Strandbeest Inspired 3D Printable Walking Machine
25,659
265
12
About: Experienced, ambitious designer and fabricator with cross-functional skill sets spanning manufacturing, strategic growth & team leadership.
This Instructable will guide you through the process of creating your very own walking machine. The design of this toy was inspired by Theo Jansen's Strandbeest creatures, and combines 3D printing with some standard hardware to put the beauty of Jansen's walking mechanism in your hands.
Supplies:
Step 1: Parts List
In addition to the printed parts, this design utilizes some standard hardware. These include three aluminum rods, 40 pins, and 20 washers, all to add the spring to its step. These 63 parts are easy to find online or at a hardware store. Below are links to the hardware that I used:
1/8" dia. aluminum rod: http://www.mcmaster.com/#9062k24/=x86afe
1/16" x 13/16" spring pins: http://www.mcmaster.com/#98296a037/=x86bz6
0.141" ID steel washers: http://www.mcmaster.com/#92141a007/=xc45cq
The aluminum rods need to be cut to 6 3/4" lengths (or ~171mm, if metric is your thing). Fortunately, aluminum is a forgiving metal and cuts easily with a hacksaw blade or wire cutter.
Step 2: Printing the Parts, Part 1 - the Numbers
This toy requires a lot of parts. Though it may sound daunting at first, the beautiful simplicity of the walking mechanism that this machine employs is reward enough for anyone attempting the build. Read on, brave maker.
One walking machine consists of 107 printed parts and 63 non-printed parts, for a total of 170 individual parts that comprise the machine. Of the printed parts, there are 13 unique shapes that, when assembled, form 61 moving pieces. The rigid skeleton that holds the machine together is composed of 9 elements, while the other 161 parts form the legs and walking mechanism, all driven by the central crankshaft which accounts for 21 of those parts.
The skeleton, assembled crankshaft, and unassembled parts are shown in each picture, respectively.
Step 3: Printing the Parts, Part 2: Prepare the Files
There are 8 print layouts, which each take an average of 2 hours to print. It'll take a few days.
These files are also available on Thingiverse. If you don't have access to a 3D printer, you can have these parts printed through 3D Hubs.
The following print settings are generally comfortable, but play with them as you like to achieve your desired result:
Infill: 12%
Shells: 3
Speed: 80/140
Layer height: 0.20 mm
Step 4: Printing the Parts, Part 3 - Organization Is Key
It's helpful to start putting the parts together while waiting for the rest to finish printing. This helps keep track of your progress and is also a good way to make sure everything fits together snugly.
For optimal use of time, I recommend printing the parts in this order:
1) Crankshaft
2) Ligament 1
3) Tendons
4) Thighs (x2)
5) Ligament 2
6) Plates
7) Shins (x2)
8) Caps
Step 5: Assemble the Crankshaft
The crankshaft is what coordinates the movement of all the legs. In order to understand the crankshaft, it is best (though not required) to put it together before assembling the whole machine. This will help later on in the assembly process. The crankshaft consists of 21 printed pieces. These pieces fit together to create the heart of the walking mechanism, which uses five phases in a 120 degree rotating pattern.
http://imgur.com/mnYdQLw
I recommend assembling the crankshaft as depicted in the photos, periodically checking that the symmetrical 120 degree phasing is accurate.
Step 6: Assemble Your Walking Machine
Once all your parts are printed, final assembly can begin.
Start by carefully removing the first phase of the crankshaft. This is what you will use to assemble your first pair of legs. Keep the unused portion of the crankshaft intact throughout the assembly process, as this will make it easier to maintain the crucial 120 degree phasing as you add more parts.
Thread on the ligaments and thigh assemblies, taking care that parts are added exactly as depicted in the photos. Don't forget to add the washers as you go! It is very difficult to add them after the fact.
No tools other than the parts themselves are required for this assembly, though I would recommend having some super glue and some oil on hand, to keep any loose pieces from wiggling apart and any tight joints rotating freely. This is by far the best glue and oil combo I've found:
http://www.amazon.com/Insta-cure-filling-Bob-Smith...
http://www.amazon.com/Sewing-Machine-ZOOM-SPOUT-OZ...
