TF2 Minigun (Sasha)
71,255
285
28
This is an Instructible for creating a minigun from Team Fortress 2 for cosplay or whatever.  This covers creating a basic minigun with spinning or fixed barrel.
This was made at LVL1, Louisville's Hackerspace.  (see more at http://www.lvl1.org)  Be sure to check your area for a hackerspace, they're a great place to meet new people, learn new things and get access to awesome tools.
Having a laser cutter or CNC machine will really help with this build, but they're not required.  The pics in this tutorial were all taken after the gun was built, so everything is its final colors.
When building my weapons I try to make my weapons scaled perfectly and worry about the details later.  There are a lot of miniguns out there, but most of them are scaled horribly.  To me, the details don't really matter as long as the weapon is scaled properly.
Tools:
Laser cutter or CNC machine
band saw
miter saw
belt sander
hot glue gun
tin snips
rivet gun
drill
box cutter
really long Phillips head screwdriver
Rough List of Materials:
1/2" foam board
1/2" plywood
3/4" PVC pipe 10'
1/2" PVC pipe about 3' long
1/2" conduit about 1' long
4" PVC coupler
4" to 2" PVC adapter
3" PVC pipe 1' long
2" PVC pipe about 2' long
sheet metal
12" long 3/8" diameter threaded rod
6x coarse 3/8" nuts
4x 3/8" lock washers
2x 3/8" fender washers
4x 3/8" washers
3/8" inner diameter bearings
servo
12v battery
microswitch
belt (and pulleys if you don't want to make your own)
Mod Podge
craft foam
black and white paint
other bits of scrap wood
Step 1: Make the Barrel
We're doing this first because it looks awesome, and if you get that far it'll make you want to complete the rest of the project.
Cut six 1" diameter PVC pipes to 19" in length.
Use 1/2" foam to cut out 6 foam supports (8 for a static barrel.)  This file is for a laser cutter which makes the final part a little smaller so you might need to scale it slightly to work with whatever method you use.
- Print the file onto a sheet of paper, glue to foam, cut out with a knife.
- Same thing, as above, but use a band saw or jig saw.
- Laser cutter
- CNC machine
- Mind bullets (advanced users only)
Four of these only need to look pretty, two need to fit snugly in the end.  On all of them, the pipes should fit snugly; our entire barrel assembly is held together with nothing but friction and paint.  If you're cutting the holes manually it is also easier to hide mistakes if the holes are slightly smaller instead of too big.
Test fit all of your foam pieces, then add a layer or two of Mod Podge.  I know this sucks and it takes forever to let every foam bit dry, but if you don't Mod Podge the foam it will melt when you paint it.
The wood pieces are smaller and have a center hole for the axle.  If you aren't going to make the gun spin you can skip the wood pieces and make two extra foam supports.  Our first revision of this gun didn't spin and the barrel was just held in place by the friction of the foam in the funnel bit and a single screw on the top.
Fit all of the foam pieces together as best as you can.  To get the individual barrels even cut a scrap piece of 1" thick wood to fit inside the end so you can press the barrels down against it.
Bolt the wood bits onto a 12" long 3/8" wide threaded rod (our axle).  As you can see in the pics, I only used hardware to secure the very end support and then used the second support as, uh, support.  The hardware I used was
nut - lock washer - washer - fender washer - support - fender washer - washer - lock washer -nut
Once the wood supports are attached to the axle, slide the wood pieces onto the barrels.  This is kind of hard, I ended up pressing down on the wood support and spinning each individual barrel up into the support a little bit at a time.  When you're done you will probably have to readjust all the foam supports again.
Step 2: Make the Ammo Barrel
Cut a piece of sheet metal into an 15.5x30.75" rectangle.  I recommend sheet metal from the air duct section of Lowes, it's much cheaper than the actual sheet metal sold with the steel bars and such.
Mark a line down the short side 1/2" from the edge.  Every 1" to 1.25" or so put a mark for a rivet.  We made ours unevenly spaced on purpose to match the game gun.  Drill holes for the rivets on one side, the roll the sheet into a circle and rivet together.  Once you get the rivets in it should naturally form a perfect-ish cylinder.
Trace the end onto a foam board and cut out three circles to help it hold its shape.  One will be put in the front permanently, you can make this one as tight as you want.  After you put it in, hot glue it into place from the inside.
The second one will be for the back end, but this one you will take in and out to access the inside of the gun.  I made mine slightly big and tapered the edges.  After a few fits it started to naturally sit in place.  I would recommend putting a single drywall screw in it to pull it out..
The third piece will be for the middle, it will be a little looser and will need to be modified later to get around the backbone.  It will be less for holding shape and more for keeping the barrel from deforming too far when the end piece is out.  With the end piece out this barrel is very weak, be very careful with it so you don't deform it too much.
