Simple Lightweight Hexacopter (A2212 Motors, 30AMP ESC, AIOP FC, 3000mAh 11.1v Lipo)
2,979
56
12
About: I love making things. I have for as long as I can remember liked to make stuff. Now days I have two kids (Thomas and Emma) and most of the things I do are safe for them! I love electronics and Microchips, I ...
Here we have instruction for a very simple and relatively cheap Hexacopter. This is a very easy method of construction using just basic marking out tools a hacksaw and a drill.
The parts are as follows:-
1 off 12” * 6” 1.6mm glass fibre sheet.
3 off 500mm 12mm Diameter carbon tube (eBay)
6 off aluminium clamps for the above tube (eBay)
6 off motor mounts for 12mm carbon tube (eBay)
For all the eBay items if you search for “12mm carbon tube” you should find them all.
6 off A2212 1000Kv 13 turn Brushless motors and 30A ESC to suit. I buy these as a kit which includes the motor, ESC and propeller adaptor and the 1045 propeller (one of each clockwise and anti) (eBay)
1 off AIOP CRIUS (All In One Pro) Flight control board.
1 off GPS board (optional).
2 off 55mm * 55mm copper clad board for shielding EMF’s generated by the motor wires which effect the digital compass.
1 off 300mm Velcro strap to hold battery.
400mm 14AWG red and black silicon wire
100mm 12AWG red and black silicon wire.
1 Deans plug (or whatever fits your Lipo’s).
8 off 20mm female-female M3 spacers
4 off 20mm female-male M3spacers.
4 off 5mm female-male M3 spacers.
M3 screws and Nyloc nuts.
Supplies:
Step 1: Construction
This is a Hexacopter configured to a “+” you can turn the Flight control board 90 degrees then fly it as a “X” then the centre fibre glass sheet would be width way (not sure if that makes sense?).
Part 1
Start with the fibre glass sheet, this comes 12” by 6” but I cut it down to 100mm wide. Then mark out and drill all the holes as shown in the pictures, all the holes are drilled 3mm. If you can’t find the same tube mounts as I have used then just adjust the drill as necessary, the main dimension is the tubes should be mounted with 265mm centres. Then mount the 4 corner tube supports and fit the 12mm tube which should be cut down to 434mm. (the important dimension here is the distance between the centre of the two motors on each tube (459mm), in my case the motor mounts take up 12mm each. ) all the screws are M3 and nyloc nuts are used. The centre carbon tube should be a little more than 500mm (506mm) but since the tubes come 500mm it has to do and the centre tube is mounted on top so the propellers could overlap (but they don’t) have a look at the drawing to see where the dimensions come from.
Step 2: Wiring and Flying
Now you have the 3 tubes in place you can fit the 6 motors and wire up the motor wires to the ESC’s make sure you have 3 that run clockwise and 3 that run anti-clockwise. Make sure when you mount the motors that you alternate them clockwise then anti-clockwise and when you mount the Flight control board then you should check that the front motor runs ANTI-CLOCKWISE.
Next the Flight control board and GPS if you are fitting one. I like to use stand-off to fit these items and I also use copper clad below and above the flight control board to shield the board against the motor wires. (More on that later). Check out the picture to see what bits I used to mount the flight control board and GPS.
Then I wired up all the power cables to each ESC. I choose to connect the 3 ESC’s at each end then run a cable to the middle and then to the main battery connector. The ESC’s are wired using 16AWG, I then used 14AWG wire to connect the 3 at each end and 12AWG for the battery. I use NON INSULATED in line crimps and solder all the connections together then heat shrink over the joints. What I wanted to avoid was putting a power distribution board under the middle, so by doing the connections at each end then running the cable down the edge I should have a happy compass on the FC. Oh and by the way I didn’t have any 14AWG black wire so had to use red for both cores.
Once you have done all the power cables you can connect all the ESC signal wires to the FC and then connect the Receiver.
A few tie wraps to keep everything in place is all that’s left to do.
The weight minus the battery is 950grams!
If you wish to add an undercarriage you can pick them up from eBay cheaply, if you managed to find the same one as me then it will mount via the holes drill already. The position of the holes was chosen to make sure the battery fits in-between the fixings.
Flying this hex is really fun, it is so light it takes off with very little power and is very manoeuvrable, my test day wasn’t ideal as it was very windy but hopeful the wind will drop tomorrow and I can try out the GPS.
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    • Classroom Science Contest
    12 Discussions
    manua8
    3 years ago
    Nice :)
    seem very stable.
    I will do it, what do you recommand as a battery ?
    mr_fidmanua8
    Reply 3 years ago
    I have been flying this model for the last few weekends, and I have been using one 5000mAh 11.1v lipo it gives a good long flight time and the isn't a problem at all. Its a really good model to improve my flying, and I am still struggling with flying nose in but getting better with each flight.
    Duaa Jay
    3 years ago
    Hi there!
    can I add a mini WiFi camera to this hexcopter for making it spy hexcopter?
    and please, can you post the video of your work on dailymotion?
    mr_fidDuaa Jay
    Reply 3 years ago
    Currently I have a small camera mounted so I can try FPV, I also added a OSD (on screen display) so I can get remote readings of battery and number of satellites etc. once you have a good platform you can add what you want.
    Duaa Jay
    3 years ago
    Btw it's amazing :)
    (Y)
    Lashway
    3 years ago on Introduction
    what's the load capacity? I've been looking for a way to carry something a little heavier than a go ptro, but it never occured to me to just add more propellers.
    mr_fidLashway
    Reply 3 years ago on Introduction
    That is a very good question and a perfect excuse to go and try! (the kids have gone to bed and there is no wind!)
    So I got video of this test and you can see it here.
    https://youtu.be/aYzfGdYLI9s
    Basically the copter with undercarriage weighs 1171Grams add the battery (3000mAh) which is 225grams total 1396grams. Then attach a 2litre bottle and see how much you can lift!!!! after a couple of tests I weighed the bottle and it was ok with 1100 grams. Mind you I don't think the battery will last long as you may hear!!!! (motors screaming)
    Lashwaymr_fid
    looks like that is ewuivalent to some $600 quad copters, what do reckon your final costs were?
    mr_fidLashway
    Motors, ESC’s, propeller’s, prop adaptor £60.
    (£10 per kit) (Search
    eBay “a2212 esc 1000kv”)
    Fibreglass sheet about £7.50
    Carbon fibre tube 12mm 4(1 spare) off 500mm lengths. £16.
    (Search eBay “12mm Carbon Fiber Tube”)(fiber not fibre!!)
    Motor mount were expensive at £3.60 each Total £21.6
    (search “12mm carbon mount”)
    Cheaper plastic ones at about £6.00 for 8.
    (Search “12mm Brushless Motor Holder” for plastic)
    Tube clamp/mount 6 required mine were expensive and I can’t find the part anymore! But alternative ones are about £8 for 8.
    All In One Pro flight control board with GPS and extender board £43
    Undercarriage kit £10 (landing skid)
    All in that’s about £156
    You need to add your own battery and receiver.
