Simple Shortcuts Keyboard
2,548
51
8
About: Innovative Projects, Diy's, Life Hacks
Lots of people could save hours, just by making their daily computer tasks automatic or easier.
One of the ways to be more productive is by using shortcuts.
Let's make a shortcut keyboard out from a USB num pad.
What's needed:
  • USB num pad or a keyboard
  • Label paper
  • A free program called "HID Macros"
"HID Macros" is used for this project, because it can identify different USB keyboards.
Because of that function, we can use a USB Num pad and convert it to a shortcut keyboard.
Keyboards will not interfere with each other. In other words, if you set a shortcut to Num pad's key Nr4, your computer keyboard's key Nr4 will not run the shortcut. I will works a a normal button.
Step 1:
  • Measure the size of keys and make the labels you want.
  • Print out the labels and cut them out.
  • Stick the labels to the keys.
Step 2:
  • Plug in your USB num pad
  • Download a free program called "Hid Macros"
  • Run it and create a new macro
  • Click on "Scan" button
  • Press a key that you want to assign to the shortcut
  • Select "Run Application"
  • Find the program you want to open (Notepad) and click on "Open"
  • Click on "Save configuration" and then on " Compile All" to load the script.
Now when you'll press number 4 on your shortcut keyboard, Notepad will open.
If you will press number 4 on you computer's keyboard, it will not open "Notepad", it will work as a normal key.
In this example I chose to run "Notepad".
Check out "Hid Macros" help file or the web page for other script examples.
You can send keyboard commands or even mouse clicks.
The only thing I am not sure about is the label paper. It does the job, but with the time it could wear off.
Any ideas on how to make the labels coffee spill proof? OK, it's not a good idea to spill the coffee on any keyboard, but you get the point. Labels need some extra protection. Nail vanish?
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    8 Discussions
    anfil89
    2 years ago
    This doesn't work in Chrome, Firefox, etc, in Windows 10. Any idea why and how to solve this?
    The HidMacros dosn't recognise the event in those software's... I check it in the "Test area - alst input event" in HidMacros :(
    HugoM38
    3 years ago
    I love this idea and really want to make it but I downloaded the software and there is no "Save and Configure" button as there is with the tutorial. Obviously not allowing me to save and configure :(
    Any help appreciated :)
    Yonatan24
    3 years ago
    Great! I will use this to play "Ouu Yeah" over and over again ;)
    surya raju
    4 years ago
    can I please know which software you used to create the labels?
    settingsdestroyer
    4 years ago
    perhaps little slide preventer like those rubber thing on bottom of furniture or on cabinet doors sometimes?
