Speech Recognition With Arduino (Bluetooth + LCD + Android)
1,109
5
In this project, we are going to do speech recognition with Arduino, Bluetooth module (HC-05) and LCD.
let`s build your own speech recognition device.
Supplies:
Step 1: Watch the Video
Step 2: Components
Components:
  • Arduino UNO
  • HC-05 Serial Bluetooth Module
  • LCD 16*2
  • 1x 1K POT
  • 1x 1K ohm resistor
  • 1x 2.2K ohm resistor
  • Wires
  • Jumpers
Step 3: Connect to Arduino
Connect LCD with Arduino
  1. VSS to ground
  2. VCC to +5V
  3. VEE to potentiometer
  4. RS to pin 2 in arduino
  5. RW to ground
  6. E to pin 3 in arduino
  7. D4 to pin 4 in arduino
  8. D5 to pin 5 in arduino
  9. D6 to pin 6 in arduino
  10. D7 to pin 7 in arduino
  11. A to +5V
  12. K to ground
connect HC-05 to arduino
  • tx with rx in arduino (note: don`t connect tx while uploading the code)
  • rx with resistors and then connect to tx in arduino (note:don`t connect rx while uploading the code)
  • +5V to +5V
  • GND to ground
Step 4: Programming the Arduino
first you need to download LCD library from here
note: don`t connect tx and rx when uploading the code
CODE:
Step 5: Download the Application
Download the free App here: Arduino Voice Control
Steps:
  1. Download the app from Google PlayStore
  2. Tap on Connect button
  3. Click on your bluetooth module (in my case it`s the HC-05)
  4. Wait until it says connected to bluetooth module (HC-05)
  5. Tap on the mic icon and state your command
Step 6: Problems Are Solved
  • if LCD doesn`t display anything, adjust the value of POT (variable resistor)
  • if code doesn`t upload, don`t connect Tx and Rx in Arduino
Arduino Contest 2019
This is an entry in the
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    3 Discussions
    agis68
    6 days ago
    this a really clever and usefull in many ways project. Thanks...
    EslamG11audreyobscura
    Reply 5 weeks ago
    Thank you!. this project can be used in a lot of applications such as a communication between two rooms at home.
