Striped Wood Pencil Box
10,492
233
9
In this Instructable, I will show you how to make a pencil box with a striped lid. It's fun to make and makes a great gift.
Please vote for me in the Epilog Laser contest. I want to win the laser cuter to make custom items to sell on my Etsy shop I am starting in November.
Materials:
1/4" oak
1/4" walnut
poplar
2 finishing nails
Tools:
Bandsaw
Drill Press
Mitre Saw
Belt/Disc Sander
Supplies:
Step 1: Prep Your Wood
To make most of the box, you will need about 15" of 1/4" thick oak. For the ends, use some thicker wood that contrasts the oak. I used some live-edge burl scraps to add some character. The stripes are made of thin walnut and poplar. Since this is a pencil box, it needs to accommodate pencils. Pencils are about seven inches long, so cut two pieces of 1/4" oak that are 7 1/4" long.
Step 2: Make the Box
Cut one strip 1 3/4" wide and 7" long(bottom) and two 1 1/2" wide and 7" long(sides). Glue them together so that you can't see the seem.
Step 3: Make the Lid
Cut a peice of 1/4" oak to 7" by 2 1/4". Cut it in half diagonally. Take a thin peice of walnut (at least 1/4") and cut a wavy line through it. Cut a slice of 3/4" poplar about 1/32" thick. Glue the poplar in between the wavy pieces of walnut. Make sure the curves align. Glue the walnut between the diagonally cut oak slices. Once the glue is dry, sand the whole thing so it's flat on both sides. Trim both ends square and rip it to the exact width of your box.
Step 4: Add Ends to the Box
Measure the length of the lid and cut the box to that length. Trace the box end (with the lid) on the end piece. Cut the shapes out and glue them onto each end.
Step 5: Attach the Lid
Round over the back edge of the lid on a sander or router. Hold the lid in place and with a drill press drill a small hole through each end of the box into the end of the lid. If the holes aren't deep enough, drill them deeper with a cordless drill. Find some finishing nails that fit snugly in the holes and tap them in until they are flush.
Step 6: Sand
Sand the box on a belt sander until everything is smooth. Round over all the edges except the bottom edges. Sand it more with an orbital sander going from 80 to 320 grit.
Step 7: Done!
Now you are done! You can store your pens and pencils in style. If you make one, post a pic. in the comments.
2 People Made This Project!
  • Classroom Science Contest
  • IoT Challenge
    IoT Challenge
  • Fandom Contest
    Fandom Contest
9 Discussions
amwill
3 years ago
Nice box but would have been better with hidden hinges done inside the side pieces instead of drilling right through...then it would be magic...
isayloramwill
Reply 3 years ago
Thanks, that's a great idea. It would just be very hard to line the holes up.
amin_mh
3 years ago
Nice jub, awesome but may i ask a question? How old are you to work with such a dangerus tools? Your hand shows not too old!
isaylorisaylor
Reply 3 years ago
I have have lots of experience with these tools (and industrial sized versions in my school's shop) and take all necessary safety precautions. Don't worry:)