Step 3: Create a Backbone
We're going to create a backbone to attach everything to.  Cut a 1.5"x1.5" piece of wood to 12" long.  If you are not spinning, then this is all you need for this step.  The size of the backbone isn't super important, just make sure it's not too wide or it will deform the barrel.  If you plan to make your gun spin, be sure it's about the size of your servo to make mounting the servo easier.
Cut down two other scraps of wood to 8" long for the servo mount.  These will be attached to the backbone and will support the servo (see pic for the complete part).
Also be sure to drill some largish (1/4-3/8") holes sideways through the backbone.  This is so you can ziptie the battery down, if you forget this step you'll be taking the gun apart later...
Attach the backbone to the gun with a couple drywall screws through the ammo barrel.  Be sure to pre-drill the holes so you don't split the backbone.  Pay attention to where you place the backbone as this will determine where the seam lines up on the side of your gun.  If you look at the minigun from the front you'll notice that the barrel is off center.  I forgot this fact so our rivet seam ended up slightly higher than it should have been.
Step 4: Make the Main Tube
Next we will create the main tube on top.  Cut a 3" PVC pipe to 9" long.  Next, create a slit in the back for the belt.
Just make some shallow cuts with a chop saw then use a drill or something to break the middle piece out.  When you're cutting the slits do NOT let go of the trigger until the blade is all the way back up.  If you let go while trying to balance the blade in just the right spot it will jerk down as it stops and ruin the part.  This part doesn't need to be very exact, as long as the belt has some room to move.
Cut a small scrap of wood for a spacer.  I used 3"x1"x5/8"
About 2.75" back drill a hole in the top (opposite side of the slit) for a screwdriver to fit through.  On the other side drill a hole for a drywall screw, cram your hand into the tube, get the screw started in the hole on the bottom, then use a screwdriver through the hole in the top to attach it to the backbone of the gun.  You'll want to pre-drill the spacer also so it doesn't split.
You don't have to attach it yet, you just need to know where this screw is going to go so that you don't cover it up with a bearing mount.
Cut round pieces to support the bearings of your choice.  I went with some really cheap plain bearings from Lowes and the servo was able to power through the added friction but I would highly recommend getting some flanged ball bearings instead.
Once you cut the bearing blocks screw them into place with a single drywall screw.  Be sure to leave them a little loose so they don't bind on the axle.  In my pics I screw the the blocks into place from the top, you can probably do this from the bottom instead without making it harder to take apart.
Put the rear mount in front of the screw hole you drilled earlier (so you can take apart the gun later) and put the front mount about 1.25" back.  For a exact fit press the PVC adapter in and butt the bearing block up against it (see first pic of next step for what I mean).
Once the bearing blocks are in test fit it on the axle to make sure it spins correctly.
Step 5: Mount the Main Tube
Screw the main tube to the ammo barrel.  The adapter should be 3" from the front edge of the barrel.  Once the main tube is set, screw the adapter to the backbone.  I used a bolt with a nut on the other side, but this was overkill and made the gun hard to take apart.  A single drywall screw through the bottom of the adapter into the backbone should do the trick.  Just make sure that whatever you add is countersunk so it does not interfere with the barrel.
Hopefully your main tube should be tight on the top of the adapter.  This will let us adjust the angle of the height of the main tube relative to the adapter.   The barrel is so heavy, it will bend the axle slightly and the barrel is tight enough in the adapter that it this slump will cause it to rub.  To compensate for this we'll add a screw on top of the main tube that will push down the adapter relative to the main tube.  Once this is set correctly the gun will only spin when you're holding it properly, lay it on its side or hold it upside down and it'll set against the adapter enough to prevent movement.
When picking a set screw make sure to get something that isn't pointed on the end, otherwise you'll end up going through the adapter too.
If you're feeling really freaky you can try what I'd like to do for revision 3; make the barrel support and adapter into one giant custom ball bearing.  This is how real mini guns are supported.  I've included a rough sketch of the idea if you want to try it.
Step 6: Make the Front Handle
Cut three rectangles out of 1/2" of wood, two 4"x3.5" and one 4"x5.75".  Attach the small ones to the side of the big one as shown below.  Don't worry about the strength of the side pieces, they only need to support their own weight.  All of the stress will be on the big middle piece.
You can round the corners if you want, I was a little lazy and skipped this step.
Next cut a piece of 3/4" conduit for the front handle.  I would cut it long, bend it, then cut the ends down to length.  If it's a little off don't worry, the game gun is slightly lopsided too.  (It's not a bug, it's a feature!)
