Summer Sundress Made From Two Circles of Fabric
5,826
93
15
About: I am an artist and clothing designer with a passion for helping others bring their own creative dreams to life.
I designed this dress in my head a while ago, but the dress contest gave me a perfect excuse to let it become a reality. It's made from just two large circles of fabric: one circle is the main body of the dress, and the other is cut into a spiral shape to make the flounce and straps.
You will need approximately 3 yards of a knit fabric that is 60" (152 cm) wide. The fabric should be stretchy in at least one direction, and it should also look similar on both sides, because both sides of the fabric will be visible in the finished dress.
Step 1: Cut the Fabric
You will need two circles of fabric, one larger than the other. One easy way to cut a perfect circle is to fold the fabric and anchor a piece of string at the folded edge. Then tie the other end of the string to a marker, and draw an arc on the fabric. Cut the fabric on the mark through both layers, and then unfold it.
My larger circle ended up being 48" across (122 cm), so it was drawn with a 24" long piece of string. But I recommend starting with a circle larger than that, even as big as the full 60" width of fabric, and then trying it on briefly the way I describe in the next step to see how it will fit you. You might prefer a larger circle, especially if you are tall, and you can always cut it down later if it's too large... but it's rather difficult to make it bigger. ;)
The second circle will be cut into a spiral shape to make the flounce. It doesn't need to be as large as the other circle, but again, it doesn't hurt to make it bigger than you think you might need. My flounce was made from a circle 36" across, and I had plenty left over. I cut it into a spiral, making each pass 2.5" (about 6.5 cm) from the last cut, until I reached the center. You can see from the pictures that when you stretch the spiral out, it ruffles all by itself.
After you do a very basic fitting to check the size of your large circle (see the next step for directions), then sew the flounce to the outside edge of the large circle. Make sure you orient the flounce so that you are sewing the inside curve (the shorter, concave edge) of the flounce to the circle, and not the outer, longer edge of the flounce. It should ruffle like I'm showing in the pictures.
Step 2: Drape the Dress
Note: This step should be done without clothes on, but I'm wearing clothes for the pictures, because this is not THAT kind of instructable. ;) If you will be wearing a bra with the dress, then wear a bra for the fitting. If you want the dress to be a swimsuit coverup, then drape the dress over your swimsuit. But you will probably not be wearing the dress over a t-shirt and pants, so please don't drape it over a t-shirt and pants. It just won't fit the same way once you wear it on its own.
If you've got long hair, it helps to tie it up. If your fabric only stretches in one direction, make sure that the stretchy direction is going around your body, or else it will be less comfortable to wear and you won't be able to get in and out of the dress very easily.
Lay the fabric on the floor and fold the top of the circle under about 4 inches (10 cm) or so. Lie on top of the fabric with your arms just above the fold. Now wrap one side over your body, and then the other, as though you were a giant human burrito.
Make sure everything is snug and straight. Hold the fabric where it crosses in the front (or use a few pins), and then stand up to check to fit. You may want to snap photos of how you have it draped so that you can see all of the looks side-by-side and pick your favorite one, once you've tried a few out.
Now take it off, fold the top of the circle under 8 inches (20 cm) or so, and try it on again. The look of the dress will change depending on how much fabric you fold down at the top, as you can see in my pictures. The more you fold under at the beginning, the farther the flounce will come down your back, and the shorter the dress will be. The amount you fold under will also make the flounce fall differently across the front of your body.
Keep experimenting by folding under different amounts of fabric and find the look that works best for you. You can also spin the dress around so that the first fold is going across your chest and the fabric wraps around behind you, or wrap across itself at your side.
Step 3: Add Straps and Pin Everything
Once you have settled on your favorite way to drape the dress, go ahead and pin in some straps. I ended up using straps I made by braiding together leftover pieces of the flounce. You could also use the scraps of fabric to make straps, or use ribbons, or chains, or make it a halter top... whatever you like. I took pictures of various different straps to give you some ideas. You could even go strapless if you want to, but it's harder to make a strapless dress fit properly... so if you are a beginning sewer, I would recommend using some kind of strap.
When you are sure you have found your favorite way to drape the dress and the right length for the straps, go ahead and pin everything with safety pins. Pin all along the top edge where the circle is folded, securing the straps as you get to them. Then pin the front through both layers, right beside the flounce, where the dress wraps over itself at the front of your body. You can see in the last three pictures where I have placed the lines of pins, which is where you will be stitching the fabric in the next step. Make sure that the dress is as snug as you want it, but that you can still get in and out of it easily. Do a final twirl to make sure everything is as you want it to be.
Step 4: Sew and Trim
Stitch all along the lines where you have pinned the dress, removing the pins as you get to them. Backstitch over the straps to secure them well. You will be sewing all around the neckline and then down the front along the curve where one side of the circle wraps over the other side. Stitch just beside the flounce, but do not catch the flounce in your stitching line. Also make sure you don't sew the back of the dress to the front! You should just be going through two layers of cloth, right where the safety pins were placed. Go slowly and keep an eye on the other layers of cloth so that they don't get caught under the needle.
Now turn the dress inside-out. There should be a curved flap of fabric that is just hanging free, where one side of the circle was lapped over the other. Trim off the flap of fabric about 3/8" (1 cm) from the stitching line, as shown in the picture.
Step 5: Done!
You're done! Flip the dress right-side out and put it on. What a transformation from a couple of circles! Geometry has never been so awesome. ;)
DIY Dress Contest
Runner Up in the
DIY Dress Contest
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    • Woodworking Contest
      Woodworking Contest
    15 Discussions
    DoggyMANIA6105
    3 years ago
    Very beautiful and I didn't even know it was that simple to make a dress, two circled of fabric... Wow that's simple. Looks really great and your writing is very easy to understand and you've added a bit of humour in there too!
    bharathipaul
    3 years ago
    Simple and neat! it really looks gorgeous. planning to do one for my little one!
    Rapturee
    3 years ago
    ingenious, great job girl!
    Valkyrja'sW
    3 years ago
    ingenious, ideal for my daughter. Will be trying it out for her this summer. Constrasting colours would change the look as well, and for the good seamstresses adding in a zip would make getting it on and off easier
    farraha
    3 years ago
    awesome!
    smstivers
    3 years ago
    That's ingenious! You look so good in it too.
    BirgitJansen
    3 years ago
    Wow, this looks so amazing on you. I wish I were your size, I would do it in a heartbeat! Great instructable and great dress!
    SnazzyBotBirgitJansen
    Reply 3 years ago
    I bet it would work on a variety of sizes, because it seems like a very forgiving and flattering style. :) Thank you so much for your comment!
    parisusa
    3 years ago
    Love how you show the cutting out of the circles on the grass & how you wrap yourself up! Great visuals! So pretty! Thank you for sharing!
    Penolopy Bulnick
    3 years ago
    That is a really snazzy way to make a dress! So unique and adaptable to everyone :)
    Super_seal
    3 years ago
    A beautiful looking dress out of two circles? Who knew! you nailed it!!
