Stationary Stand
4,326
142
About: I'm a creative content creator here at instructables, which means that I have the most awesome job making just about anything and everything! My passions are interior decor, fun and innovative children's pla...
Keeping pens and pencils organized seems daunting, especially when little hands are at work creating great pieces of art. With this straight-forward stationary stand, cleaning up and organizing pens and pencils will be as easy as coloring!
Step 1: Cutting and Drilling Wood
I used soft redwood for my stand, but any type of wood could work for this project
The redwood chunk I had had a knot in it, so using a table saw, I cut off the entire end with the knot on it. My working piece was 5" x 9"
I measured out and divided where I wanted to drill the holes where the markers' heads would fit into. I used a staggered design spacing, consisting of three rows, and alternating 4 and 3 holes per row.
Step 2: Measuring Marker Diameter
I used Crayola brand washable markers, and measured the diameter of the caps precisely at .532". Using a 9/16" drill bit, which is just larger than .532", this will ensure that the hole in the wood will be slightly larger than the marker, allowing for easy insertion.
Using a drill press (a standard drill will work perfectly fine as well) I drilled into the pre-measured markings. I drilled at a depth of 1 inch.
Step 3: Testing and Sanding
After I drilled the first hole, I tested to make sure the drilled hole was both wide enough and deep enough for comfort by inserting a marker into it. It worked.
I continued on to drill into all of the pre measured markings.
Next, I sanded my block of wood to get clean, straight edges. Wonderfully, this step also removed any of my pencil markings. score!
Step 4: Making Colored Pencil Stand
Remember that I had to cut off a chunk of my redwood because of the knot? Well, I didn't want to waste any of this beautiful wood, so I cut off just the knot portion of the wood and salvaged another workable piece to create a stand for colored pencils! This process is exactly like making the marker stand except that the diameter of the pencils was obviously much smaller.
Step 5: Measuring Pencil Diameter
I measured the diameter of the pencils at exactly .274" and used a slightly larger drill bit, 5/16", to allow for easy insertion.
This block of wood was much smaller than the stand for the markers, which is fine, because colored pencils are much thinner, but I had to place the drilled holes much closer to one another.
Using the same type of staggered design as in the markers stand, I drew out three rows, with alternating 5 and 4 holes per row.
Step 6: Testing and Sanding.
After making the initial hole with my drill press, I tested to make sure its width and depth were ok by inserting a colored pencil. It passed the test, and so I continued on to make all 14 holes.
Next, I sanded all edges of the block for a polished and clean look.
Step 7: Enjoy an Organized Desktop!
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Jewelry Challenge
      Jewelry Challenge
    2 Discussions
    baris_43
    5 years ago on Introduction
    Very nice design, but not above the security pens in terms of the spikes should be considered again. Good work.
    roballoba
    Yours is so pretty! I did one like this for all my dremel bits....
