Sound Flipping Headphones!
7,450
168
16
About: I made a book with some new projects in it! It's called Marvelous Makeable Monsters. Check it out here: https://amzn.to/2xN1uWj The Oakland Toy Lab is a community-based wonder lab for students to build, ti...
Haven't you heard? These sound flipping headphones will turn your world of audio in to just plan odd-io. Left is right, and right is left, and you'll find that conversations, ambient noise, snaps and claps, all seem to come from invisible sources on the wrong side of your body. With this easy to make science set, you won't just flip your hearing, but the fashion world, too! They actually work, and are actually wonderful.
  • What: Sound Flipping Headphones
  • Where: Over there! Wait, no, over there!
  • Concepts: sound, perception, waves, physics
  • Cost: ~ $5 with old hearing protection, $15 if bought
  • Time: ~ 45 minutes
  • Materials:
    • Ear Protection (construction grade works great)
    • Sump Pump Tubing (available at hardware store)
    • Two Funnels (any size)
    • Zip-ties
    • Duct Tape
  • Tools:
    • Drill Press (if available) or Drill
    • Scissors
    • Hand Saw
    • (though pictured, glue not necessary)
Prosthetic-altered perception has long fascinated, well...everyone! Besides the large fields of corrective devices like glasses and hearing aids, there have been famous musings such as upside-down glasses, a smell printer, giant ears from World War II, all in the amazingly complex world of perceptual adaptation. I was inspired by exhibits I saw in the Exploratorium to this effect, and wanted everyone to be able to make this on their own in classrooms and at home.
Let's FLIP OUT!
Step 1: Drill Those Headphones
First up, take out the insulation in your headphones, and save them. Find a drill bit that is the same diameter as your sump pump tubing (ours was about 1 1/4"), and drill in to those hearing protectors. I tried for a second to do it with a hand drill, but found using a bracing jig on a drill press to be way easier. Drill lightly to avoid cracking, and whipping around your headphones. At the end, use a metal file to smooth out some of those rough edges.
Special bonus if your hearing protectors come off the headband! This makes it a lot easier to drill.
Step 2: Insert Ear Tubes
Push the tubing into those ear holes. If you cut it just right, you can use the ridges to help lock it in place. Cut a length of tubing for each (mine were about 20"), and use some duct tape on the outside to keep it in place. If you have curve in your tubing, line it up, so that it will go up and over the headband.
Step 3: Cut Listening Holes
Take your insulation, and cut holes in the center so that what comes down the tube (sound) can go straight in to your head. Then stuff the insulation back in to your headphones. This will help block out other ambient sounds, too!
Step 4: Re-Connect and Correct!
If you took your headphones off the headband, replace them now so that the tubes point upright. Fold the tubes over the headband, and check to see if the tubes are the right length. I cut just a little bit off of both tubes so that the ends of the tubes could reach roughly to directly above the opposite ear.
Now is actually a fun time to try them on, even with the tubes flopping around.
Step 5: Add the Funnels
Funnels will help you hear more than the tube alone. Cut your funnels with a hand saw (I used a small plastic saw), so that the cross-section hole is just smaller than the sump tubing. You don't have to be too exact here, and can correct a lot of things with duct tape at the end. Repeat on both sides!
Step 6: Zip Tie and Get Pumped!
Fold the tubes over so they are facing in opposite directions. Bundle them and zip-tie them to the headband in two different places. For mine, I had to use two zip-ties chained together. The ridging on the sump tubing give excellent valleys to hold the zip-ties in place. After you're all set, cut off the extra bits with a pair of scissors.
Step 7: Flip Your Sound. Flip the World.
Get ready for your mind to explode, because flipping sound is really, really weird! And super fun! Here are a few things that are great to try:
  • Have two people have a conversation with each other while standing on either side of you
  • Close your eyes and have somebody snap near one ear. Try to guess and point where they're standing.
  • Have somebody make a constant hum, or listen to a car drive by to see how your ears pick it up
  • Try wearing them for a longer period of time and go out in public (you'll look awesome), and see if you can start to adapt and get used to it
I would absolutely love to see your sound flipping headphones and hear ideas that you've come up with for how to use them! Post below, and I'll respond!
Have fun, go wacky, and keep exploring!
  • Woodworking Contest
    Woodworking Contest
  • Fandom Contest
    Fandom Contest
16 Discussions
adeptdigital
1 year ago
Hi. I went in search of the materials for this. Found some tubing used in swimming pools. Looks really similar to "sump pump tubing".
When I held it to my ear, there was a weird sussurating sound, in the same category as holding a sea shell to your ear and hearing the ocean.
The sound was loud enough to be disturbing, and to drown out some of the sounds I wanted to hear.
Possibilities:
1. My hearing is weird - I had no volunteer to confirm the effect
2. My tubing selection is wrong
3. Everyone else experiences the same thing, but didn't mention it!
Any comments?
Brendon
GlennM6
3 years ago on Step 7
I'm completely deaf in my left ear and partially deaf in the right. There are very expensive bone conducting devices to bring sound from one side of your head to the other but the nature of my disease negates their usefulness. I may try this to see what happens if I can modify this design to flip the sound on the left but leave sound on the right intact.
The most interesting thing I think you'll find if you try this is not knowing where the sound is really coming from, something that is more disorienting than you might think.
Thanks for the fun design!
Hey Glenn M6!
Thank you for the comment, and I'm super interested in whether you can bring the sound over and what that will sound like to you. If you want another simple bone conducting experiment, I just wrote up a project I call "Tooth Phonograph" and there's also my previous "Bite-Sized Boombox." Let me know if what you discover!
Those are two interesting projects, but the Boom Box is just wild! I'll put those in my stack of things to do because I'm interested in what sort of fidelity those form factors express. Thanks.
Hey Jude
3 years ago on Introduction
You might also like Domonic WIlcox, who did something similar along with various other wonderful creations :o)
swilus
3 years ago
Cool! Thanks for sharing. This ha inspired me :)
FriXs
3 years ago
one big like for the photo, hahaha
wobbler
Sounds interesting. I wonder is it would work with some bendy straws feeding the sound in from the other side, a mini-stealth version? You could then secretly listen to someone whilst looking away. I'm sure no-one would think you odd or at all unusual if you had some bendy straws going into your ears. You could also paint yours silver and pretend you're a Cyberman (or even become a real Cyberman).
Raitis
No matter what you say this will remain a brain vacuum to me. It's hard to get rid of the first impression. :D
