Snuggly Heating Pad
2,176
26
About: Art Teacher, Artist, and Maker - Follow me on Instagram to see what I'm working on before it hits Instructables.
How wonderful is it to snuggle up with something warm? With this adorable microwave heating pad, you can get cozy in under 5 minutes. Put it at the end of the bed for warm toes, behind your neck after a long day, on an upset tummy, or just pretend to have a significant other sleeping beside you at night.
Materials and Tools:
black fleece
white/cream wool felt
black thread
sewing machine
scissors
straight pins
rice
Step 1: Test Your Fabrics
Put a small piece of your fabrics into your microwave and set for 3 minutes. Keep an eye on it. If it melts or burns, pick another fabric.
You need a fabric made in large part by natural fibers.
I'm using the standard fleece you can get at any fabric store.
Step 2: Make a Pattern
Draw out your design on paper, making sure to add a 1/4" to the outside edges.
Mark on each pattern piece how many of each piece you'll need.
I needed 2 body pieces, 6 claws, and 4 of each arm, leg, and ear pieces.
Step 3: Cut Pattern Pieces
Cut out the pattern pieces and pin then to your fabric. If you need at least 2 of that piece, fold the fabric in half to cut two at once.
Cut out the fabric along the edges of the pattern, and repeat until you have all the pieces you need.
In addition to the pattern pieces, I cut eyes out of wool felt.
Step 4: Add Details
Pin the eyes onto the front body piece.
Use a tight zig zag stitch to sew around each of the eye pieces.
Step 5: Sew Extremities
Place the claws between the two halves of each arm piece as pictured with the front of the fabric facing inward.
Pin them in place, and sew around all edges except the end that will attach to the body.
Turn them right-side-out.
Sew the ears and legs inside-out. Turn them right-side-out.
Step 6: Add Rice to Extremities
You can choose how much rice to add to the arms and legs, but I chose to just add enough to give them a little weight.
Add rice to each arm and leg before stitching them shut.
Stitch the ears shut.
Step 7: Sew It All Together
Your going to sew the body inside-out.
Pin each arm, leg, and ear in place on the inside of the back piece with the back piece face-up.
Lay the front piece on top, face-down.
Pin the edges of the front to the back.
Sew around the edges, leaving the space between the legs open.
Turn it right-side-out.
Step 8: Finish Up
Fill half the body with rice.
Hand stitch the space between the legs tightly as shown.
Step 9: Enjoy!
Warm your new friend in the microwave for about 3-5 minutes and snuggle!
Warm and Fuzzy Contest
First Prize in the
    • Paper Contest
      Paper Contest
    • Pie Contest
      Pie Contest
    • Organization Contest
    3 Discussions
    audreyobscura
    18 days ago
    Eee! This is such a cute idea! Great work! I'm sharing this one with a pal who has a dog that needs a heating pad for an achy hip, but hates the actual heating pad - maybe a crafty project like this will do the trick instead! Thanks for always such amazing projects <3
    skrubol
    18 days ago
    I'd avoid microwaving just a small scrap of fabric on its own. On older microwaves especially, running them basically empty can damage them.
    Whitney Fabre
    19 days ago
    This is so funny! What a cute rendition on a regular neck warmer.