To attach the pipe to the wood, we'll need to screw into the open end of a hollow tube (which generally doesn't hold for very long).  To make the handle stay attached longer, jam a bunch of wood into the ends.  Just cut some taper shaped pieces of wood and hammer them into the end of the tube until you can't cram anything else in there.  Cut off the excess and then run a screw into the end of the pipe without pre-drilling.  This will make all the stuff you crammed into the pipe even tighter and will create a stable way to mount the handle.
Mount the handle 1.25" from the edge.
Cut the V piece.  This is where I really deviate from the game files, the method I show here for the V and the rear handle don't match the game exactly, but they were quick and easy to make.  Revision 1 of this gun was finished at the con so I had to cut a few corners to get it done and this is one I never went back and fixed.  It's a part nobody really looks at and there are other improvements I'd rather do first.  If you can come up with a better solution let me know, if not plow on ahead!
Cut the V, and then bolt it to the top of the front handle base.  I kinda cheated and used screws that looked like bolts.. :/
Step 7: Cut the Rear Handle
Cut the rear handle out of wood or something sturdyish.  Revision 1 of this was foam with a layer of ABS on each side.  It worked alright, but was attached poorly.  The next version was cut from 1/2" MDF.  This held up better but was starting to split by the end of the con.  Some sort of plywood would probably work best.
Use the attached file to CNC or hand cut the handle.
You should also cut the bottom piece now.  This will be glued to the back foam piece for easy removal of the back piece.
Step 8: Mount the Handles
Screw the front handle into place.  I used three screws, one in the middle for strength and two on the sides so you can make slight adjustments to the angle.  Once the screws are through, they'll block the barrel; paint the ends so you know how far they go through then grind off the painted part so the screw won't go all the way through the adapter.  Once that is done you'll probably have to sand down the ridges created by the screws when they came through.
If you're going for a non spinning barrel don't trim the screws, they'll help hold the barrel in place.
Fit the rear handle in place, it should be pretty tight under the V.  If it's too tight just sand down the end until it fits nicely.  Drill a pilot hole from the top of the V through to the main tube.  Remove the rear handle and make the hole bigger, this part is the most likely to split.
For the back of the rear handle, I just ran a screw from the inside of the main tube into the handle.  This held pretty well, even with the foam since the back part of the handle gets pushed down in order to balance the gun.  Most of the weight is held by the front handle.
Once the front and rear handles are in place, hot glue the bottom piece of the rear handle to the foam so it looks like a continuation of the rear handle.
Step 9: Get the Gun Ready to Hold the Barrel
Now for the moment of truth: attaching the barrel to the rest of the gun.
Add two nuts and a lock washer to the axle about 1.75" from the last wood support.  Just hand tighten for now, you'll probably need to adjust this soon.
Carefully slide the axle into the main tube.  Make sure the nuts are back far enough that they're hitting the bearing before the barrel is hitting the back of the adapter.  As you can see in the pictures, my front wood support is all the way out of the adapter.
Pick up you gun and see if the barrel spins nicely.  If not:
- Check the alignment of your adapter
- adjust the adapter height adjustment screw covered in step 5
- back out the nut stops so the barrel is further out from the gun
- verify the inside of the adapter is smooth
- loosen the screws that hold the bearing blocks and make sure they're not binding
- double check that your axle is strong enough and isn't sagging too far
- give up and pretend you were working on a static, non spinning barrel all along
Hopefully you don't have to go with the last option...
Once you're happy with where your barrel, is tighten down the nut stop at the front, put the barrel back on the gun and then add a rear stop (nut, lock washer, nut).  It's a little tricky to get it in there but it's doable.  I wouldn't worry about getting the lock nut flat, otherwise you'll never be able to get it off.
From now on when you store the gun, always put some foam under the end of the barrel so it's supported.  The axle holds up alright, but I wouldn't trust it to not bend permanently after a couple weeks of storage.
Step 10: Get Some Pulleys and a Belt
Now it's time to drive the barrel!  I went with a belt and pulley because the belt is pretty forgiving (not as sensitive as gear meshes) and will offer a little protection for the motor by allowing the belt to skip if something happens to the barrel.   I also could easily print out pulleys on our 3D printer in order to test various drive ratios.  If you don't have a 3D printer this is a little harder, so you might want to look into direct drive.  The final ratio I went with ended up being 1:1 so direct drive is a viable option.
If you'd like to go the belt and pulley method, find a belt about 9" long.  To generate the pulleys I used an OpenSCAD library I found on Thingiverse at http://www.thingiverse.com/thing:16627  Attached to these steps are various file formats of the pulleys so you don't have to dive into OpenSCAD (you should) if you don't want to.
The bottom pulley has been modified to fit on a servo.
