Small Photobooth
30,437
210
19
After making a photobooth this summer from these instructions portable photobooth I wanted a more mobile and smaller booth but still be able to use a DSLR.....
Supplies:
Step 1: Step 1: Parts
For the photobooth I used:
Enclosure:
Front and back - 4mm MDF (laser cut from the illustrator template that is named frontbackipad.ai)
Sides - 18mm MDF (17cm wide)
Corners - balsa wood 3cm x 3cm (or various sizes)
3mm countersunk screws
Hardware:
Arcade button - Green
Lock - with key
Camera - I used a Canon 650D / Rebel T4i , with magic lantern installed (for intervalometer)
Lens - Canon 15-85mm
Flash - Youngnou 560-II - or any flash with a sync input
Sync cable to flash - cable
Hot shoe adapter - shoe
Eye-fi card - card
Ipad air
Beauty dish - 16" with s-mount kit
Speaker stand 35mm tube - any or
Speaker stand top hat 35mm - top hat
16mm metal rod for fastening beauty dish
2x hinges any type
Camera mount head, I had an old Manfrotto 486RC2 that I wasnt using
2.5mm stereo jack
some 2 wire cables for the button
Tools and materials used:
Miter saw
Band saw
Cordless drill and various drills
Countersunk bit
Wood glue
Soldering gun and solder
Heat gun
Orbital sander
Sanding paper - 120, 240, 400.
Primer filler
White spray paint
Polyester putty
Step 2: Step 2: the Build
After having the 4mm MDF laser cut from the file in part 1 you can measure the lengths you need for the sides, bottom and top. (first two pictures are of the wrong front, I used a microsoft surface first, but changed to ipad)
Drill holes for the screws, you have to drill the whole way in because mdf can break up if it is not pre drilled.
Use a countersink bit so the screws are easily hidden afterwards.
When the sides, bottom and top are completed you can then begin forming the corner curve from the balsa wood.
I like to cut them into strips, glue them to the sides, after the glue is dried it is really easy to sand the balsa down.
Drill a hole in the bottom for the speaker top hat, I used a 38mm core drill for that, measured in the middle.
After you have sanded the balsa down you have to close it up with polyester putty or it will absorb all the paint and primer and leave a rough surface. Also fill all holes where the screws are.
Sand all the corners and holes until there are no blemishes or scratches and finish with 400 grit sandpaper.
Step 3: Step 3: Paint
I am no expert on painting, but to get the best paint surface you have to sand everything down to at least 400grit.
Spray on a surface primer filler, sand that also down with 400grit. Remove all dust and try to use a dust mask and enough ventilation when spraying the paint. Just follow the instructions on the can.
Step 4: Step 4: Interior
It all depends on what camera you are using, but the hole for the front is 80mm wide so make sure your lens fits through that. You can see what kind of bracket is built for the camera to stand on the pictures
So that the photobooth would not rotate on the stand I drilled a hole on the side of the hat, put a thread bit on and an knob to fasten.
To solder the button to the 2.5mm jack I followed these instructions link
To fasten the ipad is illustrated in the picture. Used some balsa wood, measured the thickness of the ipad, glued 3 pieces together so they form a brace that holds a wood lenghtwise across the iPad.
Step 5: Software, Settings and More
To receive images from the eye-fi card, I am using shuttersnitch, it has alot of features, a great image mask / overlay, can send to facebook, flickr and more, great for browsing pictures, has a filmstrip or can hide it....
Settings for the camera:
iso 400
f 7.1
shutter speed: 200
Manual focus set to 1.5 - 3m
turn off image stabilizer
flash 1/4
Magic lantern settings:
Magic lantern has a built in intervalometer that has many settings, I have it begin the process when the focus button is pressed ( as described when connecting the 2.5mm stereo jack) takes a pic after 5sec, then after 3sec..
I probably left out some steps and information, usually when I work I do not write things down so its mostly just from memory. If you have any questions I will try to answer as best I can.
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    • Party Challenge
      Party Challenge
    19 Discussions
    VinceP3
    Question 6 months ago on Introduction
    Hi, would this still work with a surface pro?
    jimmypat
    3 years ago
    Great project! Any idea what zoom level you set your lens to? Thanks!
    jimmypat
    3 years ago
    vishcolorseamster
    Reply 4 years ago
    How did you attach the light top and tripod base. What hardware is required
    deadduckvishcolor
    Reply 4 years ago on Introduction
    Hi, for the light top I used a 16mm diameter and 15cm long steel rod, drilled a hole in the middle and tapped the hole for 6mm screw thread.
    (https://www.instructables.com/id/Tapping-screw-threads/)
    The tripod base is a speaker stand top hat like in the description. It has screw holes.
    Picsanddeadduck
    Reply 3 years ago
    Hi, I have made a photo-booth and use a speaker stand and a "top hat" inside too. It is very sturdy, but it so easily rotates. Do you have this problem and if so, how did you fix it? My "top hat" is cast iron so I don't think it can be drilled.
    deadduckPicsand
    Reply 3 years ago
    It can be drilled easily and tapped, or you can use the KM ringlock system to fasten the booth. http://produkte.k-m.de/en/Speakerlighting-and-monitor-stands-and-holders/Accessories-for-speaker-stands/21441-Adapter-sleeve-Ring-Lock-black
    Picsanddeadduck
    Reply 3 years ago
    Thanks. I love the look of that ringlock system. Sadly I built it with the 38mm hole for the larger stand and that ringlock is for the 33mm size. I will see about getting the top hat tapped and getting a knob to tighten it. What size would you suggest?
    Picsanddeadduck
    Reply 3 years ago
    thanks. I'll see about getting a knob with an 8mm thread, it would be handy not to need a wrench to tighten it.
    KotoOverMiguelT18
    Reply 3 years ago
    it seems that it is using and eye fy card as you can see on the website of shutter snitch
    ecytam
    3 years ago
    Nice Project! Im wondering, does the ipad show / mirror the viewfinder? Or does it just preview the image after the photo is taken? thanks!
    KotoOver
    3 years ago on Introduction
    Hello!
    Very very nice project! Only point is that I don't understand how you deal with the button actually... could you please provide more details on this part, how is it linked to the Camera?
    Thanks in advance!!!
    acoens
    Great project! I like your take on it and I'm happy to see the idea take different forms.
    Thanks for linking back to mine for reference :-)
