs and chemicals as "The Dope" indicating the highest form of the particular chemical or medication. To the under society of people who use these products "The Dope" has come to be used to indicate anything that is desirable in the best quality, or highest desirability.
PaulGetsonKeywizard
Reply 2 years ago
Thanks, that was informative. I knew a lot of the information about airplane dope. I had found some when I was a teen that someone was throwing out in their trash. I kept it for a while, but I never did use it. Eventually, when I built some tissue covered balsa model planes, I just made a solution of white glue diluted in water for my 'dope'. It worked rather well to stiffen and strengthen the tissue, but was probably much heavier than using the proper 'dope'. The models were mainly for display, and not to be flown.
WannaDuino
2 years ago
DOPE means verry cool
thats street Slang (street Talk)
g4ipzjabal23
Reply 2 years ago
What is "It is dope" supposed to mean?
g4ipzbillbillt
Reply 2 years ago
Ah well. My fault for having been brought up speaking a version of English that everybody can understand without instructions :-)
Chefmike66g4ipz
Reply 2 years ago
well, no one is born speaking any language... You have to learn it somewhere! :)
Angry_Skorpiong4ipz
Reply 2 years ago
I was a prison guard for 20 years. "It is dope" is ebonics for "that is really cool". }8-)
wearetheg4ipz
Reply 2 years ago
If you are junkie it means a lot :)
Linksepg4ipz
Reply 2 years ago
http://lmgtfy.com/?q=define+dope
jwilliamseng4ipz
Reply 2 years ago
"Dope" is slang for "excellent, cool, or very good"
technofossil
2 years ago
Love it. It doesn't do any real work but it's still great. Thanks for sharing.
PaulGetson
2 years ago
Yes, I've made a few of these. You can also make different shapes for the armature, and not just a coil.