Step 11: Modify a Servo
I chose to use a servo because they are relatively cheap and include a gearbox which gives them a lot of torque and limits their top speed.  You'll have to modify a servo to use it as a drive motor.  The Instructible below gives step by step instructions for modifying a servo.
https://www.instructables.com/id/How-to-modify-a-servo-motor-for-continuous-rotatio/step3/How-to-modify-a-servo-motor-for-continuous-rotatio/
TL;DR: rip out all the electronics besides the motor, attach leads directly to the motor, cut off the stop tab on the big gear.
I blew a couple servos when working on the gun, mainly by testing to see how much power they could handle.  18v is the danger zone, 25v is a burnt up servo.  12v works pretty reliably and spins the barrel at a decent speed.
Step 12: Mount the Electronics
Attach the pulleys to the axle and the servo.  Run the belt around both pulleys, slide the servo until the belt is tight then screw it into place.
Mount a momentary switch on a the handle and mount a 12v battery to the backbone (or somewhere inside the ammo barrel).
Wire everything up and test it out.
Step 13: Add the Details
Now you have a decent minigun with all the important structural bits.  The rest are just detail pieces.
Side tubes -
Cut a 2" diameter PVC pipe to 5.5".
Cut foam end caps and rings, Mod Podge and paint.
Once dry, hot glue to the ammo barrel.
Side Thumbscrews -
I just cut these out of 1/2" foam and hot glued them to the side of the front handle mount.
Bottom Pipe -
*Do not glue this on until everything is painted!*
Cut a 1/2" diameter PVC pipe to 8.5" long and another 15.5" long.  Put a coupler on top end and 90 degree joint between the two.  Make a foam block with a hole for the bottom pipe and attach it to the bottom of the ammo barrel.  Make a pivot for the front out of foam or print the attached .stl file on a 3D printer.  Yes, printing that piece is overkill (and takes forever) but everyone knows that anything made with a 3D printer is automatically more awesome.
Everything else -
There are many pieces we never got around to making, look around at source pics and fill in all the stuff we missed.  Craft foam is a good, easy to work with material to add details.
Step 14: Paint
Make sure all exposed foam parts have a good couple layers of Mod Podge.  Take everything off the ammo barrel and paint it white.  Once dried mask off the top 8.5" and paint the bottom black.
Stuff some paper towels in the main tube to protect the bearings and put a garbage bag over the axle then paint everything black.  Be sure to get all angles so the gun doesn't look funny from the bottom like ours does.
Step 15: Learn Fake Russian, Make an Awesome Hat
Once the paint dries put everything back together and enjoy your awesome minigun!
You also might want to brush up on your fake Russian accent and get an awesome hat to help establish your superiority.
YOU DID WELL!
Halloween Props  Contest
Third Prize in the
Game.Life 2 Challenge
Runner Up in the
  • Jewelry Challenge
    Jewelry Challenge
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
28 Discussions
MadameNeko
3 years ago on Introduction
Can I buy one from you? My friend wants to cosplay as the Heavy, and I would like to help her out. :)
There is a free Steam gift card giveaway at http://getsteamgifts.com/ Works for all countries!
Ethansaurus
4 years ago on Introduction
Free Steam games: http://getsteamgifts.com/ Works for all countries!
coryalex
5 years ago on Introduction
Thank you for inspiring me! I'm building my own Sasha, now.
I'm 3D modeling most of the parts, and I've got just about all the barrel components done. She's coming along beautifully. I'm going to do a test fit to verify motor operation (and lights... yes, lights). Then I'm on to other parts of the build.
I plan to have it done no later than May (for Phoenix Comicon 2014).
Thanks again for the inspirational Instructable. :)
GigabitPony
Okay on the barrel what is the front housing made out of? It looks like big piece of PVC pipe but you do not state what it is.
JackDF
5 years ago
what does modge podge do to the foam, is it like a detail filler?
RedWagonJackDF
Reply 5 years ago on Introduction
The primary reason for it here is to prevent the spray paint from melting the foam. Bondo is a much better detail filler since you can build it up and sand it smooth. Modge Podge is basically white glue mixed with water so it can fill details about as well as latex paint.
crayzeedude
6 years ago on Introduction
Is it possible to make this without some the machines (i.e. CNC, saws, etc.)? I, sadly, do not have access to much of them.
xeon_hl2
6 years ago on Step 15
This is just pure win :D, good job.
poofrabbit
Congratulations on being a finalist in the Halloween contest!!! Can’t wait to see if you win! Good luck!
propfreaks
Awesome tut! Just fyi, I posted to it on my site, www.propfreaks.com.
Thanks for the great effort!
-@PropFreaks
