Single Strand Ringbolt Hitching
517
17
Published
Introduction: Single Strand Ringbolt Hitching
An attractive way to cover a ring or other closed object
Step 1:
I used a 1 1/2" O.D. iron ring in this project. I used 7' of 3/16" cotton sash cord. I left about 16" of cord Standing End which will be used after the ring is covered. I took the Working End from left to right through the ring and made a clockwise path around the Standing End
Step 2:
Bring WE through the ring from left to right and . . . . .
Step 3:
. . . underneath the two strands of the crossing you made in step one. Keep tightening the knot as you go along.
Step 4:
Repeat steps two and three until the ring is covered.
Bring the WE through the ring from left to right.
Pull slightly on the bight "A" that the SE goes through to slightly enlarge it
Step 5:
Bring the WE up through that bight
Step 6:
Bring the WE under the two strands of the last crossing point
Step 7:
And down through the bight
Step 8:
Take the SE to the right out of its bight
Step 9:
Pull on the SE To tighten the bight. Pull on the SE to complete the knot.
Step 10:
At this point the knot is complete.
You can cut the ends close as in the white cotton example. (you can see the end a little to the right of 6:30. A dab of clear glue will prevent the ends from undoing. Melt the ends with a flame if you use synthetic cord.
You can also finish by using the two strand closing knot of your choice. The diamond knot is a good choice. In the yellow example I used the crown and diamond
https://www.instructables.com/id/Crown-and-Diamond-Zipper-Pull/
In the blue example I made what appears top be a 4 Bight, three lead Turks head knot . . . . . . .
Step 11:
I covered step by step how to do this in the Instructable,
https://www.instructables.com/id/Single-Strand-Lanyard/
The above synopsis shows how to use it in this situation
    • BBQ Showdown Challenge
    • Backpack Challenge
      Backpack Challenge
    • Stick It! Contest
      Stick It! Contest