Step 7: Testing and Troubleshooting
The walking machine walks best when applying firm downward pressure to the center of its top bar and pushing it forward and backward. Rigorous exercise will help to work out any kinks over time.
If your machine is not walking properly, check that the crankshaft has been assembled correctly, and that the ligaments are all oriented in the right direction. These machines can be unforgiving of assembly errors, but can be taken apart and fixed if necessary.
Step 8: An Exploration of Filaments
This walking machine prints great in a wide variety of filaments. As with maps, the fewest number of colors that you can use while making sure that no two parts of the same color touch is 4. But if you wanted to print a model in which every single part was a unique material you would need 66 different types (there currently exist about 30 materials available as filament).
Step 9: Epilogue
The design of this toy was influenced strongly by the work of Dutch artist Theo Jansen, and is a continuation of a Kickstarter project that was completed in 2012.
The beauty of this design is that anyone can find joy in the animal-like movement of the walking mechanism. Unlike others, this particular design has ten legs in total, so when it's walking towards you all you see are five legs across. The odd number of legs breaks up the walking pattern in an interesting way - because the crankshaft has only three phases, and three doesn't divide evenly into five, the pattern of its motion is disguised and rendered even more visually appealing. Its wide, flat faces catch light in different ways, giving it a warm profile, and the weight provided by large, solid pieces make for a durable toy.
This design is very malleable and open to reinterpretations, improvements, and upgrades. Experiment with new materials, see how much it can carry, build it really tiny, or really big! Or hack the design to add motors and make it remote controlled. The possibilities are endless. Have fun, and dream on...
3D Printing Contest
Runner Up in the
3D Printing Contest
2 People Made This Project!
  • Fandom Contest
    Fandom Contest
  • Gardening Contest
    Gardening Contest
  • Woodworking Contest
    Woodworking Contest
12 Discussions
jazzflutist
Question 1 year ago on Step 5
I printed the parts for the crankshaft but the tolerances are too loose and therefore they dont stay together when assembled. Do you recommend i scale up the rods of the crankshaft slightly to get a more snug fit or is there an easier solution i am missing?
1 answer
danowall1jazzflutist
Answer 1 year ago
Hello! Yes, I've experienced this problem before as well and I find that scaling parts is generally overkill since small parts are so sensitive to small tolerance changes. Instead I would suggest tweaking the print settings you used. For example, try printing at a slower speed, use 3 shells, 60% infill, and a slightly higher temp. That is often enough of make previously loose fit of the parts nice and snug.
TaisH
2 years ago
Your thighs are 208mm but my printer can only handle up to 200mm. How can i fix this?
danowall1TaisH
Reply 2 years ago
Hi TaisH, I've added an STL for a single Thigh file for you to print, you can find it among the rest of the files located here: http://www.thingiverse.com/thing:868878
Hope this helps!
TaisHdanowall1
Reply 2 years ago
Thank you so much!
Do you know if it would have been possible for me to do this myself from your first template?
Is it correct that i need 10 of those prints for the whole thing?
danowall1TaisH
Reply 2 years ago
Hi! Yes, 10 is the correct number. It's possible to import the original STL files into a CAD software program and change how many are in the array if you'd like to adapt them yourself. A good place to start would be tinkercad.com if you're interested in learning more :)
MindKits
3 years ago
I really love this and it is such a beautiful print. I am just wondering if anyone has some more detailed instructions on the assembly? I am just having a few issues. I am following the photos, but unsure of a couple of things. Any help would be great appeciated.
Erivelton
3 years ago on Introduction
Great, i love this machines. His project is a remix of that : https://www.instructables.com/id/The-Humble-Velocipede/ ? I remember his KS, where he spoke exactly the "gear" responsible for the movement
MarkW24
Do you have any video of it walking? I'm sure many people (myself included) are interested in making this, but would need to see what it looks like walking first – after all, the whole point of this is that it walks.
danowall1MarkW24
Reply 3 years ago on Introduction
I've added a few videos, apologies for the poor quality. I'll be adding more as I shoot more reel.
